Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-12-2009, 01:02 AM   #1
freakfly23
Member#: 171302
2006 wrx tr
crystal grey metalic
Default rebuilding a rear diff
Does anyone know where to get parts to rebuild a rear diff?
freakfly23 is offline   Reply With Quote
Old 12-12-2009, 02:08 AM   #2
piddster
Member#: 144285
1993 UHEV Legacy
What parts? I went through one and the bearings were fine, so it was a matter of seals from the dealer. If you are trying to rebuild a burnt viscous diff, you are SOL. If it is a roasted R180, the dealer shouldbe able to get the parts, or Rallispec can get them.
piddster is offline   Reply With Quote
Old 12-16-2009, 10:50 PM   #3
freakfly23
Member#: 171302
2006 wrx tr
I am rebuilding an r160 with busted pinion gear and the gear at the end of the main shaft.
Old 12-18-2009, 11:09 PM   #4
freakfly23
Member#: 171302
2006 wrx tr
Im still looking for parts.
Old 12-18-2009, 11:11 PM   #5
prometheum
Member#: 92003
04 bicycle!
with the prices the dealer is going to charge you, you might as well get an aftermarket lsd...or just grab a used one here for $100
prometheum is offline   Reply With Quote
Old 12-19-2009, 12:27 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
junk yard or dealer. Yet expect $400 at the dealer. Good luck at the junk yard as they are not common to find.
I have a r160 with a blown diff. Looking to get rid of it. May also need a bearing or two.
Old 12-19-2009, 09:32 AM   #7
freakfly23
Member#: 171302
2006 wrx tr
So rebuilding is pointless?
Old 12-19-2009, 11:43 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Replacing a broken pinion gear is kinda pointless. Way too many R160's to be had cheaply to justify the cost of a new ring/pinion and then the labor to properly set it up.
Keep the case, bearings and shims or anything else that may still be good.....but pitch the broken pinion and ring gear.
Jay
Old 12-19-2009, 08:57 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Depends what you are doing with it. If it's just a daily driver, find a used one and swap it. Much easier and cheaper. If you are racing, give a shout as we have some treatments that will really make it last longer.
Tony
Turn in Concepts is online now   Reply With Quote
Old 12-20-2009, 01:03 AM   #10
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
If you can't find parts, you can't rebuild it. Step 1 is the EASY part and you can't do that?
Old 12-20-2009, 02:26 AM   #11
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I've got one in a 3.545:1 ratio I'll sell you for probably less than the cost of the parts you would need.
speedyHAM is offline   Reply With Quote
Old 12-20-2009, 01:17 PM   #12
freakfly23
Member#: 171302
2006 wrx tr
How much?
Old 12-20-2009, 02:55 PM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
well I have the parts if you want to make a deal. I could use the space. I will make it worth your while.
Old 12-20-2009, 09:27 PM   #14
freakfly23
Member#: 171302
2006 wrx tr
I was talking to speedy but what parts are good out of your blown diff?
Old 12-20-2009, 11:30 PM   #15
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Everything but the actual diff. Ring and pinion are in good shape.
Old 12-21-2009, 01:09 AM   #16
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Originally Posted by freakfly23 View Post
How much?
Pm'd you. Let me know if you want it.
Rebuilding a rear diff fullerswrx Transmission (AT/MT) & Driveline 0 03-26-2010 09:53 AM
Rear Diff Rebuilds? SpooksRex New England Impreza Club Forum -- NESIC 3 01-29-2010 08:31 PM
FS: R160 3.90 Rear Diff.[Needs Rebuilding] Dena NWIC Private Classifieds 0 08-25-2009 01:04 PM
Rear Diff Rebuild dunk Transmission (AT/MT) & Driveline 3 01-07-2005 08:42 PM
WANTED: WRX Rear Diff and/or parts to rebuild johnnytran Rocky Mountains Impreza Club Forum -- RMIC 2 05-25-2004 10:37 PM
