Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC > NESIC Vendor Classifieds
Old 12-12-2009, 05:12 PM   #1
EFI Logics
Vendor
Vendor Sales Rating: (1)
Member#: 193180
Default EFI Logics Winter Service Specials!
This holiday season, make sure your car is at the top of it's game! Enjoy EFI Logics' winter specials on Subaru servicing. Our technicians are among some of the best in New England, one of which is a 7 year Subaru Master Technician.
With winter fast approaching, EFI Logics knows that your car may be in need of some scheduled maintenance. We have put together some winter pricing to help motivate you to get that much needed work that your car may need. Remember, not only does EFI work on performance oriented vehicles, but we are fully licensed in the state of CT to perform general repair and maintenance!
Please make sure to call ahead to make an appointment at least 1 week in advance.
Notes:
*We will match any reasonable competitor rates*
*These prices are good until March 31st*
*If you do not see your applications below, please Contact Us*
Oil Changes:
Oil change (conventional oil, premium filter) - $35
Oil change (synthetic oil, premium filter) - $45
Spark Plug Replacement:
Spark plug replacement (2.0l Turbo - NGK one-step colder) - $150
Spark plug replacement (2.5l Turbo - NGK one-step colder) - $160
Compression Test: - $125
Compression Test with Leakdown: - $175
Brake Pad and Rotor Replacement:
Front brake pad replacement ('04-'10 STi, Hawk HPS Pads) - $205
Front and rear brake pad replacement ('04-'07 STi, Hawk HPS Pads) - $370
Front and rear brake pad and rotor replacement ('04-'07 STi, Hawk HPS Pads, DBA Street Slotted) - $1060
Front and rear brake pad and rotor replacement ('04-'07 STi, Hawk HPS Pads, DBA 4000 Series Slotted) - $1160
Front brake pad replacement ('02-'05 2.0l WRX, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('02-'05 2.0l WRX, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('02-'05 2.0l WRX, Hawk HPS Pads, DBA Street Slotted) - $920
Front and rear brake pad and rotor replacement ('02-'05 2.0l WRX, Hawk HPS Pads, DBA 4000 Series Slotted) - $1005
Front brake pad replacement ('06-'07 2.5l WRX, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('06-'07 2.5l WRX, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('06-'07 2.5l WRX, Hawk HPS Pads, DBA Street Slotted) - $940
Front and rear brake pad and rotor replacement ('06-'07 2.5l WRX, Hawk HPS Pads, DBA 4000 Series Slotted) - $1030
Front brake pad replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads) - $175
Front and rear brake pad replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads) - $335
Front and rear brake pad and rotor replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads, DBA Street Slotted) - $920
Front and rear brake pad and rotor replacement ('98-'07 2.5RS/2.5i, Hawk HPS Pads, DBA 4000 Series Slotted) - $1005
Clutch Replacement:
Clutch replacement (STi, Exedy OEM Replacement, flywheel resurface) - $875
Clutch replacement (STi, Exedy Stage 1 HD, flywheel resurface) - $1125
Clutch replacement (STi, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1175
Clutch replacement (2.0l WRX, Exedy OEM Replacement, flywheel resurface) - $695
Clutch replacement (2.0l WRX, Exedy Stage 1 HD, flywheel resurface) - $1025
Clutch replacement (2.0l WRX, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1075
Clutch replacement (2.5l WRX, Exedy OEM Replacement, flywheel resurface) - $850
Clutch replacement (2.5l WRX, Exedy Stage 1, flywheel resurface) - $1075
Clutch replacement (2.5l WRX, ACT Heavy Duty w/Street Disc, flywheel resurface) - $1125
Clutch replacement (2.5l LGT, Exedy OEM Replacement, must bring new/used 2.5l WRX flywheel*) - $775
Clutch replacement (2.5l LGT, Exedy Stage 1, must bring new/used 2.5l WRX flywheel*) - $1000
Clutch replacement (2.5l LGT, ACT Heavy Duty w/Street Disc, must bring new/used 2.5l WRX flywheel*) - $1050
Clutch replacement (Non-turbo Impreza/Legacy/Forester, Exedy OEM Replacement, flywheel resurface) - $625
Clutch replacement (Non-turbo Impreza, Exedy Stage 1, flywheel resurface) - $825
Clutch replacement (Non-turbo Impreza, ACT Heavy Duty w/Street Disc, flywheel resurface) - $875
* We can either buy a new one from Subaru or we can also resurface a used one if need be.
Mount and Balance Tires
17" or smaller wheels (set of four) - $85
18" (set of four) - $100
19" or larger wheels - Please Call
Scheduled Maintenance Services:
30,000 mile service - $455 (Save over $150 from dealer price)
- Inspect drive belts
- Oil change (Add $10 for Synthetic Oil)
- Replace engine coolant and inspect system and hoses
- Replace/Clean air filter depending on what intake you have
- Replace brake fluid
- Inspect brakes and system
- Rotate/inspect tires
- Replace transmission and rear differential gear oil
60,000 mile service - $610 (Save over $100 from dealer price)
- Spark plug replacement (stock or one step colder)
- Replace fuel filter (For cars with fuel filter in engine bay)
90,000 mile service - $455 (Save over $150 from dealer price)
105,000 mile service - $600 (Save over $200 from dealer price)
- Replace timing belt - $120
- Replace drive belts - $32
Add in the following for another $275!
- Replace water pump
- Replace Cam seals
- Replace AVCS Fittings (in AVCS equiped vehicles)
120,000 mile service - $610 (Save over $100 from dealer price)
- Replace fuel filter (all cars)
Happy Holidays from all of us at EFI Logics!
EFI Logics.com
8 Sympaug Park Road
Bethel, CT 06801
Phone: 203.748.1115
Email us through our website
EFI Logics.com / Myspace / Facebook /Our Packed Interactive Dyno Database
Subaru / Porsche / Mitsubishi / Ford / GM
__________________
[SIZE=1]
[/SIZE][SIZE=1] - Customer rated #1 shop on [I][B]
[/B][/I]
[B][I][COLOR="Black"]Cobb Tuning Solutions for:[/COLOR][/I][/B] [b][COLOR=Red]R35 GT-R[/COLOR][/B] / [B]Subaru[/B] / [B]Mitsubishi[/B] / [B]Nissan[/B] / [B]Infiniti[/B] / [B]Mazda[/B]
[B][I][COLOR=Blue]Subaru Engine Packages from street to track[/color][/I][/B]
[/size]
EFI Logics is offline   Reply With Quote
Old 12-14-2009, 09:42 AM   #2
EFI Logics
Vendor
Member#: 193180
All PM's replied to, please do not hesitate to contact us if you have any questions.
__________________
[SIZE=1]
[/B][/I]
[/size]
Old 12-16-2009, 11:26 AM   #3
EFI Logics
Vendor
Member#: 193180
Big bump for some great success for this sale.
__________________
[SIZE=1]
[/B][/I]
[/size]
Old 12-19-2009, 09:39 AM   #4
JNA Performance
Vendor Sales Rating: (82)
Member#: 184966
---- Visit Us @ ----
www.jnaperformance.com
BuMp for GREAT shop-CLEAN work
Alan
-JNA Performance-
__________________
LET US MATCH OR BEAT ANY PUBLIC ADVERTISED PRICE. PM US TODAY.
paypal:
Check Us Out On FACEBOOK
Customer Review Thread:
JNA Performance is offline   Reply With Quote
Old 01-12-2010, 04:46 PM   #5
EFI Logics
Vendor
Member#: 193180
Bump! Lots of people have already taken advantage!
__________________
[SIZE=1]
[/B][/I]
[/size]
EFI Logics Winter Tuning Special! EFI Logics Tri-State Area Vendor Classifieds 7 01-18-2010 09:14 AM
EFI Logics Winter Tuning Special! EFI Logics Vendor 'General Sale' Forum 1 01-12-2010 04:48 PM
EFI Logics Winter Service SPECIALS! EFI Logics Tri-State Area Vendor Classifieds 4 01-12-2010 04:48 PM
EFI Logics Winter Tuning Special! EFI Logics NESIC Vendor Classifieds 5 01-12-2010 04:45 PM
Agile Auto Winter Service Specials Agile Auto MAIC Vendor Classifieds 26 03-26-2009 03:50 PM
