Old 12-10-2009, 11:38 AM   #1
Somboa
Member#: 156585
2006 WRX LTD Wagon
Default 2010 STI - Has the hesitation/ringland/tune problem been fixed?
Hi all, thinking of picking up a 2010 STI but wanted to do some research first. Has Subaru fixed the hesitation/tune problem in the 2010 STI's or are they still there? I know the 07, 08 (and possibly 09?) STI's had tune and ringland issues.
Would it be best to just get a protune right away (voiding engine related warranty) or just wait it out? I'll be doing a protune eventually anyway.
Somboa is offline   Reply With Quote
Old 12-11-2009, 02:38 PM   #2
Hines
Member#: 116398
08 STI OBP
Tuned By Agile
I would get the protune just to be safe. My 08 had a cobb ots map at 1k miles, had full exhaust and protune at 3k miles, and a stepped up to a big turbo at around 12k miles. Still stock block, still no issues at all and im about 37k miles right now.
~Kris
Hines is offline   Reply With Quote
Old 12-12-2009, 01:21 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
w0w.....the 2010 STi's are available already
Old 12-12-2009, 10:12 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Most of the issues seemed to be with the 08's. In 09 subaru changed many of the engine parts which seemed to help. The tune still sucks on the new ones though.
Old 12-12-2009, 12:44 PM   #5
gungaslow
Member#: 144906
^^they changed engine parts???? what did they change? are you sure?
gungaslow is offline   Reply With Quote
Old 12-12-2009, 01:39 PM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
unless they changed the pistons you're still going to have problems.
Old 12-12-2009, 04:33 PM   #7
climberd
Member#: 183019
05 LGT Stg3 Wgn
if you're worried about voiding your warranty, how is the dealer ever going to know you got tuned?
climberd is offline   Reply With Quote
Old 12-12-2009, 05:23 PM   #8
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
I have a 2010 sti. Everything seems fine so far. The Cobb AP is not available for 2010 models yet, previous units do not work.
ImprezaRSfan! is offline   Reply With Quote
Old 12-13-2009, 01:07 AM   #9
HaPpYfAcE
Member#: 185760
2007 STi ltd 42
UGM
yep, i've heard that they're working on getting the ap-sub-003 working on the 2010s, but it will require more patience than i probably have, lol.
HaPpYfAcE is offline   Reply With Quote
Old 12-13-2009, 05:27 AM   #10
HeroicDose
Member#: 180858
I too have a 2010 STi and I haven't found any issues with mine. As far as I know, there hasn't been any issues with 09's after, what I think, the August 2009 build dates.
IMO it's all in how you break the car in. I've been taking it easy, and doing random romps on her every now and then. I've been messing with the DCCD, the SI Drive, and modifying my driving habits so that I feel there is proper engine/drivetrain load. You take it too easy on her, and potential problems won't show until much much later. You run it like a raped ape, and your problems will surface before 2000 miles. Finding that middle ground is key. The crosshatching on new cylinders fade after something like 50-100 miles. So the piston rings set within that time. Just have to make sure they have the proper tension and the only way to do that is to flux the engine power.
Buy one if you're in love with it, duder. I absolutely LOVE my car.
HeroicDose is offline   Reply With Quote
Old 12-13-2009, 07:22 PM   #11
gungaslow
Member#: 144906
any different internals between 08 and 2010 Sti????????
Old 12-14-2009, 04:57 PM   #12
design1stcode2nd
Member#: 112178
With my 08 I spend half my time in love with it and half hoping it doesn’t blow up. It seems I can’t buy a car I like that doesn’t have some sort of potential ticking bomb issue.
design1stcode2nd is offline   Reply With Quote
Old 12-14-2009, 07:03 PM   #13
dmcmahan12
Member#: 50370
2008 STi
Default I feel your pain!
Originally Posted by design1stcode2nd View Post
With my 08 I spend half my time in love with it and half hoping it doesnít blow up. It seems I canít buy a car I like that doesnít have some sort of potential ticking bomb issue.
I bought my 08 used from a friend with 8000 miles on it. He had the factory ECU reflash from SOA and then put an Invidia DP with a Cobb AP and a Stage 2 map. He went through the proper break in with it so hopefully it will be ok. But it scares me when I see another blown engine thread with 27,000 miles on it
dmcmahan12 is offline   Reply With Quote
Old 12-27-2009, 12:01 PM   #14
vasteve20
Member#: 222212
2010 STI
Aspen White... No really.
Well,
This is comforting, considering I just placed my order for the Special Edition STi.
vasteve20 is offline   Reply With Quote
Old 12-27-2009, 12:16 PM   #15
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
like the other's have said. unless subaru put better pistons in the newer sti's there will be failures.
It's basically not if it will pop it's when.
Danomite is offline   Reply With Quote
Old 12-27-2009, 12:37 PM   #16
vasteve20
Member#: 222212
2010 STI
I'm with you on that... I've done the whole engine building thing (VW/Audi scene), I subscribe to the theory that was posted earlier on in this thread about break in periods. If you drive your new car off the lot with .1 miles on it and start beating the piss out of it immediately, then expect there to be a catostrophic failure within 3k-5k miles. After 500 miles, I'm down with beating **** up. This has been my experience with the vw 1.8t. But who knows, the Subie may be a different animal.
Old 12-27-2009, 01:38 PM   #17
live2ridetahoe
Member#: 31386
2008 WRX Avant
Knowing Subaru, they will change the STI next year... I'm surprised it lasted three model years...
live2ridetahoe is offline   Reply With Quote
Old 12-28-2009, 10:38 AM   #18
ChrispySTi
Member#: 99093
I have a 2010 and it's running great, no issues at all (knock on wood)
ChrispySTi is offline   Reply With Quote
Old 12-28-2009, 12:46 PM   #19
HaPpYfAcE
Member#: 185760
2007 STi ltd 42
UGM
yep, mine has gone ok so far, but i've only got about 1400 miles on it or so. i installed my catback at 997 miles. i'm about to go stage 2...just waiting to pick up the Accessport when i get some extra funds.
Old 12-29-2009, 02:52 PM   #20
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
I love these threads! In order for Subie to have corrected any 'issues' with the WRX/STI, they would first have to admit that there was an issue to be corrected. I haven't seen Subie ever say anything like that.
And to the post a few above this... about Subie changing the internals for 2010... Nope. There were a few stupid OP's that posted a while ago tha they saw something about Subaru released/published about the 2010's having hardened internals. . . That was true, but it was also true in 2008, 2007, 2006, ect ect. Naive people start these rumors.
So long as the pistons are hyper-cast and the OEM map runs lean because of emissions, you're going to get cracked pistons. If its an issue, then keep your car 100% stock to get your car fixed under warranty. If your car is coming out of warranty, then the world is your oyster and you can do whatever you want to your car. Personally, I've got a secret stash of $$ for a short block with forged pistons, just in case.
scramjett is offline   Reply With Quote
Old 12-29-2009, 03:45 PM   #21
vrusso
Member#: 207074
2015 STI
You know you're jealous
Originally Posted by scramjett View Post
........ If your car is coming out of warranty, then the world is your oyster and you can do whatever you want to your car. Personally, I've got a secret stash of $$ for a short block with forged pistons, just in case.
Oh you let the cat out of the bag now the wife is going to see this and find it and spend it before you find out and when your pistons do crack and you go to do a rebuild the money will be "missing" O.o
OP I would not lose to much sleep on this. If I was in your shoes ( which I am not shy a few grand ) then I would look to get a good tune after purchase and fall asleep with a grin on my face knowing what I get to wake up and drive the next morning.
vrusso is offline   Reply With Quote
Old 12-29-2009, 05:20 PM   #22
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
+1. I have over 14k now on my late model 08 and the last 4k have been catless/ 20g. No issues yet for me but I also broke it in right and then tuned it at 900 miles.
Have to watch the oil consumption though. Mine had been sucking alot of oil out the PCV and into the turbo inlet when in boost. The stock air filter was very dirty after only 10k miles of AZ driving. Oil being sucked into the intake can/ will reduce the octane and can be a contributing factor to broken ringlands.
blkscooby is offline   Reply With Quote
Does 2010 STi has larger brakes than 2009 STi? gtr General Community 5 05-02-2010 02:34 PM
Considering a 2010 STI - is the optional BBS wheel/tire package worth it? Kwyjibo Tire & Wheel 19 01-28-2010 04:59 PM
Which aftermarket exhaust for the 05 STI has the least fitment issues? Moshpit552 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2005 10:34 AM
Has the ABS/bumpy pavement issue been eliminated on the new Lagacys? Sonic Yellow 2K3 WRX Warranty Issues & SOA Problems 11 03-16-2005 07:15 PM
Has the Dodge Neon monster truck been posted yet? JMP73 Off-Topic 8 11-19-2003 04:15 PM
