Old 05-18-2002, 10:36 AM   #1
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Default How do you reset the ECU to get rid of a CEL?
Jasno999 is offline   Reply With Quote
Old 05-18-2002, 10:45 AM   #2
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Please help me.
Old 05-18-2002, 11:13 AM   #3
Judah
Member#: 9320
2002 Subaru WRX
If you want to reset the ECU, just un-hook the negative battery cable and step on the brakes, that drains all the energy out of your car and resets the ECU. But that doesn't mean that it will get rid of a CEL though. If you have a problem, the CEL will come back on.
Judah is offline   Reply With Quote
Old 05-18-2002, 11:43 AM   #4
Obsidian
Member#: 5627
06 WRX STi
This is a tricky matter if you have a UniChip. If you reset the ECU it will "forget" it's current fuel/timing map and go back to the default one. While this will get rid of the CEL the ECU will not learn to accomodate. In other words, with the UniChip misfire CEL's are common, and if you reset the ECU the car won't have a chance to learn to live with the slight delay in the singal (what it interprets as a misfire). The best thing to do is to pull the CEL code via an OBD2 scan tool and then reset the CEL.
--Matt
Obsidian is offline   Reply With Quote
Old 05-18-2002, 12:03 PM   #5
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
--Matt
So your saying that is if i used a OBDII Scanner to pull the code and used it to remove the code, the ECU wont forget its current mappings? Or it will? BTW-I usually use the Snap-On OBDII Scanner to pull codes & remove them. TIA!
Need4Boost is offline   Reply With Quote
Old 05-18-2002, 12:18 PM   #6
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
If you use OBD2 software you can reset the code without losing your other ECU memory. That's what I do whenever I get a CEL. I had a problem with EGT sensor high output when it was cold out. I got the software from that i-club group buy for like $70. Make sure you open the task manager (Ctrl-Alt-Delete) and close any tasks that may tie up your com port. It took me a while to figure that out.
kenshiro is offline   Reply With Quote
Old 05-18-2002, 01:01 PM   #7
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Where can you buy the wscanner? How does it work?
Old 05-19-2002, 01:25 AM   #8
titsataki
Member#: 4402
yup I got mine with the group buy that Jon (in CT) set up. I got all the modules for $140. Actaully just today I got the a misfire CEL that I pulled and reset. first for me and stage 0. Maybe you can get someone local to pull the code for you.
It is actually software that you install on your laptop or computer. They sent you a cable that connects to the serial port of your computer and teh OBDII port in the car (under the steering wheel).
Cheers
Nick
titsataki is offline   Reply With Quote
Old 05-19-2002, 01:29 AM   #9
hotrod
Member#: 14141
2002 Impreza WRX
Default not all CEL lights are equal
Just a note that not all CEL's are the same. There are some non-critical CEL's that will go away on their own after 4 engine restarts if the condition does not exist.
FWIW
Larry
hotrod is offline   Reply With Quote
Old 05-19-2002, 01:54 PM   #10
Jasno999
Member#: 9262
2002 WRX Sedan
Blaze Yellow
Ok.
I still would like to know where I can purchase a scanner.
How do you Reset the ECU Without Disconnecting Battery zman519 Engine Management & Tuning 9 03-06-2007 09:53 PM
How do you reset the ECU? Homemade WRX Engine Management & Tuning 2 04-24-2003 12:52 PM
How do you Reset the ECU BlueByYou Newbies & FAQs 16 03-28-2003 02:01 PM
How do you reset the ECU khai yang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-22-2001 10:21 PM
How do you reset your ECU IcedOutRS Newbies & FAQs 10 03-27-2001 04:41 PM
