Old 04-28-2013, 09:06 AM   #451
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by toph View Post
Just dropped my DOM 3.5XT-R 08 STi off at the tuner yesterday. Should have some results for this thread in the near future. Manitou, your praise of this turbo helped me on my decision! Can't wait to get her back.
Here is a link to my build thread. Pretty basic setup. No E85 around me so I'll be running a 93 octane map 95% of the time and also a 110 octane map when I want to have fun
http://forums.nasioc.com/forums/show....php?t=2489220
Looks good! It seems that you should see some nice power and spool from the Dom 3.5xtr with your DAVCS 08. Are you're heads/ cams stock? I did not see a mention about them but maybe I missed it.
Old 04-28-2013, 10:37 AM   #452
toph
Member#: 78640
14 KTM SuperDuke
15 STi CWP | 02 STi Wagon
Heads and cams are stock. I may piece some together over the next year but we'll see how I like the drive ability at this power level first.
toph is online now   Reply With Quote
Old 05-30-2013, 02:56 AM   #453
worksti
Member#: 117847
2005 Rotated DOM3XTR
460whp, 400wtq Pump Tune
- 03_24_12 - New MPS Motor Built, Installed and Dyno Tuned MPS.
Blouch Dom3XTR 10cm 3", Methanol Injection
[email protected], [email protected] - 22.3psi
- 05_29_13 - MPS Dyno Tune, Rotated Dom3XTR, replaced 10cm hotside with .82
MPS fabricated Cold Air Intake, MPS manufactured Rotated Kit (all other variables equal)
[email protected], [email protected] ([email protected]) - 22.8psi
worksti is offline   Reply With Quote
Old 05-30-2013, 12:19 PM   #454
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
For someone who is buying new headers, uppipe, turbo, and downpipe... but looking for a smaller setup, do you still think its worth it to go rotated and what are good 'small' rotated turbo options? I currently have an OG Green, looking to see if I can move to a newer technology to spool sooner and improve the overall powerband. I was looking at a Dom 1.5 XTR as a replacement but am open to suggestions.
Built motor, probably running 93 but been thinking more and more about the logistics of running E85 all the time instead.
TROLL is offline   Reply With Quote
Old 05-30-2013, 01:38 PM   #455
manitou
Member#: 193757
2006 XTI Limited
Probably not with 40-50 lb./ min. turbos but it really depends what you're doing with your car and if you're adding a FMIC and all the parts you mentioned then it's going to be a better build with it rotated and you'll have more options. With Blouch stock location turbos the Dom 2.5xtr is better for the 2.5's and the 1.5xtr is better on the 2.0's. We've seen some Garrett GTX2871's rotated lately with great response and power, look at Proven Power bragging threads for these. Look at my thread, with my Dom 3.5xtr, 58 lb/min. turbo in it's stock location, I'm not giving up much if anything at all regarding response and power.
Old 05-30-2013, 01:48 PM   #456
worksti
Member#: 117847
Moving my Dom3xtr from stock location to rotated mount, turbo spool and throttle response improved beyond expectations.
Old 05-30-2013, 02:26 PM   #457
manitou
Member#: 193757
2006 XTI Limited
What did you change, housings etc. lets see some pics.
Old 05-30-2013, 03:35 PM   #458
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Damn that's sick. I'm sure you feel that extra 100 pounds in torque haha
alcoolaid is offline   Reply With Quote
Old 05-30-2013, 07:24 PM   #459
worksti
Member#: 117847
Event: Dyno Tune
Ambient Temp: 50 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2005 Subaru STi
Tuner: DynoComp
Peak HP at RPM: 486.8whp @ 6,350 rpm
Peak Torque at RPM: [email protected] rpm
Target Boost: 22.8psi
Fuel: 93 Octane + Methanol Injection
Engine/Power Modifications:
- Blouch - Dom3xtr .82 hotside / 3" EWG
- MPS - Rotated Turbo Kit
- Cobb - AccessPort - MPS | Home
- Devil's Own - STi Stage 2 - 50/50 Water / Methanol Progressive Injection System
- Kelford - 264 Cams for AVCS Heads
- JE - Custom Pistons w/ Ceramic Crowns and Performance Heads w/ H-Beam Rods (8000rpm Redline)
- ACL - Rod Bearings
- Ferrea - Stainless Valves
- Manley - Springs w/ Ti Retainers
- MAP - Ultimate H11 Head Stud Kit
- Killer Bee - Oil Pan Kit with Pickup and Windage Tray
- Tial - 44mm EWG
- Agency Power - Equal Length Headers
- MPS - Turbo Inlet / Cold Air Intake
- MPS - Top Feed Fuel Conversion w/ 1000cc Injectors
- MPS - -6 Fuel Line Kit
- Walbro - 255 LPH Fuel Pump
- Group N - Motor Mounts
- Invidia - Q300 Cat-Back Exhaust
- TurboSmart - E-Boost 2 (Stealth Series)
- Perrin - Front Mount Intercooler (Stealth Series)
Old 05-30-2013, 08:19 PM   #460
manitou
Member#: 193757
2006 XTI Limited
That looks like some nice gains for you but it's still inconclusive regrading rotated or stock location of this turbo. Were you tuned full speed density or hybrid MAF/ SD before with the Dom 3?
You must have had an intake restriction other than the inlet tube, maybe the intake was smaller. Didn't you also go to an EWG? That will give you much bigger torque and HP gains.
I made more torque and quicker in the stock location with my 3.5 with less timing I'm sure.
Old 05-31-2013, 01:16 AM   #461
worksti
Member#: 117847
I believe tuning practices were the same on both setups, I was on an EWG in stock location. The only hardware change besides the rotated piping/dp/intake was the swap from a 10cm to .82 hotside.
Old 09-08-2013, 03:26 AM   #462
Isshinryu28
Member#: 336091
2011 wrx
Awd dyno jet
Temp 90 degrees
Dom 3.0 xtr
Perrin fuel rails
1000cc injectors
Injen intake
Spearco top mount
Perrin up pipe
Agency power uel header
Plus all other supporting mods built block and exhaust
407awhp/383trq at 20 psi
This is my break in tune and my limit right now on stock five speed
Isshinryu28 is offline   Reply With Quote
Old 09-09-2013, 12:53 PM   #463
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Holy poop wow break in tune. U may just want to leave it at that. Nice numbers ! Enjoy
krambte79 is offline   Reply With Quote
Old 09-09-2013, 02:11 PM   #464
Isshinryu28
Member#: 336091
Well they said tht tune just scratches surface of this turbo so looking at ppg gears now
Old 09-10-2013, 10:39 PM   #465
manitou
Member#: 193757
2006 XTI Limited
You can get a little bit more out of it on good 93 pump gas but E85 is where it will shine but you may be a bit under fueled.
Old 09-11-2013, 05:47 AM   #466
Isshinryu28
Member#: 336091
Well e85 to far but not 110 octane and running id 1000cc injectors ... Think need bigger
Old 09-11-2013, 05:54 AM   #467
manitou
Member#: 193757
2006 XTI Limited
Not with 110, yes with E85. What pump are you running and have you rewired it?
Old 09-11-2013, 06:09 AM   #468
Isshinryu28
Member#: 336091
Running the forgive spelling deatchwerks 265 pump
Old 09-11-2013, 06:35 AM   #469
manitou
Member#: 193757
2006 XTI Limited
You should install the DW fuel pump rewire kit. It will supply higher voltage to the pump, so it won't work as hard. You'll run out of pump and injector pushing it on E85 but you could still make probably 500ish if you can bump the base pressure up with an adjustable FPR on e85.
Old 09-11-2013, 06:46 AM   #470
Isshinryu28
Member#: 336091
Ok look into sad trying sell Suby now 400 isn't nearly enough power and doubt 450 will be either
Old 09-11-2013, 07:53 PM   #471
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
enough power for what?
Fierysun is offline   Reply With Quote
Old 09-11-2013, 07:56 PM   #472
Isshinryu28
Member#: 336091
Just for personal excitement trust me 400 hp ain't as crazy as sounds lol
Old 09-11-2013, 08:09 PM   #473
Fierysun
Member#: 82745
2005 Subaru STI
Try racing on a track against other drivers.
Making more power is easy, all you need is more money.
Old 09-11-2013, 08:12 PM   #474
Isshinryu28
Member#: 336091
Yea true that lol
Old 10-22-2013, 01:06 AM   #475
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
In real world, what do the Dom 3.0XTR & Dom 4.0XTR really compares to in the FP and GTX series?
Blouch states:
- Dom 3.0XTR equiv to the GTX3076 & FP Red 76HTA (55-57lb/min vs < 60lb/min)
- Dom 3.5XTR equiv to the GTX3576 (58-60lb/min vs 64lb/min)
- Dom 4.0XTR is greater than the GT3582 and less than the FP Black 82HTA
How much do the Dom 4.0 actual flows and the response compared FP Black 82HTA
west_minist is offline   Reply With Quote
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts GTBGUY Normally Aspirated Powertrain 85 05-24-2001 07:33 AM
