Old 11-30-2009, 12:08 PM   #1
wrxgirl08
Member#: 227965
'12 wrx
pbp
Default I need help!!!
So I was pulling out of a parking lot and I couldn't go sideways because there were cars parallel parked way to close on either side and the dip was huge. It cracked my zerosports bumper on the top and I really need to know if it's fixable. I really hope those jerks who parked there got parking tickets.
wrxgirl08 is offline   Reply With Quote
Old 11-30-2009, 12:48 PM   #2
REVNU
Member#: 82147
2005 WRX Sedan
That's not that bad. It's fixable. All it needs is a little filler, sanding, and paint. Take it to a shop and get a quote or do it yourself if you know how.
REVNU is offline   Reply With Quote
Old 11-30-2009, 12:50 PM   #3
wrxgirl08
Member#: 227965
'12 wrx
pbp
Ah you have no idea how relieved I was when I read that . . . I literally teared up when I saw the crack. Would it be hard to fix it myself?
Old 11-30-2009, 12:53 PM   #4
REVNU
Member#: 82147
2005 WRX Sedan
You might if you know how to wet sand and blend paint. It's possible you might have to repaint the whole thing to get it to match. Best thing to do is ask a shop if doing a "spot repair" would work, then try to figure out if you want to tackle the job. If not, then let the pros handle it.
Old 11-30-2009, 12:57 PM   #5
wrxgirl08
Member#: 227965
'12 wrx
pbp
I think I'll just have them do it then, cause if it doesn't match that'll be all I see when I look at it thanks a bunch!
Need help with VAGCOM, "Not trying to flash, just log" realitycheck3907 Open Source Reflashes 7 06-05-2010 09:12 PM
NEED HELP!!! Squealing and burning smell PremierWRX Transmission (AT/MT) & Driveline 6 06-05-2010 08:57 PM
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 05:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain 0 06-04-2010 08:53 AM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
Message Board Statistics All times are GMT -4. The time now is 01:39 AM.
