Old 11-29-2009, 06:20 PM   #1
elitescouter
Member#: 127164
05 WRX STi
Default My custom air intake box completed!
I finally finished what I wanted to do for a very long time. Finally I had some spare time and I thought I’d try and finish it. The box is made out sheet metal and it basically separates my short ram cobb intake from all the hot air that comes from the engine. There are 2 big holes where the silencer used to be and the air comes from the fender and into the box. Not the cleanest install, but it really does the job.
The night before I put it in when it's around 50 outside the temp of my air intake temp used to range from 87-130s.
After I put in the box I drove my car for 1 hour, outside temp was 54 and my intake temp ranged from 57-64. That was with stop-n-go in traffic not just on the freeway.
It's sealed off pretty good and I really like it. You can feel the difference in performance.
This is temporary, I am working on a thicker and cleaner box. This was just to get it to fit in perfectly and see what kid of temp's I get, that way I can just take it out and draw an outline onto the thicker sheet metal and bend it into shape.
Just tho throw it out there, this is made out of one piece of sheetmetal except the cover and then bent into a box. The aluminium tape is there to seal the tiny gaps from hot air coming in and not to hold it together.
elitescouter is offline   Reply With Quote
Old 11-29-2009, 06:40 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
is it only held together with tape?
scby rex is offline   Reply With Quote
Old 11-29-2009, 06:51 PM   #3
elitescouter
Member#: 127164
05 WRX STi
Ohh no... It's screwed in to the bottom
Old 11-29-2009, 07:16 PM   #4
DevinR
Member#: 205825
01 2.5 RS coupe
Haha it looks like you duck taped it then chromed it out.
DevinR is offline   Reply With Quote
Old 11-29-2009, 07:37 PM   #5
elitescouter
Member#: 127164
05 WRX STi
Used the aluminium tape to seal it so the hot air doesen't get in. This box is temporary so I can see some results then I will be putting in a thicker box. Next time I will be using foam tape in between gaps that way I don't have to wrap it in aluminum tape.
Old 11-29-2009, 07:41 PM   #6
gungaslow
Member#: 144906
watch out for squirls.....if one gets in there at night it wont be good.....i had a similar thing happen to me
gungaslow is offline   Reply With Quote
Old 11-29-2009, 07:43 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
why not rivet it all together, then attach the lid with screws?
Old 11-29-2009, 07:45 PM   #8
PCrowlz
Member#: 215260
12 WRX STi
PBP
pretty sketchy but if it works then it works!
PCrowlz is offline   Reply With Quote
Old 11-29-2009, 07:52 PM   #9
elitescouter
Member#: 127164
05 WRX STi
Everything is made out of one whole piece of sheet metal just bent it into a square. The only thing that's seperate was the lid.
The next one I am making will be also bent but the material will be thicker. This was such a pain in the... to do just because the top wall had to be cut in a curve so it fits good because the wheel is there so it's not level.
Old 11-29-2009, 08:46 PM   #10
jessyandjoseWRX
Member#: 226904
2004 wrx
aspen white
lmfao....................... hahahahahahahaha
jessyandjoseWRX is offline   Reply With Quote
Old 11-29-2009, 10:51 PM   #11
elitescouter
Member#: 127164
05 WRX STi
This one is not perfect, the next one will be much better but right now the change in air temp is very noticable. I mean going from 130 intake temp down to 64 when it's the same temp outside is basicly what I was hoping for. You can definatly feel the difference in the performance.
Old 11-29-2009, 11:43 PM   #12
WagonWielding
Member#: 143213
1990 ED7 Civic Si
'03 E39 Touring
How many times does this guy have to explain himself?
This is Version 1.0
It works as intended & drastically lowered intake temps.
Version 2.0 is in the works and will be more visually appealing as well as keep intake temps down.
I say damn good job and keep up the good work
WagonWielding is offline   Reply With Quote
Old 11-29-2009, 11:46 PM   #13
Dizzuque
Member#: 98699
2007 SWP WRX
good job.
Dizzuque is offline   Reply With Quote
Old 11-30-2009, 06:52 PM   #14
elitescouter
Member#: 127164
05 WRX STi
This is Version 1.0
Exactly! Thanks!
Old 11-30-2009, 07:31 PM   #15
Serkan
Member#: 180514
2004 Sti
I dont get it. Is this some kind of heatshield to the stock box or an airbox itself.
If so how is it keeping the temp down ? And what did you do with filtering ?
Edit: I didnt read the whole thing, i got the answer to my question, sorry. Good job !!!
Serkan is offline   Reply With Quote
Old 11-30-2009, 07:44 PM   #16
C Branch
Member#: 222120
2003 WRX
Nice job! I did this same type of thing on my Civic drag car a few years back and the results were very impressive.
It is nice to see other peoples creativity. Keep up the good work!
C Branch is offline   Reply With Quote
Old 11-30-2009, 07:53 PM   #17
jgardner9000
Member#: 219549
2009 STi
Where and what is holding this to the car? I like the idea might have to try somethin like that
jgardner9000 is offline   Reply With Quote
Old 11-30-2009, 11:06 PM   #18
elitescouter
Member#: 127164
05 WRX STi
There is a screw on the bottom holding it to the engine bay.
Old 11-30-2009, 11:14 PM   #19
yeloh474
Member#: 170128
2004 JBP STi
318whp/342wtq on Mustang
Why didn't you just get one of these instead?
If it's money...then nevermind!
yeloh474 is offline   Reply With Quote
Old 11-30-2009, 11:19 PM   #20
downpipe12
Member#: 212666
2002 WRX Wagon,
Black, EVOIII16G+Meth
that really improves the hell out of the short ram, cool idea.
downpipe12 is online now   Reply With Quote
Old 12-01-2009, 01:28 AM   #21
elitescouter
Member#: 127164
05 WRX STi
It's not a money issue, I just like to make custom parts to fit my needs. They make it to fit all years, I make mine to fit just my car.
The next one that I am in process of making will be much better and thicker.
Old 12-01-2009, 02:08 AM   #22
SIBzzz
Member#: 129888
Liquid Copper
u my friend have too much time on your hands. Props on the intake, but seriously go get a gf or something lol jp
SIBzzz is offline   Reply With Quote
Old 12-01-2009, 02:27 AM   #23
jgardner9000
Member#: 219549
2009 STi
Where does one find one of these? I checked the cobb website.... unless they dont fit wrx.... ???
Old 12-01-2009, 02:45 AM   #24
07pearlwht
Member#: 212576
2007 impreza wrx sti
pearl white
Looks like they discontinued it or something. Which they have done to a few of their products.
07pearlwht is offline   Reply With Quote
Old 12-01-2009, 02:50 AM   #25
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
pretty cool, just looks a little... meh... YES I UNDERSTAND IT'S THE PROTOTYPE.
Le Saboteur is offline   Reply With Quote
FS: So Cal 07 STI full turboback, heat shield, intake silencer, air intake box bugeyeblue Engine/Power/Exhaust 7 12-28-2007 04:09 AM
My Custom Air Box GPJamesMVT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 09-25-2006 04:39 PM
OEM WRX air intake box w/ ITG air filter djerickd Private 'For Sale' Classifieds 1 07-09-2006 06:56 PM
WANTED: Stock air intake box and airscoop zuczek Canada Region Forum 19 10-27-2004 12:33 AM
AVO carbon fiber stock air intake box ZERO26D Interior & Exterior Modification 4 01-27-2003 12:41 AM
