Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 05-18-2002, 04:41 PM   #1
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Default Getting new rotors - new pads worth getting too?
I am going to be replacing my stock rotors with some DBA crossed-drilled pretty soon, as my stock ones have been warping since I got the car and the dealer refuses to replace them.
I'm keeping my stock calipers and everything, but is getting some upgraded pads REALLY worth it? I'm on a budget. Will I notice a huge difference in performance with aftermarket pads?
The current pads only have 6500 miles on them.
BeavisNuke is offline   Reply With Quote
Old 05-18-2002, 04:43 PM   #2
mitch808
Member#: 10228
2002 Subaru WRX
Better pads will make more of a difference then the rotors will
mitch808 is offline   Reply With Quote
Old 05-18-2002, 04:51 PM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
are there any good powerfull and more or less long lasting pads?
Hyper is offline   Reply With Quote
Old 05-18-2002, 05:53 PM   #4
romanom
Member#: 16215
2002 WR WRX wagon
romanom is offline   Reply With Quote
Old 05-18-2002, 06:09 PM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
and how much were they?
Old 05-18-2002, 06:41 PM   #6
romanom
Member#: 16215
2002 WR WRX wagon
$80
Oh by the way, that's his recommendation with the stock rotors.
You may want to send him a PM (DBASteve) about the DBA rotors. He's a really nice guy, I'm sure he'll be glad to help.
Old 05-18-2002, 07:06 PM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
thanks a lot!
I think I will take them too
Old 05-18-2002, 07:08 PM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
Pads will make a huge difference w/ stock brakes (ss lines and DOT 4 fluid help too). There are many quality pads out there Mintex, Hawk, Porterfield and the ones I chose- Endless.
From what I've read you will want to run your stock pads on your new rotors for a little while first, then put new pads on. Evidently new pads + new rotors = not good (without one or the other broken in some).
Big Sky
Old 05-19-2002, 04:28 PM   #9
DBAsteve
Member#: 16839
Big Sky
Ditto !
If possible re-dress the surface of the old pad on a bench type disc sander or belt sander to remove any glazing.
Steve
DBAsteve is offline   Reply With Quote
Old 05-19-2002, 07:15 PM   #10
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Heya DBASteve - can you recommend a specific pad that will work best with the MRT/DBA cross drilled rotors?
Old 05-19-2002, 08:07 PM   #11
DBAsteve
Member#: 16839
Axxis Ultimates or Metal masters.
Generally a good semi metallic pad will do.
Carbon metallic or Kevlar pads can be a problem if driven too hard on cross drilled rotors.
I have recently found out that ACDelco are having a pad manufactured by Bendix but with their own compound specs. The sample I saw last week looked like they will be good for high temp street rotors. I've ordered samples to test on a WRX.
I will post some results as soon as I can.
Steve
Old 05-19-2002, 10:46 PM   #12
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
What about the MRT pads? heh
I'm assuming they'll be optimal for the MRT rotors
I definitely wouldn't want the permanent brake dust look from those axxis ones :\
Old 05-19-2002, 11:20 PM   #13
DBAsteve
Member#: 16839
MRT pads........yeh! go for it.
Steve
Replacing rotors and pads... brake lines too? Ryan314 Service & Maintenance 3 08-25-2008 01:11 AM
New pads, new rotors, new noise Clean Brakes, Steering & Suspension 2 05-27-2007 03:27 PM
new rotors, new pads? sha_zapple Brakes, Steering & Suspension 0 09-14-2005 03:26 PM
new rotors, new pads, same time??? couch Brakes, Steering & Suspension 1 10-21-2003 10:05 PM
Getting new rotors what pads now? ferretboy Brakes, Steering & Suspension 0 09-06-2002 10:53 AM
