#1 |
Member#: 232116
SCIC
Vehicle:2003 wrx wagon Silver |
I have an 02 wrx Cobb access port stage2 91oct stromung turbo back exhaust and a short ram intake that I just installed today had a flashing cel but went away after I got off the gas the engine stutters in around 4500 rpms when I get on the gas
#2 |
Member#: 181617
Vehicle:2004 wrx 6speed/ 330whp/ 300wtq |
Uninstall and reinstall. Try it again. It only takes a few minutes. Then report back. The ap should clear all cels. What was then cel code?
What is the specific question you want answered? Any more info? Clean maf sensor are you getting full boost? How many psi and you did flash the ecu with the 91 map? |
#3 |
Member#: 26223
SWIC
Vehicle:2012 GTR - on E85 07 STi twinscroll XTR |
Put the stock intake back on, for starters. If you're not tuned for the intake, you could potentially cause fuel trim problems and cause your car to run poorly. Most cause alot of turbulence at the MAF sensor and cause all types of erratic engine behavior. Even if you are tuned, the short-ram intakes are universally bad (unless you have a properly set up intake heat shield), as they suck in hot underhood air, causing your IAT to be abnormally high (that's bad- your ECU will pull timing when it sees high IAT). There's a reason people refer to short-ram intakes as "hot air intakes".
#4 |
Member#: 135789
SWIC
Vehicle:2005 STi CGM |
if everything else sudjested in this thread checks out fine. you might want to look into replacing your fuel pump. i think you can monitor the air fuel ratio with the accessport and even tho its a narrow band, you will still see it runing around the 14ish area at WOT if the fuel pump was takin a dump. Had this same issue with a buddys car that looked like it was a bad maf since it ran fine after swapping mafs, but the problem returned
| Thread Tools | |
| Display Modes | |
| Need help with VAGCOM, "Not trying to flash, just log" | realitycheck3907 | Open Source Reflashes | 7 | 06-05-2010 09:12 PM |
| NEED HELP!!! Squealing and burning smell | PremierWRX | Transmission (AT/MT) & Driveline | 6 | 06-05-2010 08:57 PM |
| Columbus, OH: Need help with TMIC install.. | taketurns | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 06-04-2010 05:15 PM |
| need help with a/c compressor replacement | sen7inel | Factory 2.5L Turbo Powertrain | 0 | 06-04-2010 08:53 AM |
| Need help!Need flywheel bulletin from SOA.Please help. | RallyeX | General Forum Archive | 3 | 06-01-2000 07:57 AM |
