Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 12-03-2009, 07:28 PM   #1
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Wirelessly posted (BlackBerry8900/5.0.0.348 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/100)
I just had a re-alignment done after changing out the wheel bearings, and asked for -2.5f and -1.5r camber but ended up with -2.0 in the rear.
Is that ok? Any adverse effects?
BeBop86 is offline   Reply With Quote
Old 12-03-2009, 07:44 PM   #2
viper74656
Member#: 84758
'04 WRB WRX
No problems at all with that alignment. Quite nice, actually. Serious autocrossers often go with a lot less camber in the rear (to make the car rotate easier) but you DONT want that on the street. Tire wear should not be affected at all, especially considering many cars are -1.7ish stock.
viper74656 is offline   Reply With Quote
Old 12-03-2009, 07:56 PM   #3
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
So, for Track / AutoX it's not so great?
Old 12-03-2009, 11:18 PM   #4
viper74656
Member#: 84758
'04 WRB WRX
It'll be good for both of those. If this were a DEDICATED autocross only car you could consider getting rear camber plates and playing with the settings to see what you like, but it isn't (I'm guessing).
It's all personally preference anyway really when you are really hammering at around the course or track.
That alignment will be excellent for the street, your car should turn in well and really stick through the corners. Assuming you have good tires, etc....
Old 12-04-2009, 12:14 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
track??? = great
autcx...not so much
track and autox are worlds apart
and that is actually a pretty good alignment...especially if you have mods that have increased positive caster
Old 12-04-2009, 12:16 AM   #6
chazly413
Member#: 151079
2005 2.5RS RBP
motec system exhaust-RIP
Yeah, you don't want the front to have a good bit more camber than the back, like your requested -2.5 and -1.5. The front end gets more grip in this situation and more grip in the front means oversteer.
chazly413 is offline   Reply With Quote
Old 12-04-2009, 12:25 AM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I have found that for 'fast street' use with modded suspension and good UHP/MAX performance tires.....keeping the rear camber between -.5 and -1 of the front is a good range to work within....depending on personal preference
a tail happy street car has proved to be a death trap for many n0000bs that think it is k00 to slide around.....and when they cant catch it...usually at higher speeds......the accident is inevitable
Old 12-04-2009, 01:39 AM   #8
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Originally Posted by Uncle Scotty View Post
track??? = great
autcx...not so much
Yes. If you're doing both track and autox, do a track alignment. A proper autox alignment is unlikely to be very stable at high speeds
Old 12-04-2009, 02:51 PM   #9
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Didn't mean to group autoX and Track together.
I'd like to get an ALK for the front for some more caster and replace the front camber bolts with camber plates.
So for Track it's great, are their better settings? (I understand that alot of this is personal preference)
Also, for AutoX, would you want more camber in the rear?
Old 12-04-2009, 04:01 PM   #10
chazly413
Member#: 151079
2005 2.5RS RBP
In Autocross, someone who likes rotation wants less camber in the rear. Remember, less negative camber means less grip, and less grip in the rear plus more grip in the front means oversteer at the limit.
Old 12-04-2009, 10:55 PM   #11
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
unless you have added aftermarket bolts....this is a foolish thing to do
and before you do anything....keep researching what you are doing and why
BETTER is not a word to use.......different rate...maybe----better....no
VITEK Spark Plugs - All 2.0 and 2.5 Turbo and N/A engines. stav05sti Engine/Power/Exhaust 15 05-21-2010 10:04 PM
Stock 2.0 and 2.5 pistons and offset col5555 Built Motor Discussion 1 07-06-2009 01:24 PM
WTB COBB DP and AP V2 2.0 and 2.5 milkface NWIC Private Classifieds 5 06-15-2007 12:36 PM
I've had 2 percocets and 2 glasses of wine and...... I am b Southern California Impreza Club Forum -- SCIC 5 05-19-2003 12:21 AM
2 18" and 2 16" OK?? adamsrs Brakes, Steering & Suspension 11 11-01-2001 02:48 AM
