Old 06-03-2003, 05:17 PM   #1
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Exclamation Excellent Turbo Info
***Mods, you may want to sticky this***
OK, this was posted in FFI but I think the info is more than applicable here too. Guru's please add any info you can about EJ25 applicability etc
Originally posted by johnnytran
Stock Turbo 360 CFM at 14.7 PSI
T3 60 trim 400 CFM at 14.7 PSI
IHI VF 23/24 423 CFM at 14.7 PSI
STOCK HYBRID 430 CFM at 14.7 PSI
IHI VF-22 435 CFM at 14.7 PSI
SR 30 435 CFM at 14.7 PSI
T04E 40 trim 460 CFM at 14.7 PSI
Small 16G 505 CFM at 14.7 PSI
Large 16G 550 CFM at 14.7 PSI
SR 40 595 CFM at 14.7 PSI
18G 600 CFM at 14.7 PSI
PE 1820 630 CFM at 14.7 PSI
20G 650 CFM at 14.7 PSI
SR 50 710 CFM at 14.7 PSI
GT-30 725 CFM at 14.7 PSI
60-1 725 CFM at 14.7 PSI
GT-35R 820 CFM at 14.7 PSI
T72 920 CFM at 14.7 PSI
IHI VF 23/24 388 CFM at 18 PSI
T3 60 trim 410 CFM at 20 PSI
IHI VF-22 460 CFM at 18.0 PSI
AVO 320HP 465 CFM at 17.5 PSI
T04E 40 trim 465 CFM at 22 PSI
SR 30 490 CFM at 22 PSI
Small 16G 490 CFM at 22 PSI
Large 16G 520 CFM at 22 PSI
AVO 400HP 580 CFM at 17.5 PSI
PE 1820 600 CFM at 22 PSI
AVO 450HP 650 CFM at 20.0 PSI
SR 40 650 CFM at 22 PSI
20G 695 CFM at 20.0 PSI
AVO 500HP 725 CFM at 23.0 PSI
SR 50 770 CFM at 22 PSI
GT-30 790 CFM at 22 PSI
60-1 800 CFM at 22 PSI
GT-35R 880 CFM at 22 PSI
T72 1000 CFM at 22 PSI
HKS GT2835 Turbo about 400 hp approx 580 CFM, pressure not specified
HKS GT3037 Turbo about 460 hp approx 670 CFM, pressure not specified
HKS GT3040 Turbo about 490 hp approx 710 CFM, pressure not specified
HKS GT3240 Turbo about 570 hp approx 830 CFM, pressure not specified
That should help you decide.
Thanks.
BOY is offline   Reply With Quote
Old 06-03-2003, 05:24 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
added to the FAQ
kastle is offline   Reply With Quote
Old 06-03-2003, 05:25 PM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
danke
Old 06-03-2003, 06:24 PM   #4
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
These are somewhat helpful too, similar to the other chart. Maybe youve all seen them before, maybe not.
========= 658 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.5 (22 PSI) 7000 rpm =======
HKS GT3037 460 hp 670 CFM at 22 PSI
PE 1820 680 CFM at 22 PSI <--- estimated from manufactures rated max power
20G 695 CFM at 20.0 PSI <--- added
HKS GT3040 490 hp 710 CFM at 22 PSI
HKS GT3240 570 hp 830 CFM at 22 PSI
T72 1000 CFM at 22 PSI <--- note you would have to run a 2.0 L engine
at >40 PSI boost to flow this much air
========= 526 CFM max flow for a 2.5 Liter at .85 VE pressure ratio 2.0 (14.7 PSI) 7000 RPM =======
IHI VF 25 395 CFM at 18 PSI <--- estimated
IHI VF 26 400 CFM at 18 PSI <--- estimated
IHI VF 27 420 CFM at 18 PSI <--- estimated
IHI VF 24/28/29 425 CFM at 18 PSI <--- estimated
IHI VF 23 430 CFM at 18 PSI <--- estimated
IHI VF-30 460 CFM at 18.0 PSI <--- estimate based on trap speeds of cars running this turbo
FP STOCK HYBRID 490 CFM at 18.0 PSI
IHI VF-22 490 CFM at 18.0 PSI <--- refigured
ION Spec (stg 0) 500 CFM at 19 PSI <--- per vendor post 12-27-2002
PE1818 515 CFM at 22 PSI <--- estimated from manufactures rated max power
Large 16G 520 CFM at 22 PSI <--- upgraded flow some on review of compressor map
PE 1820 630 CFM at 14.7 PSI <--- estimated from max flow numbers
T72 920 CFM at 14.7 PSI <--- Note you would have to spin a 2.0 L
engine at about 14,000 rpm to flow this much air.
Surb00 is offline   Reply With Quote
Old 06-03-2003, 11:11 PM   #5
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
So you know what the possible horspower is at that PSI? This won't tell you how bad it lags though right? Another questions does the stage 2 and 3 Ludespeed Turbo T3/T4 have as many CFm's as a small 16G DSM? These turbo's look smaller than the T3/T4 but produce lots of power.
cpu77 is offline   Reply With Quote
Old 06-04-2003, 01:57 AM   #6
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
According to the chart I took that from, 1.45 CFM approx. equals 1hp. There are many different sizes of t3/t4's. You would need to find the specs for whatever trim ludespeed uses to see how it compares with a 16g.
Old 06-04-2003, 07:50 AM   #7
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Stage 3 Ludespeed T3/T04B-25 .60 A/R latest kit
Old 02-02-2008, 04:07 PM   #8
Project GC4-RS
Member#: 128264
1997 "GC8wannabe"
Brilliant Red
what about the oem TD041?
Project GC4-RS is offline   Reply With Quote
Old 02-02-2008, 05:53 PM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
wow , 2003 to 2008 ! not bad
IllNastyImpreza is offline   Reply With Quote
Old 05-29-2008, 12:10 PM   #10
hessey07
Member#: 181152
1997 impreza 2.2l
green
yeah a pretty big jump in time
hessey07 is offline   Reply With Quote
Old 05-29-2008, 12:11 PM   #11
hessey07
Member#: 181152
1997 impreza 2.2l
green
just trying to be able to post my own topic so im going to leave a few more replies on here lol
Old 05-29-2008, 12:11 PM   #12
hessey07
Member#: 181152
1997 impreza 2.2l
green
and the last one
Old 05-29-2008, 10:14 PM   #13
2milehi
Member#: 81633
'98 RS-T
Hey, he knows how to use the search button...
2milehi is offline   Reply With Quote
Old 05-30-2008, 03:21 PM   #14
98skuby
Member#: 52632
1998 impreza rs
black
what about using a bigger engine, what would be a good single turbo? like say a 1997 H-6 svx 3.3 motor...?
james
98skuby is offline   Reply With Quote
Old 07-06-2008, 03:09 PM   #15
AVOwagon
Member#: 183927
2003 wrx sedan
The rare sonic yellow
a svx motor with boost is not a good idea! You well make a bit more power for a very short time!
AVOwagon is offline   Reply With Quote
Old 07-06-2008, 03:29 PM   #16
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
not true. the ez22 is an awesome platform for BOOST. TONS more potential with much less boost....its a tranny killer
Old 11-08-2009, 09:23 PM   #17
hotshot2109
Member#: 94785
04 WRX STi
what about the td04hla twin scroll found on the JDM b5 legacy turbo. it has a much larger compressor wheel then the wrx tdo4. i'm curious since I just picked one up for my 02 wrx
hotshot2109 is offline   Reply With Quote
Old 01-31-2010, 09:34 AM   #18
apg39
Member#: 176612
1990 GL wagon
Bump on his query, very keen for some specs.
apg39 is offline   Reply With Quote
excellent turbo info Kastley85891 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-27-2007 07:55 PM
Looking for 2.2 legacy turbo info/pics jakeslick Normally Aspirated Powertrain 2 05-18-2001 10:44 AM
Turbo Info dwendel General Forum Archive 2 01-14-2001 04:32 PM
Any Turbo Info Out There? CRXTLS New England Impreza Club Forum -- NESIC 17 08-03-2000 09:14 PM
