Old 05-17-2010, 04:20 PM   #26
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Originally Posted by Matt Monson View Post
OK. I'll check it out in the morning. And if there's not a way that I can make the 4EAT version fit, I can make a 5EAT version if there's enough demand. It's just a question of whether or not there's actually a market for it, and if people are willing to pay what Modena parts cost to make.
Considering the LegGT and Outback XT only came 5MT on 2005 and then it was all 5EAT till 2009 and there are enough 5EAT sedans in that forum, I think there might be enough interest. Specially since I race my auto and have won two championships with it to use to the "Why in a 5EAT?" argument.
Leonardo is offline   Reply With Quote
Old 05-17-2010, 04:26 PM   #27
climberd
Member#: 183019
05 LGT Stg3 Wgn
Subscribed for interest in getting a 5eat front LSD developed (assuming is is different from the 4eat version already produced. Would like verification of that part as well
climberd is offline   Reply With Quote
Old 05-17-2010, 08:47 PM   #28
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
We ordered in part #12 from the schematic on the other page of this thread; the left side housing of the 5EAT open differential. I'll let you know what we find once we measure it.
Though if climberd wanted to mail me his complete spare 5EAT open differential it would give me even more to work with here. I'd happily pay the shipping on it.
Old 05-18-2010, 01:08 AM   #29
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Doo Eet!!!
Old 05-18-2010, 01:25 AM   #30
climberd
Member#: 183019
05 LGT Stg3 Wgn
PM sent, let's do this
Old 05-20-2010, 01:19 PM   #31
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Awesome!
Old 05-20-2010, 04:32 PM   #32
Matt Monson
Member#: 832
99 2.5RS, '85 911
I got ClimberD's 5EAT differential today. Unfortunately it's not going to be as simple as I had hoped. Based on the information I had put together with Flatirons we were thinking that we were going to have to make a spacer ring to push the ring gear towards the pinion.
However, if you look at the picture it's going to go have to go the other way. The black sharpie mark indicates how much has to come off the top have of our differential to bring it down to the right distance to properly place the ring gear. It's almost exactly 10mm.
So where do we go from here? Well, I think the next step is to see what it's going to run to mill off 10mm of material and figure out if it's more cost effective to just cut a handful of new caps, make a run of new diffs, or mill these down.
The other option would be to mill the backside of that ring gear. If you look at that gear it's ridiculously thick. When they cast it, it appears that they just cast a "spacer" into it and potentially it would be cheaper to shave the gear than the diff. I suspect that it's a softer material than our diff bodies and would cut faster and with a less expensive bit on the lathe.
Old 05-20-2010, 05:12 PM   #33
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
But that being said, wouldn't reducing the mass on the ring gear weaken it given as opposed to the harder material on your diff?
Old 05-20-2010, 05:27 PM   #34
Matt Monson
Member#: 832
99 2.5RS, '85 911
From a truly technical standpoint, yes, a little bit. But the weakness of the gear is more tied to the teeth size than anything else, and that's already got teeny little teeth.
After I posted I thought of something else though. I bet those ring gear bolts don't go much deeper than the 10mm that has to come off and if the gear was cut then new, deeper holes would have to be cut. And that could pose a structural issue to the ring, in addition to the additional cost.
I'm going to get a bid on cutting the hats of our diff. I can't see it adding more than $50-75 to the list price of the diff. And then if they get popular, we just make another batch later on that's the correct spec from the beginning.
Old 05-20-2010, 06:31 PM   #35
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Awesome!
So that would actually be the only difference as of right now?
Old 05-20-2010, 07:35 PM   #36
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
FWIW, I have just put a Modena front TBD into my 03 WRX, and even though I have only put a few miles on it, the difference is definitely noticable. There is definitely a lot more grip up front, and the car does track going around spirited corners much better.
I am going to try to get on the track in the next couple of weeks to push things a bit and see what a difference it makes, but so far I am very happy with it.
The only thing that bares mentioning is that there is a little noise in 1st and 2nd of the diff working that basically sounds like a faint straight-cut gear whine. I dont' mind this at all, but I wanted to at least mention it.
As I get more miles on this, and hopefully some track time, the plan is to do a more extensive write-up. We'll see how time goes
FlatironsTuning.com is offline   Reply With Quote
Old 05-21-2010, 10:05 AM   #37
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
I'm picking up my 4eat Diff from fedex today, i'm so excited. Hopefully i'll have it in the car within the next 2 - 3 weeks and i'll post my thoughts.
g00fy is offline   Reply With Quote
Old 05-21-2010, 03:08 PM   #38
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
hell yes...
Old 05-21-2010, 03:42 PM   #39
Matt Monson
Member#: 832
99 2.5RS, '85 911
And unlike an OBX diff you will not need to take it apart to file off burrs or chamfer edges or any other such tomfoolery.
Old 05-21-2010, 05:54 PM   #40
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
I'm no master mechanic, but your diff seemed to have an excellent finish, and definately felt solid. I'll post more thoughts after it's in the car, but from initial inspection it looks like a top of the line piece of equiptment.
Old 05-22-2010, 02:51 PM   #41
eqt2010
Member#: 89745
2005 Subaru LegacyGT
ABP
Great thread! I'm definitely in for one if it goes production.
eqt2010 is offline   Reply With Quote
Old 05-22-2010, 04:50 PM   #42
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Plus imagine all those Outbacks that could use this to better improve their off-road capabilities.
Old 06-07-2010, 04:00 PM   #43
Matt Monson
Member#: 832
99 2.5RS, '85 911
Hello,
I just wanted to update this thread with a progress report. I've sent a single diff. off to a local machine shop with a sample of the factory 5spd body and am having them shave off the difference in height. Then we'll need to find a local car here in Colorado to install it into (I'm going to lean on Flatirons for some help in that department. ). After that, assuming it works, I'll open these up for sale through our dealers.
Regards,
Matt Monson
Guard Transmission LLC
Old 07-07-2010, 09:42 AM   #44
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
If anyones also been following this thread for updates on the 4eat diff. My car went into the shop yesterday to have my motor swapped and diff installed. I'm hoping to have the car back sometime next week, and i'll post IPT's thoughts on the build quality / fit, and i'll post my thoughts on the feel and performance of the installed unit.
Old 07-07-2010, 10:10 AM   #45
FlatironsTuning.com
Member#: 171650
Keep us posted. I'm definitely curious to see what you think.
Old 07-07-2010, 10:36 AM   #46
Matt Monson
Member#: 832
99 2.5RS, '85 911
Another update, the 5EAT body is at the machine shop and I am just waiting for it to be returned to me. I think Flatironstuning has found a local crashtestdummy for us to put into a car. Once we are sure we've got it all sorted, they'll put them up for sale. Bear with us. We hope to have it to market around August 1 or so.
Old 07-22-2010, 10:03 AM   #47
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Well things are moving alot slower then i expected on my whole engine swap. Sunday the shop got the trans out for me and I dropped it off at IPT monday morning. IPT is finishing up the diff swap today or tomorrow, so then i gotta bring the trans back to the shop that's doing the motor swap and it's just a matter of how soon they can put everything back in.
I'm really hoping this thing is all wrapped up by early next week, I miss having my car, and driving around the work truck with no A/C in this weather sucks. I also can't wait to drive my car with a sweet new front LSD, new motor, and GT35R.
Old 07-22-2010, 10:29 AM   #48
Matt Monson
Member#: 832
99 2.5RS, '85 911
Since this has been bumped I will update as well. The case was hardened more than the machine shop initially assumed and they had to order in some special bits to cut it down. I've been told they'll return it to be before the end of the week, but we'll see...
Old 07-22-2010, 12:22 PM   #49
g00fy
Member#: 82524
2005 35R'd 4eat
Flying Rhombus
Update: Called IPT earlier, my transmission is finished, the diff is officially swapped! Woohoo! Picking it up today after work then dropping it off @ Area1320 to be put back in along with my motor, hopefully it won't be more then a couple days.
Old 07-22-2010, 12:36 PM   #50
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
I can't wait for the 5EAT one!
Gauging Interest on 05-09 LegGT specific Crawford air-oil separator. Leonardo Legacy Forum 0 12-24-2009 04:33 PM
WTB: Any Downpipe that would fit on an 02 WRX w/ stock midpipe JeffyLube SCIC Private Classifieds 3 06-02-2009 01:26 AM
Whatever happened to that tribe of orcs we found in the amazon? skimmilk68 Off-Topic 16 12-24-2008 01:35 AM
WTB wheels that would fit a 05+STI Bumble Bee 03 MWSOC Private Classifieds 0 07-15-2007 11:44 PM
WTB: WRX Din Pocket or any others that would fit paperchasin Private 'Wanted' Classifieds 8 11-06-2004 06:37 PM
