Old 12-10-2009, 12:15 AM   #1
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
Default how do you guys remove the oil drain tube on the head?
i'm trying to remove this piece connected to the head that connects to the oil drain line from the turbo. it looks like it was pressed on. can anyone give me any pointers or advice? i'm working on ej205 heads.
ownnij is offline   Reply With Quote
Old 12-10-2009, 12:21 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
First, why?
It's pressed in. Grab it with vise grips and twist it out. You'll destroy it pulling it out.
Old 12-10-2009, 12:29 AM   #3
ownnij
Member#: 70459
Originally Posted by 69subaru360 View Post
First, why?
hmmm... i need it for my new motor but didnt think about ordering a new piece. i want to save some downtime by reusing it.
Old 12-10-2009, 09:04 AM   #4
bertune
Member#: 107290
Use a closed wrench or a pipe that fits over it and turn left and right with a pulling force until it comes out, also try getting a screw driver behind it and pry while turning left and right.
bertune is offline   Reply With Quote
Old 12-10-2009, 09:09 AM   #5
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
I don't think it's avail separately to order ?
G/L
sense of nature is offline   Reply With Quote
Old 12-10-2009, 09:57 AM   #6
ownnij
Member#: 70459
haha it might not be but even so it wouldn't be a total FAIL. i could always just tap it for a AN fitting because i'm runnning a Gt series turbo anyways.
Old 12-10-2009, 10:04 AM   #7
ownnij
Member#: 70459
BUT i will try to salvage the piece from my old heads since it won' hurt me if it breaks or not.
Old 12-10-2009, 10:39 AM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I swap mine all the time. I have to as I cut it down and welded an AN fitting to it.
mick_the_ginge is offline   Reply With Quote
Old 12-10-2009, 11:22 AM   #9
ownnij
Member#: 70459
maybe i'm a weak ass bitch but that thing is caked on there. **** wont turn. uhhh i guess my only options are taping it with a fitting or welding a AN fitting. holy crap im pissed.
and you were right sense of nature. you cant buy it.. it's a part of the head LOL FML
Old 12-10-2009, 03:36 PM   #10
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
This is what I was about to suggest.
CKxx is offline   Reply With Quote
Old 12-10-2009, 05:33 PM   #11
ownnij
Member#: 70459
the sad thing is im really kicking my self in the ass because i had that part laying around but thought i didnt need it and threw it away. =(
Old 12-10-2009, 05:35 PM   #12
CKxx
Member#: 33458
93 RX7+09 Forester
Hey, at least you caught it now. I would have tapped mine for a -8 line but I forgot until I already had the motor back in.
Old 12-10-2009, 05:46 PM   #13
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
smack it with a rubber mallet to loosen it up, then use vice grips. be careful to hit it at a strong part and not at the edge as you can dent/bend the opening.
Removed two this way.
brazymstrp is offline   Reply With Quote
Old 12-10-2009, 06:27 PM   #14
bertune
Member#: 107290
Let someone hold the head for you while you turn left and right, it gets easier as you go along, 3/8npt taps into the hole without drillng. I have 3/8npt to -10 fitting there.
Old 12-10-2009, 10:07 PM   #15
ownnij
Member#: 70459
thats some VERY useful information. i'll have to go and buy a tap set... more money damnit
How to Remove Turbo Oil Drain Tube on Head? SEEC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-01-2016 08:12 AM
How do you tell an intern there's, uhm...spotting...on the back of her white skirt? Kaiser Off-Topic 259 06-16-2012 07:38 AM
How to remove the oil drain plug at the very end (before it drops) ImportVenom Service & Maintenance 22 11-12-2003 09:24 PM
Good god! What did you guys do to get the oil drain plug off the first time? DVN428 Newbies & FAQs 27 05-02-2003 03:24 PM
