Old 11-30-2009, 04:43 PM   #1
windozer
Member#: 213473
2004 WRX Wagon 19t
San Remo Red
Default Open Loop Fueling Question
Ok, so I know that a WBo2 is a good idea cause the front o2 is known to be inaccurate esp. around WOT. When tuning OL fueling, isn't the ECU using the front o2 to measure AFR and adjust the IDC to meet the target AFR? Isn't there an inherent problem with using an inaccurate sensor to measure AFRs that the ECU uses in it's fueling compensations?
windozer is offline   Reply With Quote
Old 11-30-2009, 04:51 PM   #2
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
It doesn't use the narrow stock o2 to measure Open loop fueling. It uses your MAF signal and the a target AFR to adjust the injector pulse. How ever when you tune it you need the wide band to know if you are at the correct AFR.
Agkelos is offline   Reply With Quote
Old 11-30-2009, 04:52 PM   #3
windozer
Member#: 213473
2004 WRX Wagon 19t
San Remo Red
OK Thanks, that makes sense.
What exactly is closed loop vs. open loop fuel control? Neek Engine Management & Tuning 5 03-09-2005 01:50 AM
Need experts! Open loop fueling coming on too slow... big_adventure Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 11-30-2004 09:24 PM
UTEC - please explain to this idiot the benefits of open loop fueling edkwon Engine Management & Tuning 15 04-21-2004 09:36 PM
Can someone take a look at this open loop fuel map... 03WRXMA Engine Management & Tuning 7 03-13-2004 04:33 PM
Open loop fueling? Bolster Engine Management & Tuning 7 03-07-2004 12:56 AM
