#126 |
Vendor
Member#: 193180
Here's the graph for that tuning session:
- Pete@EFI
#127 |
Member#: 150716
nm.. coffee kicked in and brain began working..
#128 |
Member#: 184753
Vehicle:me wantz all black 11' sti sedan |
click the link for the URL.......it has the whole description there
*nevermind theres the graph ^^* |
#129 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Even the 2.5r doesn't hit full boost until after 4k RPM?? Seems like the 10cm hotside is a bit of a miss-match for this turbo.
-- Ed |
#130 |
Member#: 76785
Vehicle:2000 RSTi Coupe SRP |
#131 |
Member#: 26933
BAIC
#132 |
Member#: 97785
NESIC
Vehicle:2005 WRX Stg 2 EFI Logics/CTSUBIE |
Isn't there only one kind of Blouch 2.5 turbo? They are all BB garrett CHRA's and the options between, 8cm-10cm, and 2.5R or 2.5XTR...ok so technically two
![]() Last edited by chlnOrSlpn?; 01-19-2010 at 07:11 PM. |
#133 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
can anyone overnight me a dom4 xtr?
#134 | |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
EFI should overlay: DOM3 from post 51 (normal Dom3 8cm, not XTR) dom2.5r with 10cm & a representative 20G chart. I say this because I think the Dom2.5 (and all variants) are competing more with the 20G than with the Dom3 due to pricing. Power for $ people will look at the Dom 2.5 turbos and come to the conclusion it's not worth the price or they'll move straight to the Dom 3. The people considering the Dom 2.5s are people looking for something that spools like a 20G and outflows it up top (as Ed says, physics is a bi$@#, and this likely isn't happening.) I really don't think people are looking at the DOM2.5 the way they should (pretty much halfway between a 20G and a DOM3) In comparing some specific RPM points with the Dom3 graph in post #51, you can see that the 2.5XTR (or makeshift XTR, whatever it was) that EFI tested is basically just a smaller DOM3, which is pretty much what you expect. Torque is a scoosh left of the DOM3. Peak torque on both is right around 380, 4300ish on the 2.5 and 4400ish on the 3, with the 3 outperforming at >4400 and the 2.5 outperforming at <4300 Calibrated eyeball comparsions RPM - 2.5r w/10cm Torque - 3.0 torque 3000 - 210 - 205 3500 - 280 - 265 4000 - 360 - 355 4500 - 375 - 380 5000 - 350 - 370 5500 - 340 - 355 6000 - 310 - 340 6500 - 305 - 285 7000 - 260 - 275 (*7k is extrapolated) So spool is potentially slightly better with a 2.5r + 10cm hotside (or XT-R if that's what it is) vs. the Dom3. There's nothing that indicates that the 10cm really changes the shape of the curve for better or worse compared with the 8cm DOM3. The curves are pretty close in shape, they're just shifted a bit due to the cold side wheel differences. If anything, I think the 8cm shape is slightly better. Now I can see why the 2.5XTR is delayed. There's not much market for a turbo like this in my opinion. Hopefully EFI's is a frankenstein without the billet wheel and the real 2.5XTR spools better, but I fear this isn't the case. Last edited by Concillian; 01-20-2010 at 05:41 PM. |
#135 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
What fuel are you running on this? Also, what's up with the boost spike then drop off? I am very curious what this turbo can do, especially on a 2.0 liter. However, I am looking for something that can stay at max boost the whole way to redline.
#136 |
Member#: 184753
hey EFI, could you maybe show the log for this car if you can remember it?
07 WRX stock internals Blouch 2.5r APS 525 FMIC APS 70mm intake Deutchwerks (sp) 750 injectors APS hard turbo inlet Grimmspeed BCS Invidia Turbo back Gruppe S headers Labonte Meth injection w/3d controller 75% - 25% meth to water ratio APS Recirc BOV Car was tuned at 22psi. 398Wtq 395 WHP |
#137 |
Member#: 184753
also was that the OG polka pickle?
#138 |
Member#: 143941
NESIC
Vehicle:04 STI JBP 07 LIMITED #602/ 06 BUSA |
#139 |
Member#: 184753
thats an interesting log....11.0-7's all the way thru from 2900rpm on.....impressive.
#140 |
Member#: 178426
I love how quickly the 2.5 spools but it just seems to tank up top. I wonder if it's an issue of stock cams or if the turbo just can't push enough air. How's it feel on the street GDAryder?
#141 | |
Member#: 36033
SCIC
and how is it tanking? the power only drops like 5-10 hp from peak to redline. you're looking too much at the boost instead of the power. i'd much rather have this curve and powerband at 21 psi and 355whp than yours at 29psi and 340whp. isnt ur powerband the one that tanks like 80whp from peak to redline? ![]() its gotta be on pump gas or a conservative tune.....a 49 lb/min turbo will do 26-28 psi peak and hold 23-25 at redline.....this one will probably hold more with the 10cm housing. if i were you i wouldnt upgrade to anything less than the dom3xtr. the 2.5 or 2.5xtr or even the regular dom3 arent gonna add that much power.....30-50whp max........whereas the dom3xtr would add 50-80whp |
#142 |
Member#: 178426
I guess that makes sense for the initial spike. It just seems some better boost control would be in order then, unless it is designed specifically to do that. Which could be, since the tq curve is following the boost curve almost exactly.
Looking at the log link, GDAryder is dropping 20hp by redline, and it's only going to 6700rpm. Now, this could simply be and issue of something else on the car, not necessarily the turbo itself. I agree with the pump gas, that's my guess. But I'd still like to know for sure. Lol, yeah, my turbo does tank. Hence why I would like something more. However, I'd like to keep it spooling as quickly as possible, which is why I like the 2.5 over the 3.0. If I could add another 30-50whp max that's fine, as long as it can hold the whole way to redline. I'd love to have almost a 4k power band! |
#143 |
Member#: 4414
edit: n/m made a mistake.
#144 |
Member#: 184753
#145 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
Got any DOM 4.0 XT-R EJ207 (2.0L) results?
#146 |
Member#: 156340
NWIC
Vehicle:2007 STI WRB |
Well I got my dom3 xtr installed on my car and waiting to get tuned. I will post results when I get them guys.
#147 |
Member#: 122859
Vehicle:08 Subaru STI AW - Silver Fade Stripe |
i love these turbos.. Either Dom4 or Dom3 xtr will be my summer Mod.....I cant wait...
#148 |
Member#: 171920
SCIC
Vehicle:06 sti aspen white |
just got my dom 3 xtr retuned tonight.
the tune was on 91+ 75/25 meth car made 468whp/491wtq at 27psi thats all i know right now,ill post graph tommorrow. was a little more psi than i was looking for,but its not a dd. |
#149 | |
Member#: 14923
Vehicle:2007 Subaru turbo |
At what RPM did you hit 300wtq? Did you do any runs without meth? Full list of mods? Please post the dyno graph. |
#150 |
Member#: 171920
SCIC
here you go.
crappy camera,sorry for bad pics. ![]() |
| Thread Tools | |
| Display Modes | |
| 2.0 + Dom 3.0XT-R + E85 makes 392whp | rexblake | Proven Power Bragging | 36 | 07-20-2010 10:58 PM |
| 370WHP alternative to Dom 3.0XT-R | turboICE | Factory 2.5L Turbo Powertrain | 29 | 06-07-2010 12:04 AM |
| Dom 3.0XT-R and Dom 4.0XT-R Now Available | Blouchturbo | Engine/Power/Exhaust | 17 | 02-04-2010 02:01 AM |
| Good News for those who like the Dual (3,3.5,DTM) and single 4" style exhausts | GTBGUY | Normally Aspirated Powertrain | 85 | 05-24-2001 07:33 AM |
