Old 11-30-2009, 11:18 AM   #1
marcus712
Member#: 184602
2006 sti
steel gray
Default Rough idle and throwing CEL
So a few days ago I changed out my power steering pump myself on my 06 STI and now I have a rough idle, my check engine light is on and my cruise light is flashing on and off. anyone on here know what the problem might be?
Thanks
marcus712 is offline   Reply With Quote
Old 11-30-2009, 11:25 AM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Is it still possible to put the MAF in backwards these days? Did you plug it back in?
wcbjr is offline   Reply With Quote
Old 11-30-2009, 12:56 PM   #3
marcus712
Member#: 184602
2006 sti
steel gray
I checked and they are all good. Any other suggestions?
Old 11-30-2009, 01:23 PM   #4
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Did you reconnect the ground to the intake manifold?
edit: maybe that was back on my old RS...
Old 11-30-2009, 01:25 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
oh, and did you pull the code?
throttle body connector
crankshaft position sensor
camshaft position sensor
tgv sensor
rough idle and cel codes nolaboost Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 09-27-2009 09:03 PM
CEL Flashing P0301 Rough Idle and NO Power WRXerist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-05-2008 11:33 PM
Rough idle, but no CEL dan_j_b Normally Aspirated Powertrain 18 04-24-2005 12:45 PM
Rough Idle and CEL 6Pack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-25-2003 09:46 AM
Spark plug=very rough idle and CEL? Bunuel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-22-2002 11:59 PM
