Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-19-2002, 07:19 PM   #26
dolbnyc1
Member#: 11599
02 wrx
blue
I have the injen, where can I hack it, I hate taking off the tire, just to clean out the air filter. another reason to go
stock box, or shorty style. I gets old after a while.
dolbnyc1 is offline   Reply With Quote
Old 05-19-2002, 07:51 PM   #27
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Originally posted by nmyeti
Carlo,
The bottom line is that unless you replace the hose after the intake, you have not gotten rid of the main flow restriction.
-Nathan
Hey Nathan. Are you guys having to reprogram the unichips if you install the Turbo inlet pipe? Which pipe do you guys recomend? I am still running the stocker and that is probably something I need to think about.
Thanks!
CT
AZScoobie is offline   Reply With Quote
Old 05-19-2002, 10:17 PM   #28
nmyeti
Member#: 4980
Thanks!
CT
CT,
I think we are adding just a bit more fuel to the injen/samco combo. I've only used the samco personally, but the guys at TXS have used the STI unit, and they perfer the samco. They say the STI unit is just a bit too hard to install.
-Nathan
nmyeti is offline   Reply With Quote
Old 05-19-2002, 10:47 PM   #29
energy57
Member#: 18991
2002 Subaru WRX
Platinum Silver
Well damn, It looks like now I'm not getting either... I guess I'm better off sticking with the OEM intake, with the silencer removed... If I got a FMI would I need a CAI or something? Pretty new to the turbo scene
energy57 is offline   Reply With Quote
Old 05-20-2002, 12:20 AM   #30
z3coupe
Member#: 13540
2006 MKV GTI
I hope someone could answer my one question - has anyone just cut open the front section of the tank on the bottom of the resonator? It appears to me that it might give a semi ram-air effect. Thus it would maybe solve a few things. You'd still have the stock airbox, which the original ECU can handle as well as (it seems) most chips can too. Then it would also give cold air almost like a CAI (and more cold than a pod would). And lastly, if the ram effect does indeed work, then you get some air shoved in faster.
z3coupe is offline   Reply With Quote
Old 05-20-2002, 12:23 AM   #31
STEALTH-WRX
Member#: 7822
Multi layer snot green
if you are planning on getting a front mount intercooler, your are going to have to hack up your cold air intake. i would suggest if you know that you are getting a fmic, just to get a blitz, or anything that looks like it because all of the cold air intakes go into the fender. but if you have a fmic your going to have to cut your cold air intake and it will end up look like the blitz anyways.
STEALTH-WRX is offline   Reply With Quote
Old 05-20-2002, 12:27 AM   #32
AZScoobie
Member#: 8785
netcom.com
CT,
-Nathan
Ok... I am going to order one up and give it a shot. I think that stock pipe in my car is a real restriction at this point in the game.
BTW... I ran the stock airbox and intake snorkel/filter until I could simply not make anymore power with it. No matter what I did I could not make more HP. I installed the AEM and saw almost unbelievable gains. Dropping 4 tenths and picking up 5mph at the strip. I used a wideband AF and yes. The AEM did lean me out one half point. I added more fuel and got back to my target AF. I think most people will be just fine with the stock Airbox until the 350+ hp range and then it should be chucked. To bad. I dont like the noise and would rather run a stock system. I wonder if I hack the AEM off if it would help..... I better get that turbo pipe on first.
Thanks for the help.
CT
stock bcs and stock air box/or injen cold air 02 wrx roar Engine/Power/Exhaust 5 09-21-2009 10:15 PM
wtb AEM or Injen short ram intake b0nd18t Private 'Wanted' Classifieds 4 08-12-2008 01:56 PM
Opinions on cold-air intake or no cold-air? gldenchld Tri-State Area Forum 7 11-06-2002 07:55 PM
K&N Typhoon intake or Injen intake Vinnie Normally Aspirated Powertrain 1 02-28-2002 05:23 PM
blitz intake or injen CAI? yellow5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2001 08:39 AM
