Old 12-04-2009, 01:07 AM   #1
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Default One of a kind?
Definately few of a kind...
Built a WRX-style header to fit single port heads. Made it from the ground (flanges) up using 2" mandrel bend on the primaries and 2.5" on the collector. Should flow nicely into the 2.5" up-pipe on the car.
It's not a 100% true mandrel bend anymore since I had to really chop and weld two 90's together to make the tight bend from the passenger side to the collector but I doubt the sharp bend will really affect much in terms of flow.
PhilSine is offline   Reply With Quote
Old 12-04-2009, 11:18 AM   #2
cdnsigop
Member#: 226535
1998 Impreza L (RIP)
Nice work! Whats the purpose of it though? To use a stock WRX up pipe, turbo location, and downpipe?
cdnsigop is offline   Reply With Quote
Old 12-04-2009, 01:27 PM   #3
Abest10
Member#: 190962
00 STM RS
04 FXT
Props! I wanted to do this but I ended swapping to ej22t heads and got to use the dual port turbo manifold. If you could produce this you could be a rich man. There is little to no aftermarket single port exhaust manifolds out there esp for a custom turbo application.
Abest10 is offline   Reply With Quote
Old 12-04-2009, 01:28 PM   #4
Abest10
Member#: 190962
00 STM RS
04 FXT
Pretty sure that was his idea since it pretty much is a wrx manifold for a single port application.
Old 12-04-2009, 02:00 PM   #5
blackturbo
Member#: 139365
1995 Impreza L
SEXY! Nice work!
blackturbo is offline   Reply With Quote
Old 12-04-2009, 04:18 PM   #6
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
Good fab work. I assume you plan to use this on your car?
impreza_GC8 is offline   Reply With Quote
Old 12-04-2009, 06:18 PM   #7
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
Oddly enough this is not going on my car. It's what I always wanted to do to my car but had to drive it every day. I also didn't have the turbo crossmember on my car.
A friend of mine has a 2000 2.5RS that he blew his engine and tranny on. It was an automatic. We converted it to manual and I sold him my engine and turbo set-up for cheap along with my JDM WRX ECU and expertise in wiring. I was running 10psi of boost on it with that set-up and the plan remains the same with his. I think it will be faster than my stage 2 tuned WRX.
The best thing is that if he decides to drop in a WRX swap later the car and ECU will already be set for it.
There's a lot of things we are in the process of converting or adding. We have to add the MAF. The TPS plug seems to be different (still unconfirmed). The alternator plug is different. The coil plug is different. The top feed injector plugs were different so I swapped the connectors from the OBS sidefeeds to his harness (the pins easily swap). The coolant temp sensor plug was different. Unfortunately, his old engine has already been sold so we'll have to wait a bit for hime to get his old alt, TPS, and coil back from his friend that bought the engine.
I'll be sure to get him signed up on the boards here and we'll post up the build and pics when were done.
Old 12-04-2009, 07:56 PM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
Nice work Phil, but your friend's conversion sounds... odd.
silentt is offline   Reply With Quote
Old 12-05-2009, 12:59 AM   #9
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
lol
It's definately odd but that's how we roll.
Old 12-05-2009, 09:34 PM   #10
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
thats awesome. very nice work. but how will it sound?
Brother EddieJ. is offline   Reply With Quote
Old 12-06-2009, 12:28 AM   #11
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
Should sound decent. I had one of my NA UEL headers on it before when I had the up-pipe routed past the CV shaft and it had the boxer rumble. I imagine it will be rumbly.
Old 12-06-2009, 01:35 AM   #12
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
This is me being a noob, but what are the the advatages of getting a single port head? I've never seen one of those and thus, have never seen a single tube UEL header. Welds and stuff looks great though!
Layvon is offline   Reply With Quote
Old 12-06-2009, 01:36 AM   #13
likuidphreon
Member#: 218179
2004 STI
Looks very nice, curious to see what the results are!
likuidphreon is offline   Reply With Quote
A Pair of One-of-a-kinds..... f4phantomii Off-Topic 29 09-23-2008 07:49 AM
one of a kind rims for sale... 128d Mid West Subaru Owners Club Forum -- MWSOC 0 04-01-2003 08:38 PM
MY2002 options- one of a kind Chris Jones Interior & Exterior Modification 23 10-24-2002 07:42 AM
So I bent them (yeah the one of a kind Speedlines) djerickd Brakes, Steering & Suspension 8 04-02-2002 01:14 PM
WRX w/ one of a kind 18" Speedline GT-1 "Pinoy edition" hehe djerickd Member's Car Gallery 33 10-17-2001 11:48 AM
