Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 12-01-2009, 01:45 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default KW coilovers, Hawk, DBA, H&R in stock
Deals on everything in STOCK-pm for pricing
Racecomp Engineering "Regular Guy" for GR Chassis
Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI. Incorporating the knowledge gained from designing a growing list of suspension and brake performance parts for the true track day and autocross enthusiast, Racecomp Engineering is proud to announce the latest addition to their line up. The Regular Guy Functional Lowering Springs for the 2008+ Subaru Impreza
STI are designed as the ultimate performance spring upgrade for the newly redesigned GR chassis.
Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the extremely limited suspension travel available. Shorter bumpstops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street.
Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a new performance spring has been produced that adds to available bump travel, matches the excellent OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
Continuing the “Regular Guy” theme from previous Racecomp designs, the springs are colored black for a low key look. Coupled with the minimal drop, most people would be hard pressed to find anything different from stock….until the road curves.
Specfications:
320 lb/in front and rear
Shortened bump stops included front and rear (12mm shorter front, 18mm shorter rear)
GD Chassis coilsprings
Yellows-pm for pricing
With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look
Blacks-pm for pricing
Introducing the RCE Regular Guy Springs (RCE Blacks) Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Spring rates are still 10% stiffer then JDM Pinks with an emphasis on the rear rate, so you will still be outpacing just about everything on the track and auto-x course.
Wagons-pm for pricing
Finally, an option exists for Subaru WRX Wagon owners with upgraded struts! Rather then having to choose between spring rates that are too soft, like most wagon specific springs, and a saggy rear end, like most sedan specific springs, Racecomp Engineering is proud to announce an OEM replacement spring for the Subaru WRX Wagon. Designed for use with standard STi inverted struts, Koni Inserts, Tokico D-Spec struts or Ohlins Fixed Perch Replacement struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates.
GTWorx Camberplates
GTWorx are the same as the pics but painted black.
'08 STI, WRX and Legacy front-pm for pricing
'02-07 GD Chassis front and rear-pm for pricing
H&R Coilsprings for '08+ STI
1''drop frt/rr.
I installed a set in an '09 STI and the rideheight looked awesome and it was very comfortable, works well with the stock dampers.
Retail-pm for pricing
KW Suspensions
I have KW coilovers in stock:
KW V3-'05+STI, '08+ STI and WRX
KW V1-'02+WRX and '04 STI
Priced to sell, pm me for pricing
Function:
• Infinitely adjustable within german TUEV-tested adjustment parameters
• Shortened struts for increased spring travel
• Trapezoidal threads for simple height adjustment
• Three different damping technologies for individual adjustment
• Elastomer bump stops with integrated dust boot protection
• Easy to read documentation
• Ready to use comprehensive solutions
• Visually perfect – safe and unique motion dynamics
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
'05+STI and '08 STI and WRX in stock
PM me for special pricing
Whiteline Suspension
Front/rear swaybars
BSF12Z 22mm adj. frt-'03+WRX wagon
BSF30Z-22mm adj. frt- '05+Legacy Turbo
BSF30XZ-24mm adj. frt-'08+WRX
BSF33XZ-24mm adj. frt- '02-07 WRX
BSR33XZ-24mm adj. rr- '02-03 WRX
BSF35XZ-22mm adj. frt- '05+Legacy non-turbo
BSF36XZ 24mm adj. frt.- '04-06 STI
BSR37XZ-24mm adj rr.- '04-06 STI
BSF39Z-22mm adj. frt-'08+STI, '09+ Forester
BSR39Z-22mm adj. rr.-'05+ Legacy
BSF39XZ-24mm adj. frt- '08+ STI, WRX and '09+ Forester
BSR49Z-20mm adj. rr- '08+ STI, WRX and '09+ Forester
BSR49XZ-22mm adj. rr- '08+ STI, WRX and '09+ Forester
Adj. camberplates, Front and rear endlinks, Bushings
KLC26 rear HD endlinks
KLC39-front adj. endlinks
KLC044-rear adj. endlinks
KLC066-rear adj. endlinks
KDT 902 '08+ WRX and STI rear subframe bushings
KDT 903 '08+ WRX and STI rear diff. inserts
KSB 568 Frt strut tower brace '08+STI and WRX
KSB 511 Rr. strut tower brace GD sedan chassis
KSB 599 Frt strut tower brace GD sedan and '03+Wagon
Max-C race upper camberplates-GD and GRB
KCA335 fixed front upper camberplates(adds neg camber and inc. caster)
Front roll center kits
Anti-lift kits-Race and comfort
Rack bushings
Track guys or anybody interested in upgrading their brakes should take advantage of our aggressive pricing on DBA, Performance Friction and Hawk.
DBA 5000-STI and WRX
With a two-piece design and a black Alumalite™ centre hat, DBA's 5000 series slotted rotors complement the looks of a great looking performance car. As with every DBA rotor, the 5000 Series 2-Piece rotor bolts right onto the vehicle with no mechanical changes needed.
All 5000 Series rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring.
TSP is a propriety process specifically developed by DBA for improving the performance of disc brake rotors. Benefits of TSP include:
  • Improved fatigue resistance to minimize surface cracking
  • Reduced rotor fatigue during prolonged heavy braking
  • Quick replacement, minimal ''bedding-in'' of rotors
'04+ STI-dual bolt pattern
The unique Performance Friction slotted rotors use a combination of breakthrough technologies to eliminate noise and enhance rotor life.
-Our special machining process assures the lowest possible runout and thickness variation.
-Our patented slot design gives much higher brake bite.
-Our exclusive high temperature metal alloy resists hot spots and shrugs off the highest heat loading.
-Computer designed vanes maximize cooling air flow and prevent thermal distortion.
-Our two piece floating rotors are race proven in major motorsports venues around the world.
HPS, HP+ and DTC-30 in stock for most applications
PM for brake packages
We are located in Western Canada
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 12-03-2009, 11:41 AM   #2
Member#: 173316
'13 BRZ
All pms replied.
__________________
[/CENTER]
Closed Thread
WTB: KW coilover top hat washer 4 stock tophats JDM Junkyard SCIC Private Classifieds 0 04-14-2010 01:00 AM
DBA rotors and Hawk brake pads in stock dalesalignment&brake VIC Vendor Classifieds 1 06-03-2009 10:50 PM
KW Clubsport Coilovers for 2008 STi In Stock Now! AQ Motorsports SCIC Vendor Classifieds 1 05-01-2008 03:25 PM
DBA, Hawk and Ferodo in Stock!!! Touge Tuning Canada Region Vendor Classifieds 2 04-06-2008 02:54 AM
