Old 05-19-2002, 01:17 AM   #1
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Default '98 Rs-t
A few questions:
1. How many '98 RS-T are out there?
2. How many have blown their head gasket?
3. Out of those which are first Gen 2.5 and whish 2nd Gen 2.5?
4. How much boost were you running when it blew?
5.How you fix it? (i.e new gasket, O-Ringed, more torque, etc.etc)?
Thanks,
Efrain
nativo is offline   Reply With Quote
Old 05-23-2002, 06:35 AM   #2
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
I have a NA '98RS with dirty coolant if that counts... 0 lbs boost, Phase 1 block, and I'm crossing my fingers that the subie fairy came last nite and fixed it for me. If that doesn't work, I'm stealing my little sisters car so I'm not stranded while I begin disecting. Not much help, but at least it's a BUMP!
minix42@ is offline   Reply With Quote
Old 05-23-2002, 01:02 PM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default MY98
I had an MY98 running 6psi of boost for 20,000 miles give or take a few hundred. It was a Phase 1. I'm not sure exactly what happened with my car it ran perfect up to and including the day I removed the kit. I put the car completely back to stock and I kept on over heating I couldn't even drive it like more than a mile from the garage. So I got it towed to the dealership and it got a brand new short bolck and heads. I sold the car so that's the end of that story.
Joshua
yebokmj is offline   Reply With Quote
Old 05-23-2002, 07:56 PM   #4
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Not many considering the fact that there weren't that many MY98 RS's made or sold.
I have, as have countless other DOHC 2.5L engine owners.
I would suspect that most MY98 owners ended up with a Phase I block. I have a late build MY98 with a Phase 2 block, though. Didn't seem to make a difference.
I ran anywhere from 5 PSI up to 8 PSI for approximately 19K miles.
5. How you fix it? (i.e new gasket, O-Ringed, more torque, etc.etc)?
Stock gaskets with o-ringed heads. I've put about 20K miles on the car since then without any problems. (Knock on wood. )
Steve
http://www.forcefed4.com
SteveS is offline   Reply With Quote
Old 05-27-2002, 08:41 AM   #5
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Question Which Turbo kit???
For those of you '98RS, specifically DOHC, which turbo kit do you have? Did you have to modified it or was it a direct bolt-on???
Thanks,
Efrain
Old 05-27-2002, 01:57 PM   #6
ej25turbo
Member#: 10963
1998 2.5 RS-TURBO
Rally Blue Pearl
I have a late 98 with phase 2 block. blew the gaskets after 10K with only 5PSI. took it to Rallispec to have them replaced. Stock gaskets. 20K since then with it pushing 8PSI. (Also knocking on wood)
ej25turbo is offline   Reply With Quote
Old 05-27-2002, 03:06 PM   #7
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Question '98 with Ludespeed kit??????
Are there any '98 RS with a Ludespeed Turbo Kit????????????
Thanks,
Efrain
Old 05-28-2002, 10:43 AM   #8
HRE | giulio
Member#: 481
Default Re: Which Turbo kit???
Originally posted by nativo
For those of you '98RS, specifically DOHC...
Was there a different kind?
1) Don't know.
2) I haven't.
3) I forgot which mine is. I think it's II though.
4) Currently 5psi. For about 20k miles now.
5) Hopefully I'll never find out!
g
HRE | giulio is offline   Reply With Quote
Old 06-01-2002, 06:24 PM   #9
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I have a 98 with no kit yet and I blew my head gaskets after 85k. I am ordering a ludespeed kit in the next week or two. stage II.
CUNNINGHAM is offline   Reply With Quote
Old 06-01-2002, 08:42 PM   #10
N/A
Member#: 133
TBA TBA
TBA
So what companies are out there making metal headgaskets for the EJ25? Anybody got an idea of the price range?
N/A is offline   Reply With Quote
Old 06-11-2002, 07:31 AM   #11
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Default '98 RS-t idle
Again this is only for the '98 RS-t:
How have you delt with the fact that when there is a sudden drop in RPM the car is having trouble assuming idle. Otherwise the idle is fine.
Thanks,
Efrain
Old 06-11-2002, 06:48 PM   #12
TR
Member#: 28
1997 M3 Sedan
Default yes, i have that problem too
with the car idling OK, but often dropping past idle and stalling if you are not quick to blip the throttle. I have gotten used to catching it with a slip blip of the throttle, then easing it down into idle.
yes, I also have a 98 RS-T (used to be supercharged and it had the same problem then too, although with Super I assumed it was the drag caused by the super that caused that).
I used to run with a bell FPR, and it was not that - now have larger (370) injectors. didnt matter if there was an AFC, SFC or nothing in there, or the uprated fuel pump.
as for metal headgaskets, dont bother. I had them attempted, and everytime they leaked. I think its something with the way they are sealed. regular headgaskets and machining the heads to match the gaskets perfectly has been the way to go for me.
i also cracked the cylinder wall under turbo boost - 6lbs -SFC, Supra fuel pump, J&S, Bell FPR. That got replaced with a Legacy Turbo shortblock assembly. now running 8.5 lbs, Supra fuel pump, 370 injectors, J&S, S-AFC
TR is offline   Reply With Quote
Old 06-11-2002, 07:32 PM   #13
ej25turbo
Member#: 10963
1998 2.5 RS-TURBO
Rally Blue Pearl
Default Idle drop
From my experience, I've found that if the blow off valve is not adjusted tight enough,It will not shut completely when the car comes back to idle. the Mass air sensor doesn't understand the missing air released by the BOV and can't compensate for it, thus stalling the car! Tighten the adjustment, but don't over do it or the BOV won't open then causing compressor surge. not good!
Old 06-22-2002, 12:47 AM   #14
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Anyone else???
Efrain
Old 06-22-2002, 01:27 AM   #15
STiTuner
Member#: 5778
09 135i
Jet Black
I have a 01 RS but I own most of the Very first turbo kit for the RS made by Ludespeed it was built for wards car but he never got it to work right.. something about the fueling problem and stalling out during shifts. I have all fo the pipes and IC well everything but the GT25 ball bearing turbo that was used that blew seals.
Brad
STiTuner is offline   Reply With Quote
Old 06-22-2002, 05:00 PM   #16
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Mucho Boost, eh???
Call Chui, he might be able to help you as he's the one doing all the "Fine Tunning" on the RS'Ts. If not, ask Elliot!
All head gaskets from the 98- RS are the same so it's no diference!
Remember your car has logged lots of hours in PCA, BMWCA, and Auto-X events. Just new gaskets, and OEM torque should help!
Leo
Leonardo is offline   Reply With Quote
Old 06-23-2002, 12:31 AM   #17
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Muchas Gracias Leo:
What I am talking about is something very unique of '98 RS. A sudden drop in rpm (not necessarily from boost) will make the car die. It has something to do with a valve just bellow the throtle body. Besides that everything else is fine.
Gracias,
Efrain
Old 06-23-2002, 04:07 PM   #18
TR
Member#: 28
1997 M3 Sedan
Default Same
Nativo, that is exactly the same problem I have, it does not seem boost dependent.
not sure what else it could be, although I am looking into the S-AFC Decl settings. anyone have experience with that?
Old 06-23-2002, 07:51 PM   #19
yebokmj
Member#: 2213
Brilliant Red
Default Idle Air Control Valve
The problem your talking about it that of the Idle Air control valve. It doesn't respond quickly enought with a turbo system. If you go with a lightened flywheel you will have even more trouble. I had an HKS S-AFR in my MY98 and it was able to program it not to stall but it would come very close when coming out of anything over 3 grand.
Joshua
Old 06-24-2002, 10:15 AM   #20
giulio
Member#: 16040
1998 Impreza RS
Supercharged
yes yes i have that problem too!!!
i have to massage the throttle at a stop, wait for rpms to settle, for it to not stall.
aw i feel so much better now. i thought it was just MY car!
g
Old 06-24-2002, 06:54 PM   #21
TR
Member#: 28
1997 M3 Sedan
Talking throttle massagers anonymous...
this is starting to sound like a support group for throttle massagers. has anyone cured this issue without a complete ECU replacement? to me thats overkill for this problem.
any ideas?
decl function on SAFC? doing something to the idle control valve?
Old 06-24-2002, 07:34 PM   #22
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Ok! so I suppose my 10Lbs Flywheel is not making matters any better. So far when I know I have to stop I just press on the brakes without touching the clutch which I press at the very last moment and it does not stall.
Basically as I see it, it could be fixed if someone were to mess with voltage of that Idle Air control valve. Any volunteers...I suppose there aren't as many of us to find a cure. But you all can impress me
Later,
Efrain
Old 07-07-2002, 03:44 PM   #23
rotary
Member#: 21014
so would a copper or metal or sti head gasket fix the problem?
And cracked cylinder walls are from detonation right?
rotary is offline   Reply With Quote
Old 07-07-2002, 07:45 PM   #24
Mancini
Member#: 20726
I'd be interested to know if a new ECU would fix the idle problem. I just got my 98 RS a couple months ago and am planning on putting a turbo kit on it this winter. I was possibly planning on replacing the ECU with a Link...anyone have experience with this problem and a Link. Thanks.
Mancini is offline   Reply With Quote
Old 07-10-2002, 01:02 AM   #25
racerwad
Member#: 2564
mancini-
a new ECU such as the link2 should fix the problem because most often the idle problem is caused by transient richness due to BOV's not being vented back into the intake tract. aftermarket ECU's replace the stock MAF with a MAP sensor that needs no special off boost, off throttle compensation. you cc can also run a super loud bling-bling BOV that vents to the atmosphere as well.
efrain-
have you confirmed that your BOV is venting back into the intake tract after the MAF? that should be the problem. good luck.
andy
racerwad is offline   Reply With Quote
WTT: TN 00 RS Six Spokes for '98 RS 5 Spokes durania717 Private 'Wanted' Classifieds 18 12-02-2009 12:04 AM
WTT: TN 00 RS Six Spokes for '98 RS 5 Spokes durania717 Wheels/Tires 10 12-02-2009 12:04 AM
'98 RS 4EAT to 2000 RS 5MT w/ LSD keirnna Subaru Conversions 100 10-22-2009 01:25 AM
'99 RS starter compatable w/ '98 RS? jamesfacts Normally Aspirated Powertrain 5 06-13-2004 01:30 PM
Need info for '98 RS/L front bumper to '01 RS front bumper K Rock Impreza Interior & Exterior Modification 3 02-21-2004 09:49 PM
