#1 |
Member#: 220877
Vehicle:03 20g hybrid wrx I like that color |
EDIT: dynograph now included.
![]() DYNO: Mustang SHOP: PIA, Tacoma WA FUEL: 92 octane MAX whp: 330@6200rpm Max tq: 330@4300rpm Target Boost: 20.5psi Min. engine whp: 55 Average whp:221 Min. engine tq: 142 Average engine tq: 254 Average AFR: 12 Average boost: 15.6 conservative tune, worried about tranny. MODS: Blouch PnP 20g td05 8cm turbo New EJ257 Shortblock Invidia catless up/downpipe Greddy EVO2 catback exhaust Grimmspeed EBCS Deatshwerks 750cc injectors Walbro 255 fuel pump APS 70mm CAI TurboXs Big TMIC Accesport V2 Protune I have dynograph on adobe pdf file, just not sure how to attach it...help wanted. Since this dyno i have had the midrange increased through a road protune, havent dyno'd it since then.
Last edited by khyree05; 12-12-2009 at 11:44 AM. Reason: forgot the turbo on mod list, fuel, and dynograph |
#2 |
Member#: 220877
feedback wanted
#3 |
Member#: 163648
Vehicle:2002 Wrx,2.5L,HTA86 E85,2007 6mt,No traction |
Sounds good, Graph needed
#4 |
Member#: 220877
Tell me how to post a graph and i will include it. i have it just dont know how to post it. Pdf file. Sorry I'm a noob.
#5 |
Member#: 163648
photobucket maybe?
#6 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
Since you are running pump gas I would fatten it up a little to 11.3 afr if you were one my customers,it should make about the same power but with less chance of det and cooler in cylinder temps.
#7 |
Member#: 59454
NESIC
Vehicle:'10 E92 M3 M-DCT brentuning.com/blog |
read closer: average afr is an average......most likely between closed loop (14.7) and enrichment on boost both included in the pull.
#8 |
Member#: 220877
Hear is my dynograph.
#9 |
Member#: 220877
With a safe tune, stock block, heads, and tranny at 20.5 psi, does anyone see room for improvement???
Feed back wanted. Thanks. |
#10 |
Member#: 153551
Vehicle:2004 WRX psm |
i have the same setup but without the accessport tune, I have an opensource tune.. tuned by cleo at precision tuning I made 335awhp and 339 tq
***you running the stock 2 liter heads? |
#11 | |
Member#: 220877
Yes, stock 2.0l heads. Is your car a hybrid or straight 2.0l? What dyno was yours tuned on? |
#12 |
Member#: 153551
hybrid 2.5l with 2.0l heads
dyno jet dyno... |
#13 |
Member#: 220877
I have stock heads no cams, but the shop said the heads were refreshed during the hybrid build whatever that means.
#14 |
Member#: 163362
NESIC
Vehicle:'97 Battlewagon II Flat black and low-n-slow |
by stock tranny i assume u mean the 5spd correct? As far as im concerned, you and your guys did a great job! Speaking from expierience(3 engines *cough cough*) conservative is always the way to go!
| Thread Tools | |
| Display Modes | |
| td05 18g vs. td05 20g? | stg2wgn | Factory 2.0L Turbo Powertrain | 46 | 04-14-2009 10:00 PM |
| TD05-16G and TD05-20G | Marnix | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 06-10-2004 09:45 PM |
