Old 05-19-2002, 02:29 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Default What is everyones fuel pressure at idle and what pump/FPR are you using?
I have the Walbro pump, Cartech RRFPR, and stock FPR and my idle pressure is reading 44-49psi on my electric autometer guage. I have my RRFPR screws both turned out all the way and it still rises to about 70psi at 3psi boost. When I was running 9psi, it pegged at WAY past 100psi.
What other setups do people have and how is your WOT and idle fuel pressure. anyoen with cartech/walbro setup having problems keeping your fuelpressure in check? IU'm trying to get a baseline of what good WOT and idle pressures should be. Thanks
Eric
Eric SS is offline   Reply With Quote
Old 05-19-2002, 02:37 AM   #2
Andrew
Member#: 1170
2005 STi
my car likes to run at around 41-44psi idle. its not the happiest at that for idle becuase sometimes it stalls but during wot it allows a couple more PSI of fuel to get delivered and drastically lowers my EGTs (as compared to 36-38psi).
SX FPR
Walboro Fuel pump
Andrew is offline   Reply With Quote
Old 05-19-2002, 02:38 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
One more thing, at that idle pressure (44-49psi) the car idles fine (even with the EJ22T) and when I let it idle for a while and check the plugs, they look fine. No sign of fowling or anything.
Eric
Old 05-19-2002, 11:51 AM   #4
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
The stock fuel regulator attached to the fuel rail doesn't allow enough fuel to be returned to the tank, since the hi-flow pump is sending so much more fuel that is unused at idle.
You can swap it out for one from an SVX ($100 new or find one at a junk yard) and it will take the idle pressure back down to 33-35ish.
That is what I did and now I run 34 at idle and about 65 at WOT, just running 6 psi for now.
I think 100psi of fuel is a bit much. I wonder what the stock lines are rated at...
AaronB is offline   Reply With Quote
Old 05-19-2002, 04:55 PM   #5
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I'm using a Walbro High Pressure pump in my car, a crappy (I think) Vortech RRFPR, and the stock fuel regulator. Right now my car idles at 48-52 psi, depending on how long I drive it. It seems the idle goes lower if I drive it for longer (maybe the pump is getting tired?). I don't really like my idle, as it seems to be too high, though I have not had any problems related to it being a high pressure.
On boost, at full around 4 psi, I see anywhere from 4 BAR to 4.5 BAR of fuel pressure. This converts to 58.8 psi and 66.2 psi. This seems to be fine for on boost fuel, as my EGT's rarely go above 800 C (1472* Farenheit). To be honest, I have no idea which pressure plate I have in my Vortech, as they are not listed on the different plates. I just picked one out of the bag of plates I have and put it in. I think its an 8:1 plate, I don't know.
Graham
Graham is offline   Reply With Quote
Old 05-19-2002, 05:13 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Walbro pump, SVX FPR, running about 32-33psi at idle with the normal rise of 1:1.
Old 05-19-2002, 09:27 PM   #7
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Supra TT fuel pump with stock fuel pressure riser (MY00). Idle pressure is around 48psi and about 50-52 psi under cruise. Under boost it rises one psi for every pound of boost. No idle issues as I'm running the 550cc fuel injectors and Tec-2.
Fitz
Fitz is offline   Reply With Quote
Old 05-19-2002, 09:49 PM   #8
Hojai
Member#: 2190
i am running Walbro fuel pump, Sard fuel press. regulator and RC 550cc injectors and TecII. I set the idle fuel press. at 32psi right now but forgot what the fuel press. when it's on boost. I used to have 42psi before i have the Sard regulator installed.
So, what is the normal fuel press. i should get when the car is on boost? let say at 8psi of boost?
Hojai is offline   Reply With Quote
Old 05-20-2002, 01:03 AM   #9
adamsrs
Member#: 3768
Im running:
-Stock Legacy Turbo Fuel Pump with unknown miles.
-SARD Type R FPR.
-EJ22t block....
And about 35 psi at idle with NO stock FPR (i removed it) And as you know...my car runs GREAT! (NOT!!!!!)
adamsrs
adamsrs is offline   Reply With Quote
Old 05-20-2002, 07:22 AM   #10
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
I beg to differ...
Cold start ran like crap in CO, NM, and TX...
-WaC
Wayne
wac is offline   Reply With Quote
Old 05-20-2002, 03:54 PM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Originally posted by adamsrs
Im running:
-SARD Type R FPR.
-EJ22t block....
adamsrs
So it's OK to remove the stock FPR and run just the RRFPR? I'll try that. THanks
Eric
Old 05-20-2002, 04:38 PM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
NO. You CAN NOT run on just an add-on (Cartech, Bell, Vortech, etc) RRFPR. You need to have a FPR that sets a base pressure for those types of RRFPR's to run off of. You can remove the stock FPR only when you put another FPR in it's place that has the ability to run a base fuel pressure. The add-on regulators just add pressure onto what the existing pressure is in the lines.
Say a FPR is set to run 34psi with the return line back to the tank running 1psi (for example). When you put an add-on RRFPR in line, you set it so that it rises at 1psi at whatever rate. What it in effect does is add pressure between the return of the FPR and the RRFPR. The FPR "adjusts" for the pressure difference by rising the rate in the line going past the injectors into the FPR. The more pressure in the line between the FPR and RRFPR, the higher the pressure in the injector section of line is.
Old 05-20-2002, 05:26 PM   #13
adamsrs
Member#: 3768
But my SARD is fine to run without the stock FPR correct? It is adjustable!
adamsrs
Old 05-20-2002, 05:46 PM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
OK. And an SVX FPR will bolt right on with no modifications and will work right?
Eric
Old 05-20-2002, 06:27 PM   #15
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
The stock FPR on my 1997 Impreza and on Bill Harvey's 1998 2.5RS also seem to have no pressure issues at idle. We can tune the the RRFPR down to 30 psi at idle, and well past 100 psi under boost if needed. Not sure if these will fit the 2000 fuel rail, though, but I presume that since the SVX one does...
-WaC
Wayne
Old 05-20-2002, 07:40 PM   #16
Rovah
Member#: 1375
2003 WRX Rally Car
FWIW, the Vortech SMFU is advertised to be able to replace the stock FPR and be a RRFPR as well. I haven't gotten it to work this way yet, but there's no reason you couldn't.
Cheers! John
Rovah is offline   Reply With Quote
Old 05-30-2002, 12:02 AM   #17
b00st3d
Member#: 9891
2015 RC-F
Ultra White
which walbro pump? gss340, gss341, or gss342?
methadon
b00st3d is offline   Reply With Quote
Old 05-30-2002, 12:22 AM   #18
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
anyone have the part number for the SVX one?
david2z4 is offline   Reply With Quote
Old 05-30-2002, 01:20 AM   #19
adamsrs
Member#: 3768
Dave: My friend Justin (dywstric) is selling a BRAND new one in the Private Classifieds.
adamsrs
Old 05-30-2002, 01:21 AM   #20
Delicious Tuning
Member#: 1990
Talking
34 PSI at idle under vacuum of course. Running a walbro fuel pump (341 or 342 will work, one of them you have to bend the fuel line a little to fit), 440cc injectors and a Link Plus. I have it tuned pretty well now so that it will start right up like a stock RS and idle just as smooth as a stock RS.
Delicious Tuning is offline   Reply With Quote
Old 05-30-2002, 02:32 AM   #21
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
one more question to add to this, for any of you running larger injectors....what sizes and do you throw a P0172(Fuel Metering too Rich) code???
jeremy
Suddenly, Low Fuel Pressure at idle?? IowaRS Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-02-2005 06:32 PM
What is base fuel pressure? Jgrahn555 Normally Aspirated Powertrain 4 03-26-2004 04:17 PM
What is stock fuel pressure? SPeeDSiN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-26-2003 04:52 AM
fuel pressure at idle spiralsmurf Normally Aspirated Powertrain 0 04-07-2002 12:53 PM
Too much fuel pressure at idle? I have the fix.........finally ARG Technical Forum Archive 12 08-15-2000 12:12 AM
