Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-02-2009, 11:06 AM   #1
Ti Pit
Member#: 146009
2005 Legacy GT Wagon
Default Door panel extended pins/clips for aftermarket speakers?
Alright, I installed new speakers in the Baja and now I actually have a real improvement on sound quality..
I used special speaker spacers I had made for the Baja but now my speakers sit a bit too high and the body panels wont snap into place around the speaker area.
This causes a bit of rattle when I have a lot of bass playing. I remember back in my WRX days a company used to sell extended clips for door panels with aftermarket speakers. This was to act as a spacer at the same time as a door panel pins. Does anyone know if these are available for the Baja? If not, do you have any suggestions?
Ti Pit is offline   Reply With Quote
Old 12-02-2009, 11:51 AM   #2
speedymatt
Member#: 54910
2003 BAJA Classic
Silver/Silver/& uh Silver
i dont know of any pins like what you are looking for, however the permenent (because you cant return to stock) solutions would be to either make the door panel hole larger to fit around the spacers, or mark the mounting holes and top mount the speakers over the panel.
speedymatt is offline   Reply With Quote
Old 12-03-2009, 03:51 AM   #3
Benhart21
Member#: 149617
http://www.iaperformance.com/product...roducts_id=233
Direct replacement for pins surrounding the door speakers. These allow you to elevate the door panel away from the speaker to help eliminate rattling. These are currently included with every IA adapter set. This is a replacement pack. 10 in total.
Benhart21 is offline   Reply With Quote
Old 12-03-2009, 09:26 AM   #4
speedymatt
Member#: 54910
2003 BAJA Classic
^ sweet! you learn something new everyday
Old 12-03-2009, 09:58 PM   #5
DUDE ITS A BAJA
Member#: 197923
2006 BAJA SPORT
BLACK PEARL
Try just screwing the speakers directly into the holes in the door for the original stock spacers it won't be the perfect fit, but at least the door covers will go on straight again.
DUDE ITS A BAJA is offline   Reply With Quote
Old 12-04-2009, 03:04 PM   #6
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
You know, I ended up just directly tapping into the door panel body. I don't have the stock speakers anymore, and I never had plans to return to stock anyways. All that dynamat in there too - after going through spending $200 to replace all 4 door speakers with damaged outer rubber gaskets due to rubbing against the plastic grills, I'm like forget the brackets and adapters - just mount direct.
Never regretted it. Seals better, sounds a lot tighter and - yeah.
moonzie is offline   Reply With Quote
Old 12-14-2009, 10:53 PM   #7
C 007
Member#: 225990
Chapter/Region: HIIC
2016 WRX STI
WRB Pearl
how do you roll the window down if you mounted the aftermarket speaker directly to the door?
C 007 is offline   Reply With Quote
Old 12-15-2009, 07:25 AM   #8
Ti Pit
Member#: 146009
Originally Posted by Benhart21 View Post
Thank You!
Old 12-15-2009, 02:58 PM   #9
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Gotta find a speaker that's shallow enough to do so. I posted up maximum depths for door speakers a while back ago, but I don't remember. Try search.
Old 12-21-2009, 01:44 PM   #10
DaveInBerlinNJ
Member#: 223188
2006 Baja Sport
Atlantic Blue Pearl
For extended pins... there is a NAPA part that is exactly the same as the IA part, and it's cheaper. Search the Audio section.
edit: I searched for ya... here's the thread:
http://forums.nasioc.com/forums/show...ight=napa+pins
DaveInBerlinNJ is offline   Reply With Quote
Door Panel Extension Pins (6) for 02+ WRX, STi, etc. WRXerist Interior/Dressup/Audio & Security 3 04-01-2010 04:48 PM
URGENT: NEED slide pin clip for brembo's vividwrx13 SWIC Private Classifieds 9 11-25-2008 12:56 PM
WTB interior door panels in mint condition for... WildWolf Private 'Wanted' Classifieds 5 11-06-2004 10:54 AM
JDM STi door panels and gauge cluster for sale cfvwtuner New England Impreza Club Forum -- NESIC 0 11-18-2003 04:49 PM
Using ECM pin-outs for aftermarket gauges MorrisCountyWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-10-2001 10:17 AM
