Old 12-03-2009, 11:05 PM   #1
Wagonguy98
Member#: 183763
2009 WRX
SSM
Default Door Locking/unlocking problem
So the last few days my 08 OBS's drivers door wont lock or unlock with the keyless entry or with the button inside the car. All the other doors lock and unlock as usual. The door does lock and unlock with the key though. My only thought is that something may have come undone inside the door. I would take it to the dealer but my warranty is up. Any ideas?
Wagonguy98 is offline   Reply With Quote
Old 12-04-2009, 11:24 AM   #2
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
Your warranty is up on a 2yr old car? Call the dealership and talk to them. Even if you buy it used, unless it was a salvaged wreck the warranty is transferable.
TEK112 is offline   Reply With Quote
Old 12-04-2009, 11:50 AM   #3
Wagonguy98
Member#: 183763
2009 WRX
SSM
I hit 36K thats why its up not because of the time.
Old 12-04-2009, 12:07 PM   #4
TEK112
Member#: 218140
I would still give them a call. They are usually nice about that sort of stuff.
It is most likely the fuse or a bad master relay in the driver's door.
Start with the fuse.
Old 12-04-2009, 02:56 PM   #5
Wagonguy98
Member#: 183763
2009 WRX
SSM
checked the fuse and it's fine. I guess ill pull the door panel off and check things out in there.
Old 12-04-2009, 03:15 PM   #6
TEK112
Member#: 218140
From my experience, once the button is depressed, if the actuator is bad it just clicks lightly with no movement or makes a hum sound. Undo the linkage when testing this, because sometimes a seized piece of linkage will mimic a bad relay/actuator.
Old 12-04-2009, 05:36 PM   #7
Wagonguy98
Member#: 183763
2009 WRX
SSM
There is no sound at all... If i flip the little manual lock on the inside it moves as it always did.
Door Lock/Unlock Switch Light Bulb? Stylistics18 Interior & Exterior Modification 5 06-20-2009 10:06 PM
Remote door lock/unlock gthing Car Audio, Video & Security 2 06-28-2008 09:22 AM
Door lock/unlock switch - other years and models fit my 97 Legacy OB? outback_97 Electrical & Lighting 1 10-19-2005 12:48 PM
Lock unlock problem and question 2ndGearFling Car Audio, Video & Security 6 03-22-2005 10:42 PM
Loud thump when locking/unlocking doors!!?? entropy111 Car Audio, Video & Security 1 02-18-2002 10:51 PM
