Old 05-18-2002, 02:50 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Exclamation I have a camshaft question. Intake vs. exhaust lift
OK, I have always worked on american cars (mostly chevy V8's) and as I was looking around the net, I got some specs off of Cobb's website:
Intake Lift: .375"
Exhaust Lift: .310"
That surprised me. On all the engines I have worked on, The intake and exhaust lift is either the same, or the exhaust lift is larger than the intake. Does anyone know why Subaru decided to use more intake lift than exhaust but still go with more duration (232 vs 236 seat to seat) on the exhaust lobs. IS the info backwards on cobb's site (which I doubt)?
Thanks
Eric
Eric SS is offline   Reply With Quote
Old 05-18-2002, 11:38 PM   #2
Koopa
Member#: 13506
97 impreza OBS
green/slate
Post
to the best of my knowledge the longer exaust duration helps mostly for aditional bost or if your are running nitrous. you tend to loose low end but gaind top end power. and since these are 4 cyl they need to be reved more any ways. you will never got the low end out of a 4 that you can with a 6 or 8 cyl. at least not with out a lott of $$$$ and time....
Koopa is offline   Reply With Quote
Old 05-18-2002, 11:52 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
True that the longer your duration on the exhaust side compared to the intake makes for better nitrous power due to the exhaust scavenging but I seriously doubt that subaru had that in mind when they designed the cams
Eric
Old 05-19-2002, 02:17 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Eric
yes but it ALSo helps tremendously on NA cars(same as nitrous more or less) but on a turbo car you want theoretically a cam with zero valve overlap to prevent reversion...eric i'll e-mail ya some specs when i get a change(i have to do a lil measuring).
jeremy
Old 05-19-2002, 02:25 AM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
jeremy
Thanks Jeremy. I know you know a lot more about high revving japanese 4-cylinder engines than I do. call me naive but I've just never heard of an engine with more intake lift than exhaust lift but I guess 4 bangers do that.
Eric
PS: Haven;t seen you around in a couple days
Old 05-19-2002, 02:47 AM   #6
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Just posting to join thread...I am kinda intrested in hearing the answers. I would think it is because our cars can't breath worth crap but I guess that is the wrong side :/
btw hndatch627 lost his internet...and that would be the only reason you don't see him post
-neal
DoctorNick is offline   Reply With Quote
Old 05-19-2002, 02:49 AM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
-neal
hehe.. what happened???
Eric
Old 05-20-2002, 11:27 AM   #8
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
On a small block chevy the exhaust ports are small and you need a lot of lift and duration to expelled the gasses. My smallblock nova's cam is a lunati w/ .500- .515 lift 256-270 duration @.050. Valve overlap also helps with a scaveging effect and acts like a vacumm to pull more into the cylinder on the intake side. Or something like that. I know the principals but have a hard time explaining it. I guess the subaru 2.5 is more efficient at getting the exhaust out of the cylinders. Aren't the spicey cams more like 410 lift and 224 duration?
Stealthbmbr is offline   Reply With Quote
Old 05-20-2002, 10:10 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Dude, you are running a crap load of duration for such small lift.
Eric
Old 05-21-2002, 03:04 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Eric
it's not that...just compare the size of a stock impreza exhaust port to that of a stock SBC and you'll see a difference, also take into account that 4 valves will flow more then 2.
jeremy
p.s.: AT&T sucks my arse
Old 05-21-2002, 03:14 AM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
jeremy
True. Does this mean that Subaru's intake ports are weak then?
Eric
Old 05-21-2002, 07:43 AM   #12
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Eric
I know, but the motor likes it. It has small intake runners, only 175cc, so a lot of lift insn't needed. Open the valve to .500 and leave it open a long time. My nova runs 10.50's with it.
Old 05-21-2002, 11:41 AM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Eric
not necesarily becuase they move the volume needed for the motor, the weakness falls in the intake plenum design...that's why when you put a CAI on you are sacrficing torque by removing that main air box...the damn plenum is so tiny it doesn't hold enough air to feed the motor instantly....why else would the car have such a massive throttle body. *Shrug*
Jeremy
Old 05-21-2002, 07:56 PM   #14
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
the really interesting thing Eric is that the phase II SOHC motor has 1.75:1 intake rockers and 1.5:1 exhaust.
I'm sure it's in the ports and valve sizes. although the way the second (rear) exhaust port takes a wicked bend, you wouldn't think that exhaust would outflow the intake.
ColinL is offline   Reply With Quote
Old 05-22-2002, 02:14 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i agree 100% just one of those mysteries i guess *shrug*
jeremy
Old 05-22-2002, 05:14 AM   #16
tonytiger
Member#: 3844
1993 Legacy 1.8
I believe the bore also plays a part in this comparation - with the cam shaft profile. When the mixture of air is burnt the pressure inside the cylinder is much higher than the pressure of the atmosphere. There for the force pushing the gasses outside is stronger than the air pushing through the intake valve.
The air drag coefficent plays a part here. The air drag is highly crowing function of velocity. However, when the force pushing is larger the velocity of the material (gas) is always larger than with the smaller force. I hope you understand what I mean.
The pressure is proportional to the volume which is proportional to the bore. Two engines with different bore, but otherwise similar: The bigger bored engine has smaller pressure inside it when the same amount of air/fuel mixture is burnt -> the force is smaller. This isn't quite good example but anyhow.
Ports' design, cam shafts, valves and other factors plays of course a role here. But the above mentioned explains somehow why the exhaust ports don't have to flow as good as the intake ports - the measurements are done with a stabilised pressure.
I'm no expert, but some thoughts...
tony
edit:some typos eliminated
tonytiger is offline   Reply With Quote
Intake Camshaft Question STI8U Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 09-15-2006 02:42 PM
question about moding my stock intake vs. buying the injen CAI SubyRSdriver Normally Aspirated Powertrain 19 09-01-2005 07:03 PM
looking to start a war: intakes vs BOVs vs loud exhausts Tobey General Community 24 08-17-2004 10:36 PM
intake vs. exhaust inchoate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-26-2002 02:31 PM
('93-'01) if you have an intake and exhaust only on AT subie post you 1/4 mile time here SuBaRu-ImPrEzA_RS Impreza Forum 19 05-07-2001 08:46 PM
