Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-18-2002, 10:15 AM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default Could a CEL be caused by TurboXS BOV?
My check engine light (CEL) came on today while I was driving. The only real engine mod that I have done is the addition of a TurboXS blow off valve. Had it on there for a while now.
After looking more into it I asume that the CEL only occurs when there is a problem with the emissions out of the car. SO I was thinking that since the BOV makes the engine run richer maybe it is messing up wone of the O2 sensors or something.
What do you guys think? Will it go away if I put the factory BOV back on?
Jasno999 is offline   Reply With Quote
Old 05-18-2002, 10:47 AM   #2
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Please help me with this one. I am worried to drive my car.
Old 05-18-2002, 12:00 PM   #3
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
First off... did you pull the code? So that you know what it is? (It might be something totally un-related to your blow off valve)
If you did pull the code, what was it?
If it was related.... did you put your stock blow off back on, purely for troubleshooting purposes?
Kenneth2000 is offline   Reply With Quote
Old 05-18-2002, 01:08 PM   #4
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Have not pulled a code cause I do not havea scanner. I need one where can I get one?
So I think I am going to put the old BOV back on and then bull the battery tomorrow and see if it comes back. The I guess I have to take it to the dealler.
Old 05-18-2002, 01:58 PM   #5
nmyeti
Member#: 4980
I've never seen a TXS bov cause a CEL. Pull the code and find out what it's saying. I'll bet it is something totally unrelated.
-Nathan
nmyeti is offline   Reply With Quote
Old 05-18-2002, 06:24 PM   #6
Baluchitherium4
Member#: 6480
00' WS6
Red
I had a TurboXS BOV on my car and it caused a CEL. It was the code for "right bank rich". I kept clearing it and the CEL kept coming back. I put the stock BOV back on and have never gotten that code again. It seemed to be much more driveable with the stock BOV also. Needless to say, I sold the BOV and will run the stock one for quite sometime.
Later,
Dale
Baluchitherium4 is offline   Reply With Quote
Old 05-18-2002, 07:02 PM   #7
nmyeti
Member#: 4980
Later,
Dale
Dale,
Thanks for the information.
As a side note, Phil and Mark both run the stock valve. On a WRX a BOV is just a sound mod.
-Nathan
Old 05-19-2002, 01:56 PM   #8
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Yeah I did not pull the code but I think it was the BOV. I have no other mods done to the car. Plus I put the factory BOV back on and pulled the battery. So far no more CELs and it is running great.
Old 05-19-2002, 01:57 PM   #9
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
DO you guys think a 50/50 BOV would clear up this problem? And are the 50/50 BOVs loud?
Old 05-19-2002, 04:21 PM   #10
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Unhappy
I have a TbXS BOV. I've had it for about a month with no problems. I'd hate to give it though, its an awesome sound.
How long have you had it before the CEL?
KwanDDS is offline   Reply With Quote
Old 05-19-2002, 04:30 PM   #11
nmyeti
Member#: 4980
I know of a bunch of totally stock cars that had CELs. It could be anything. You have to pull the code to know for sure.
-Nathan
Old 05-19-2002, 04:50 PM   #12
Subi-fied
Member#: 13483
Put your stock Rec. valve back on and forget about the cool sound, unless you want to buy a stand alone...
Subi-fied is offline   Reply With Quote
Old 05-19-2002, 06:54 PM   #13
Tuning Factory Inc.
Vendor
Member#: 3600
I used a Blitz BOV (full atmospheric and still do). No problems at all on my car or any other car that has installed one. I doubt it is the BOV that is the problem.
Tuning Factory Inc. is offline   Reply With Quote
Old 05-20-2002, 06:24 PM   #14
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
well I put the stock back on and reset the ECU and so far no CELs.
(KNOCK ON wOOD)
Old 05-20-2002, 06:42 PM   #15
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
i've had a TXS type H for over 8k miles with no CELs. maybe some cars are more sensitive than others, i dont know. did you try adjusting the BOV?
eric m. is offline   Reply With Quote
Old 05-21-2002, 07:07 AM   #16
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Adjusting it in what way.
I am not using any washers and the valve remains closed at idle.
Tire wear, can it be caused by an improperly seated spring? wrxkyle Brakes, Steering & Suspension 9 02-23-2009 05:25 PM
Can a misfire be caused by too much fuel being pumped through the injectors? WRXfoME Newbies & FAQs 11 10-17-2007 09:44 AM
Could a CEL be activated by driving with little fuel? Assassin4457 Normally Aspirated Powertrain 4 03-01-2006 07:17 PM
Can a check engine light be caused by bad spark plugs or bad plug wires? pico Newbies & FAQs 7 06-27-2002 04:57 PM
