Welcome to the North American Subaru Impreza Owners Club Monday December 22, 2014
Old 03-14-2011, 07:20 PM   #301
worksti
Member#: 117847
2005 Rotated DOM3XTR
460whp, 400wtq Pump Tune
Originally Posted by Bobojr11 View Post
I have an 04 STi and i have a dom4 old school and my tuners just told me of the defects and i found out it was cracked. I called blouch and they will take care of it for $200. Is it worth really keeping after it is fixed?
Yes...
worksti is offline   Reply With Quote
Old 03-14-2011, 07:32 PM   #302
Beetspeed
Member#: 166264
1974 VW 2.2 BW8475
396 WHP @ 25psi
I had a cracked exhaust housing (the welds only actually) with my DOM3, but we welded it ourselves (preheated and all) and it held up better then before
After welding done right, they are definately worth keeping imo.
Beetspeed is offline   Reply With Quote
Old 03-14-2011, 09:37 PM   #303
GDAryder
Member#: 184753
2005 WRX
yes they are, hell $200 to fix a turbo that cost well over that is a good deal if you ask me
GDAryder is offline   Reply With Quote
Old 05-17-2011, 02:09 PM   #304
nastorino
Member#: 263570
2007 STI
dom3xtr's with 8cm now available huh? should help reduce lag and still make 400whp with proper supporting mods.
07 with only 17k miles stock block/clutch running 93 no meth with tgv's deleted, inlet, 70mm cai, id1000's, gs ebcs, aps tmic what would the realistic numbers be with a 3xtr and 4xtr? car will be daily driven but i want more through out the entire rpm range especially on top
nastorino is offline   Reply With Quote
Old 05-17-2011, 02:15 PM   #305
Kovs04sti
Member#: 257085
07 Sti SWP
This is making me want a 4.0!
Kovs04sti is offline   Reply With Quote
Old 05-17-2011, 02:26 PM   #306
nastorino
Member#: 263570
2007 STI
i wonder how city much driveability you lose going with the 4.0 instead of the 3.0...it is the same price lol
Old 05-17-2011, 03:59 PM   #307
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
Are most people still running an IWG with the Dom 3? I'm planning to do a Dom 3.0 XT-R on my V7 swap sometime, as soon as funds allow. I was planning to get 1000cc injectors, just to make sure I'll have plenty of fuel, and keeping it IWG for now to save some money. Any EWG funds I'd have at the time will most likely be going to a clutch haha I have an Exedy Stage 1 now, but I doubt that's going to hold the Dom 3.0 CT-R power levels.
Xcelr8to1320 is offline   Reply With Quote
Old 05-17-2011, 04:44 PM   #308
nastorino
Member#: 263570
2007 STI
you can but the iwg is very strective and sometime do to the pressure the flapper can't close all the way. dom3 pretty much needs ewg
Old 05-17-2011, 05:14 PM   #309
RLR257
Member#: 176667
2006 AW WRX Ltd
PPG'd EWG'd & Dom3'd(XTR)
I have a dom3xtr, my boy bought the dom4xtr. not much difference in terms of driveability. If you want more power, do the dom4xtr. I'm going with the Dom5xtr next time around lol.
RLR257 is offline   Reply With Quote
Old 05-17-2011, 07:10 PM   #310
nastorino
Member#: 263570
2007 STI
running a built block or stock? 8cm or 10cm housing? 2.4 or 3"? what are your dyno numbers? when does the turbo spool?
Old 05-17-2011, 08:26 PM   #311
sumfoo1
Member#: 82146
2005 Legacy GT
I'm still trying to figure out is I want a Dom 2.5xtr or Dom 3.0 xtr or maybe even a dom 4.0xtr
sumfoo1 is offline   Reply With Quote
Old 05-17-2011, 08:59 PM   #312
xandi911
Member#: 163991
first turbo i choosed... was small...
now i dont wanna feel i did the wrong choice again...
DOM5
xandi911 is offline   Reply With Quote
Old 05-17-2011, 11:27 PM   #313
RLR257
Member#: 176667
2006 AW WRX Ltd
386/363 21psi, 2.4" inlet, 10cm hotside... 23psi, im sure it could make 400whp. EL headers may put me over 400 too.
on the dyno it seems to spool kind of late, not going to lie, but on the street, spools way sooner, I want to say between 4300-4500. dont think of it as a bolt on turbo, think of it as a 30R. people say the XTR's spool late, they are bolt on... but still big turbos (dom 3, 4 and 5). now if you are going from a vf39 to a dom3xtr, you might be dissappointed at first lol. i know i was at first, because it spools later, but you will have wayyyy more top end and when u put your foot on the floor, the car will MOVE OUT.
if you still are not sure, I believe the HTA green from FP, makes similar numbers and spools a little sooner. i went with blouch because their customer service is supposed to be second to none and blouch has two options 8cm and 10cm (8 will spool sooner)
DOM5
i would say check out some dyno videos. you wont find much on the Dom5. i've been looking for the longest. whats crazy is, the dom5 came out two weeks after i bought my turbo lol. i probably wouldve gotten that. i just asked Blouch about the dom5 last week. they say it should put out close to 450whp.
Old 05-17-2011, 11:47 PM   #314
nastorino
Member#: 263570
2007 STI
i' sure if you got the 3" inlet then you would have seen better numbers as well as tgv deletes. 4300-4500 really isn't too bad imo because i drive around town without boosting, i shift between 2800 and 3200 just for economy and to keep noise and speeds down. essentially a dom3xtr 10cm with proper supporting mods nets you at minimum 375 with the boost turned down low, right? so its safe to assume a 4xtr would net you about 400 at the least amount of psi. of course a stock block might not hold up very long to a 4xtr, even the 3xtr is pushing the stockers limits. the 8cm housing should combat the low rpm lag and start it a little sooner but do you think it will take away from the power all the way to redline? will overall hp/tq suffer drastically due to the small housing? i honestly don't think i'd regret going for the 3xtr, however i just dont want to regret not getting the 4xtr for only 100 more. stupid stock block is holding me back from big numbers. however knock on wood shes an 07 with 17k original miles and both leakdown and compression are perfect, practically no blowby in the tmic and the clutch, tranny and diffs are perfect
Old 05-18-2011, 01:37 AM   #315
rexblake
Member#: 178426
2010 Audi S4
You will lose some top end power with the 8cm housing. I'd say you should be around 350whp at around 20ish psi on almost all dynos (some will be higher) largely depending on the dyno, altitude, and octane used.
I loved my dom three, even on the 2.0L. Was reaching 20psi by 4600rpm (even at altitude). 30psi by 5k. Very very fun car. I'm excited to see how much quicker it will be with the 2.5 that's being built.
I can't imagine going any smaller than the Dom 3. Honestly, if I knew I would end up going 2.5l anyway, I would just got the Dom 4.
rexblake is offline   Reply With Quote
Old 05-18-2011, 08:45 AM   #316
RLR257
Member#: 176667
2006 AW WRX Ltd
I do not think the 8cm will cause ur torque to suffer. if anything u might get a little more than me because of the quicker spool. most people with 2.5L's have hp and tq numbers that are closer. my tune was on the conservative side. if you do E85 or race gas your numbers will naturally be higher... and yea with the 3" inlet and tgv deletes, my numbers may be a little better but I wasnt sure i wanted to do the tgv deletes so i went with the 2.4" inlet.
^ what he said lol... i couldnt imagine doing the 2.5XTR after having the 3.0XTR. I would say Dom3XTR or bigger lol.
Old 05-18-2011, 09:25 AM   #317
sumfoo1
Member#: 82146
2005 Legacy GT
^ do you have the 2.4? or 3" inlet Which would you recommend?
And whose turbo inlet pipe do y'all recommend to keep from having it be sucked shut?
Old 05-18-2011, 09:40 AM   #318
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
3"
Aps, amr and AP are the only hard inlets available iirc. And aps isnt shipping to the US anymore.
Old 05-18-2011, 10:02 AM   #319
RLR257
Member#: 176667
2006 AW WRX Ltd
yea i def recommend a hard inlet. the newer perrin ones are supposed to be pretty good but with a hard inlet u dont have to worry about collapse under high boost at all.
Old 03-25-2012, 02:23 PM   #320
worksti
Member#: 117847
VIDEO VIDEO VIDEO_MPS BUiLT 2005 STi
Event: Dyno Tune
Ambient Temp: 50 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2005 Subaru STi
Tuner: DynoComp
Peak HP at RPM: 469.6whp @ 6,200 rpm
Peak Torque at RPM: 435.8wtq @5,500 rpm
Target Boost: 22.5psi peak
Fuel: 93 Octane + Methanol Injection
Engine/Power Modifications:
- Cobb AccessPort - http://getadomtune.com/
- Blouch - Dom3xtr EWG 10cm / 3"
- Devil's Own - STi Stage 2 - 50/50 Water / Methanol Progressive Injection System
- Kelford - 264 Cams for AVCS Heads
- JE - Custom Pistons w/ Ceramic Crowns and Performance Heads w/ H-Beam Rods (8000rpm Redline)
- ACL - Rod Bearings
- Ferrea - Stainless Valves
- Manley - Springs w/ Ti Retainers
Old 03-27-2012, 02:11 PM   #321
RLR257
Member#: 176667
2006 AW WRX Ltd
^^NICE build and awesome numbers!!
anybody seen any charts of the Dom5.0XTR??
Old 03-28-2012, 11:56 AM   #322
triniscoob
Member#: 143225
2004 JDM Sti
got a quick question for you gurus, on the ej257 with water meth 50/50, Dom 3.0XTR with PE800 injectors with an aggressive tune to around 450whp, would you say to change a WALBRO 255 pump to a bigger pump?
triniscoob is offline   Reply With Quote
Old 04-04-2012, 11:11 AM   #323
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
Not sure I've posted my results,
Stock long block.
Tmic, 1400cc injectors, e85, Dom 3.0 XTR
jnorth85 is offline   Reply With Quote
Old 04-04-2012, 01:31 PM   #324
Juks
Member#: 108163
2005 STI - 10.2@137
2002 WRX - EJ257/60-1/6MT
Stock long block.
[Img]http://i84.photobucket.com/albums/k1/jnorth85/Dynograph.jpg
Juks is online now   Reply With Quote
Old 04-04-2012, 03:50 PM   #325
jnorth85
Member#: 76785
SRP
Originally Posted by Juks
Thanks!
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 11:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 01:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 03:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 08:33 AM
