Old 12-12-2009, 07:49 PM   #1
Wrx KidD
Member#: 123531
.. Kwinskii <3
Default Rethinking my suspension...Your thoughts please.
All-
So as of right now on my 2004 wrx I have Megan Racing Coilovers "street". It is a great ride, but it makes way to much noise in the front and rear. Just the noise is annoying and enough to make a switch. Now today I just rode in my friends ride and he had the Megan Racing "track" edition coilovers. They rode just like mine but it was so quite.
Can someone tell me the differences between the two produces or recommend a better produce at the same price. Or could someone tell me why my front coilovers make so much noise. It sounds like every bump I hit the coilover is pushing up the metal of my car and its popping. Please help!
Thanks in advance.
Tim
Summary: Megan Coilovers make to much noise. Advise or recommend new product.
Wrx KidD is offline   Reply With Quote
Old 12-12-2009, 07:59 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
masterkwan's rce t2 coilovers with vorshlag camber plates and grp N rear tophats
/thread
Old 12-12-2009, 10:05 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
so...what EXACTLY is making the noise????
Old 12-13-2009, 12:24 AM   #4
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
Coil bind from being too low perhaps ? I am not saying you are too low, it's just a thought that comes to mind whenever I hear "megan" "coilover" and "racing" in the same sentence/paragraph. I'm just saying.
I know, the ride height adjustment is independent of the preload right ? Check the coils and see if there is evidence of bind, if there's not then that is one thing you can cross off the list. Personally I'd look into spending at least enough money to get a decent setup, but then I tend to research, wait, save, and get the right **** the first time. I am not immune from spending money to go the wrong direction, it just doesn't happen very often.
UFOpilot is offline   Reply With Quote
Old 12-13-2009, 12:32 AM   #5
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
how long have you had the coilovers? have they always been noisy? when does it make noise?
your friend probably just got "lucky" with a better quality set of camber plates....the pillowballs on Megan's are known to be a little iffy or hit or miss on quality. they also can wear out fairly quick.
that's my first guess. the only real difference between track and street megans as far as i know is the springs themselves....definitely not construction, and maybe not valving.
AndyRoo is offline   Reply With Quote
Old 12-13-2009, 01:02 AM   #6
Wrx KidD
Member#: 123531
.. Kwinskii <3
I have had the coilovers on for a year now. I think for sure it is the camber plates in the front. It literally sounds like there is space in between the coilover camber plates and my car, so every time I hit a bump you hear a metal on metal sound. Almost as if the coilover is bouncing up and down. But the bolts have been tightened all the way down. I even unbolted the two front and reinstalled them.
Perhaps I didn't save for the top quality parts, but I figured for 900 they would be decent.
-Tim
Old 12-13-2009, 01:28 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
-Tim
d0000000000000d
$ 1900 would be 'decent'
Old 12-13-2009, 02:16 AM   #8
Wrx KidD
Member#: 123531
.. Kwinskii <3
I dont know one person on this forum who would not agree 1900 would be a good figure to start with, but sadly not everyone (including me) has that money.
Old 12-13-2009, 02:34 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
well....it seems your 900 was wasted......so you were half way there already
Old 12-13-2009, 10:20 AM   #10
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
A set of Konis, Dspecs, or something along those lines with a good spring would have not only been of better quality, but it would have handled better, and you wouldn't be having this issue right now. Of course it would have cost you more than $900, but there is no way you are getting anything decent for < 1k ever. Perhaps used, but then still......
Why not scour the FS section and find a good deal on a used setup that can do better than the megan's until you can scrape together the $ for a "real" setup ?
Old 12-13-2009, 10:44 AM   #11
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
You say you tightened everything - did you tighten the top nut?
Also, if you want coilovers 1900 is not "a nice place to start" - its damn near the only place to start. If you dont have it, youre out of luck.
sniper1rfa is offline   Reply With Quote
Old 12-13-2009, 10:25 PM   #12
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
-Tim
You missed one of Andy's questions - has it always done this?
Old 12-13-2009, 10:29 PM   #13
jamal
Member#: 71875
98 Legacy GT
my wheels fit
the top spherical bearings themselves are probably toast. Spherical bearings aren't really meant to take axial loads in the first place, so when you combine that with the cheapest one they could find (and they're probably too small) they wear out quickly.
Good tops generally have a nut insert so they can use a larger bearing.
jamal is online now   Reply With Quote
Old 12-13-2009, 10:55 PM   #14
Wrx KidD
Member#: 123531
.. Kwinskii <3
No it started up about 3 months ago. Can this do any harm to my car? Or will it just create this annoying sound until I change them out?
Old 12-14-2009, 07:36 AM   #15
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Well, if you leave it long enough the strut could potentially punch through the tophat, and that would definitely damage your car.
Old 12-14-2009, 01:35 PM   #16
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
You need to check:
-Top locking nut. If it is loose, they will make mucho noise.
-Spring preload, if they are loose, they will make mucho noise. You want about 3-4mm of preload on the springs.
-Pillowball bearing, if it has worn down or there is significant debris in there, it will make Muy Mucho noise.
While you're in there make sure your swaybars and endlinks are tight as well.
9 times out of 10 it's one of those 3 major things that are making nosie on those types of coilovers.
Hope that helps.
Circuit Motorsports is offline   Reply With Quote
Porting STI heads?? Your thoughts please NORCAL STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-18-2004 10:36 AM
Your thoughts please Drowner Interior & Exterior Modification 14 02-17-2004 08:09 PM
Your thoughts please nunyo South East Region Forum 12 07-16-2003 06:34 AM
Hi Luke: once and for all, lets decide what tires I'm buying. Your thoughts please. Edvig Tire & Wheel 6 06-04-2003 02:50 PM
Your Thoughts Please christoph1371 Bay Area Impreza Club Forum -- BAIC 21 05-11-2002 05:03 PM
