#1 |
Member#: 218185
South East
Vehicle:2002 SubyPAL.com WRX |
Is it possible to run a FMIC system with silicone only? Of course I'll use some metal to connect the silicone straights, bends, etc together.. But I like the light weight properties & thermal resistance silicone offers.. just curious if anyone has done this and if there is any negatives I'm overlooking.
thanks! ![]()
#2 |
Member#: 181617
Vehicle:2004 wrx 6speed/ 330whp/ 300wtq |
Never heard of that, but it would probably be super expensive. One way of getting better cooling than silicone is to get the pipes ceramic coated. Bet that would work better.
The silicone under high boost would probably expand too much Last edited by Brother EddieJ.; 12-10-2009 at 10:43 PM. |
#3 |
Member#: 151079
Vehicle:2005 2.5RS RBP s-techs mad tyte yo |
Shiny metals (i.e. polished and smooth) are pretty good at reflecting heat. The differences would be negligible. Most of the piping isn't going near that hot of stuff, at least when you compare the rest of the engine bay to the turbo.
#4 |
Member#: 166656
NESIC
Vehicle:2002 WRX Wagon Silver |
I actually doubt that a switch to silicone is going to save you much in the way of heat or weight. And the fact that it's not nearly as rigid as metal could mean trouble when you're running high pressure through the tubing...
#5 |
Member#: 97043
TXIC
Vehicle:08 STI - 02 Z28 07 GSXR - 96 CBR |
The hose will probably expand and collapse with boost and vacuum. If you really, really want to do it then be sure to use reinforced hoses.
There are reasons people and manufacturers use hard pipes. |
#6 |
Member#: 218185
South East
Interesting, I was thinking about the expansion and collapsing myself. I like the idea of silicone though, it will be easier to work with and probably cheaper than having custom FMIC piping welded up. I'm going with reversed manifold fyi. I will do some pricing and see what I can come up with, and post it here
#7 |
Member#: 97043
TXIC
Uhhh... aluminum piping is cheap and mandrel bending is too. For elbows I agree a strong reinforced silicone hose will be ok. But my buddy popped his hose at 25psi, after we used t-type hose clamps to keep it from popping off
#8 |
Member#: 218185
South East
Well I added up the parts needed, and this is the manifest to complete silicone FMIC piping for reversed manifold
type qty cost 90 = 7 = $118.93 45 = 4 = $67.88 straight = 1 = $49.99 joiner = 12 = $95.88 TOTAL= $332.68 Didn't bother to figure in the clamps.. it's already too much.. and that's with out shipping. I think I might just piece it together myself, and do like imma_stocker says and just buy aluminum piping and have it mandrel bent to my spec, then have it welded instead of silicone coupled together. |
#9 |
Member#: 53558
NWIC
I loled at the idea.
you'd probably lose a few PSI just to the silicone expanding slightly. ![]() |
#10 |
Member#: 151079
^ He wouldn't lose total PSI once it's done expanding (no leaks hopefully), but the period of time from the silicon pipes at their initial state to full expansion would definitely create some lag, just not sure how noticeable that would be.
#11 | |
Member#: 53558
NWIC
This is the reason that people use aluminum with silicone connectors. |
#12 |
Member#: 150212
SCIC
Vehicle:2006 STI Blue |
You were going to use seven 90's?
#13 |
Member#: 173690
NWIC
Vehicle:2005 Ferd F-TeenThousand |
You'd basically be spending way more money for a far inferior setup...
#14 |
Member#: 99061
NWIC
Vehicle:06 wrx wagon CGM |
Post #13712 of the GC thread in the gallery looks like silicone inter cooler piping by APS. Could PM him.
#15 |
Member#: 64147
Vehicle:1993 STi RA V LTD Green |
Some stock cars come with sylicon piping from the factory (DSMs). Theres a reason people pay to upgrade to metal. Alluminum isn't very heavy, and as previously stated, if you're overly concerned about heat, why not get them ceramic coated, or heat wrap your piping?
| Thread Tools | |
| Display Modes | |
| New e-bay FMIC...not made from Burmese Soda cans. | WRX-ERROR | Factory 2.5L Turbo Powertrain | 4273 | 11-16-2012 06:26 PM |
| FMIC Piping 3" Blue silicone hose couplers - $70 | Demian_w | Engine/Power/Exhaust | 0 | 01-19-2007 10:06 AM |
| Were to get custom fmic pipes made | Shabib67 | Mid Atlantic Impreza Club -- MAIC | 11 | 06-10-2006 03:22 PM |
| HR: i need fmic piping made.. | Dizzuque | Mid Atlantic Impreza Club -- MAIC | 8 | 04-09-2006 09:05 PM |
| New e-bay FMIC...not made from Burmese Soda cans. | Optimus Prime | Factory 2.5L Turbo Powertrain | 546 | 12-16-2005 10:36 AM |
