Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-19-2002, 02:45 AM   #1
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Angry What happened here after a nitrous run?
So Im coming home no one around so I flick the switch hit it in 3rd gear only for about 5 seconds. Then I drive down the road everything is fine, I get to a stop light and I hear this hissing sound from inside the engine bay. So I pull over and I pop the hood and its loud(the hissing sound), I look at my intake and its covered the whole line from the nozzle to the managment unit, covered in frost. SO i run turn off the car, and close the bottle about 2 minutes later the hissing stopped. Car runs great and no CEL, nothing.
What I think happened is my selenoid (sp) was stuck a little bit open so it was letting the nitrous flow through. Any ideas why this happened? I gotta check tomorrow morning. I think I was real lucky tonight, I'll let you know what happens. It gotta be it I checked my bottle connections and the main line fro the bottle to the unit and it had no frost on it at all only the line to the nozzle was covered in frost, the seleniod had to be stuck open a little bit.
AndyM is offline   Reply With Quote
Old 05-19-2002, 02:48 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
sometimes the very cold nitrous can freze the solenoid in the open position. you're just lucky it didn;t freeze it wide open. what kit are you running? The only solenoids I ever use anymore are Nitrous Express.
Eric
Eric SS is offline   Reply With Quote
Old 05-19-2002, 02:56 AM   #3
AndyM
Member#: 3219
WR Blue Pearl
I got a ZEX kit #82011. I guess after thinking about it I would get a NX kit. I knew this would happen to me all these other guys running zex 65 shot 75 shot there ok I use a 55 shot and got a big scare. Are you running the NX kit that the Honda’s use? Oh yeah it was really cold tonight record-breaking cold here in Chicago maybe that had to do with it? You think I would be ok to still use the kit for the summer I have sprayed 5 other times before this and it was fine, it ran great? Man this is kinda depressing.
Old 05-19-2002, 03:01 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
You should be OK but I would think about getting another nitrous solenoid.
Yes I use a NX kit for "other sport compact" (that's what the kit is called). NX solenoids carry a lifetime warranty and I have installed many NX kits without incident. I'm just finishing an install on a C5 that is a major 4 day PITA because of all the damn wiring associated with the F.R.E.D. nitrous computer.
Eric
Old 05-19-2002, 03:06 AM   #5
AndyM
Member#: 3219
WR Blue Pearl
do you think the NX seleniod will work with my ZEX kit, I dont know if it would fit back in the purple box. Could you point me in the right direction, I changing' out the seleniod, Im not leavin that damn thing in there! Thanks for the info, BOY!!! was that a scare tonight!
Old 05-19-2002, 03:26 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I'm not sure if they will or not. I would call NX instead of Zex to find out. Good luck
Eric
http://www.nitrousexpress.com
Old 05-19-2002, 10:39 PM   #7
AndyM
Member#: 3219
WR Blue Pearl
can you tell me what model number your useing? Also didnt you have a web page showing the kit you have on your car, I thought I saw a site that did? I could be wrong though...Thanks
Old 05-20-2002, 12:43 AM   #8
Member#: 67
1999 Outlasting
the competition.
chances are that you had a small hunk of crap stick the solenoid ipen. i recomend a inline fiilter close to the solenoid.
ALLWAYS crack the line at the end and let a little bit flush out the lines..
believe me i know what happens to a stuck solenoid on a three stage 800" BBC motor at the strip looks like...
and its not pretty!
tom
Old 05-20-2002, 11:35 AM   #9
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
and its not pretty!
tom
No it is not a pretty sight at all. Fortunetly I caught mine before I cranked it up. Heard it and could see the fumes coming from the hood scoop. Damn soleniods are always screwing up on mine. If it's not the purge it's the damn rubber swelling in the solenoid itself. I got a 350 shot plate on my 532" bbc powered dragster. And my teammate's car has a 2 stage frogger on her 540" bbc. But it IS fun to push that button, good god it's fun.
Stealthbmbr is offline   Reply With Quote
Old 05-20-2002, 05:52 PM   #10
AndyM
Member#: 3219
WR Blue Pearl
do you guys feel that the selenoid is still safe to use, Tom I will do that open the line and Im goin to take apart the purple box and check the selenoids out, thank you I think it should be ok. I did check them out after the frost cleared up, and they were clicking on and off just fine.
Old 05-20-2002, 07:44 PM   #11
daves rs01
Member#: 4455
2001 impreza rs
COBB stage 3
I'v never had a problem like that with mine but like the previous post, install a filter! It sounds like you set it up right as i know people who have not programed the unit correctly and the solenoid stayed open once turned on reguardless of throttle position. Check it!
daves rs01 is offline   Reply With Quote
Here's what happens when you let idiots run you country JRSC13 Political Playground 51 10-11-2009 01:42 PM
What Happens When Marxist Campus Radicals Run The Nation rally_wannabe Political Playground 52 05-24-2009 08:21 AM
What happened to the Ghost town run? habbib88 South West Impreza Club Forum -- SWIC 5 01-13-2007 05:40 PM
Wow what happened here?? SubaruImpreza_power 'Old School' Subaru Forum 5 03-24-2004 11:48 PM
