Old 11-30-2009, 10:53 PM   #1
Cobb2006WRXJR
Member#: 229568
2006 WRX limited
Red
Default Running 215/45 R17 Yokohama ADVAN S.4. Tires on my 2006 WRX Anyone run those before
Im running 215/45 R17 Yokohama ADVAN S.4. tires on my 2006 WRX and I personally think they run great. The handling is great. Making tight turns is great. I can take curves at high speeds just as well if not better than with the stock bridgestone potenza re92's. The ride on the road is smoother than with the stock bridgestones and not as noisy as it is with the stock bridgestones. Cheaper than the stock bridgestones. Personally I think its a great pick if you need all season tires to replace your stock bridgestone potenza re 92 all seasons on your WRX. You don't need to spend 250 dollars each tire for bridgestones. I paid 152 dollars each tire for the Yokohama ADVAN S.4's and they run just as good if not better than the stock bridgestones. If anyone else has had an experience with this tire. Post and let me know what you thought. I think these were great. When I first put them on I thought they werent good but i think i just had to break em in cause after a few days they ran perfect. Great tire. Tell me what you think?
Cobb2006WRXJR is offline   Reply With Quote
Old 11-30-2009, 11:11 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
oh boi.....
Old 11-30-2009, 11:44 PM   #3
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
I think your entire comparison is based on 2 tires which is grossly insufficient to actually recommend something to someone. Also, I think comparing anything to the RE92, especially on performance per $ is silly. It's a crap tire and everyone knows it. Beating an RE92 in a tire competition is like beating a quadriplegic in a sprint. It doesn't really mean you're any good.
Do I think the S.4 is a bad tire? No. Would I buy it? No.
mosc is offline   Reply With Quote
Old 12-01-2009, 01:28 AM   #4
07_OBP_rex
Member#: 164321
Call me
True.
Quoted for its most epic, awesomeness.
07_OBP_rex is offline   Reply With Quote
Replacing one of 4 tires on an '03 WRX saqib11 Tire & Wheel 4 04-30-2010 03:05 AM
Will 2006 STI suspension fit on my 2006 wrx? COBOMO Brakes, Steering & Suspension 2 01-27-2010 12:27 AM
Yokohama ADVAN S.4. Tires Bleevin Tire & Wheel 2 11-10-2007 12:26 PM
Wtb: 4 Tires For My 02 Wrx! inthememof911 Mid Atlantic Impreza Club -- MAIC 2 11-16-2005 02:30 PM
Mounted BBS STI Rims/tires on My 05 WRX, do I need an alignment? Tire Pressure? joeyb7 Tire & Wheel 11 06-07-2005 02:26 PM
Message Board Statistics All times are GMT -4. The time now is 09:44 AM.
