Notices
Old 05-19-2002, 06:01 PM   #1
Vestas
Member#: 7166
2000 Impreza 2.5RS
Saab Monte Carlo Yellow
Default Subaru ECU wiring, speed signal?
Hey folks,
I just picked up the new Apex'i Rev/Speed Meter (in the new style shape, looks similar to the s-afc). Checking the wiring diagrams I noted that the wiring diagrams they use are exactly the same as the S-AFC ones, meaning WRONG for the GC8 on a MY00 or MY01. So, given that I have some questions.
I'm looking for the wiring diagram for the Subaru ECU on a MY00, however if that's not available (and I don't anyone has the whole diagram online somewhere) does anyone know which pin connector is for the speed signal? I can figure out the RPM as it's the same for the S-AFC and I can find a ground and power signal. I just need the speed signal.
Even better, if anyone has one of these installed, the connections you used would be much appreciated, thanks!
Vestas is offline   Reply With Quote
Old 05-19-2002, 06:18 PM   #2
Vestas
Member#: 7166
2000 Impreza 2.5RS
Found wiring diagrams here: Ravensblades site
I'll post back if it works and then have a good comprehensive write up seeing as I don't think anyone has installed one of these (at least posted how) on here
RPM and Speed Signals on ECU excursionist Electrical & Lighting 0 05-31-2008 01:58 PM
Where is the Speed Signal wire on the ECU harness and Parking Brake switch sssp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-12-2004 08:51 PM
car speed signal wire rbsti Car Audio, Video & Security 6 05-13-2004 09:00 PM
Rpm and Speed signal wires from ECU? Silverevo8owner Electrical & Lighting 6 10-23-2003 11:46 PM
Which wire is speed signal on our stock ECU? wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-31-2003 05:56 PM
