Old 05-19-2002, 08:24 PM   #1
MattDell
Member#: 16803
Default The Benefits of a Boxer Engine?
I couldn't think of a better place to put this, so mods move it to a better place if you think so.
Anyways, I'm just wondering what the benefits are of having a boxer engine are and why.
MattDell is offline   Reply With Quote
Old 05-19-2002, 08:37 PM   #2
Blindeye_03
Member#: 4418
2016 Focus ST
Compared to what?
According to subaru, its got lower center of gravity, a whole hell alot of torque for a 4banger (at very low rpms)... Im sure there are more things that are good about it...Why else do porches come with flat 6 engines?? .
-justin
Blindeye_03 is offline   Reply With Quote
Old 05-19-2002, 09:38 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
The lower center of gravity helps with handling, and a boxer engine is inherently balanced because the pistons act as counterweights for one another so it is a very smooth running engine.
Eric
Eric SS is offline   Reply With Quote
Old 05-20-2002, 12:10 AM   #4
MattDell
Member#: 16803
Originally posted by Blindeye_03
Compared to what?
I guess compared to a "regular" engine. I'm not very knowledgable about engines.
Old 05-20-2002, 01:28 AM   #5
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
The boxer engine is also shorter and much much lighter than any other 4-banger out there of equal displacement because is doesn't need to be balanced.
Because the engine is a boxer type isn't the reason why they have low-end torque, that's because of the displacement and tuning.
DoorKnob is offline   Reply With Quote
Old 05-20-2002, 02:47 AM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Sounds alooooooot better
Old 05-20-2002, 07:58 AM   #7
Joe Alejandro
Member#: 9004
'94 FF 1.8RS
Rally Blue
It makes it sound bigger than it is. So you won't get any tin, coffee can sounds. Joe
Joe Alejandro is offline   Reply With Quote
Old 05-20-2002, 10:53 AM   #8
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
The flat configuration means it's not very "deep" into the engine bay, so it can be mounted more forward to aid traction.. I much enjoyed the benefits of this in my old FWD '87 GL wagon.. Nearly the entire engine was in front of the front axle. That thing was a tank in the snow.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 05-20-2002, 11:54 AM   #9
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
I thought the boxer was mounted lower and further back to provide a lower center of gravity and better weight dispursement. Not further forward over the front axle.
Is that what I get for thinking?
doobie is offline   Reply With Quote
Old 05-20-2002, 12:16 PM   #10
BugBomb
Member#: 1342
99 OBS & SUXASS
May your line be smooth
I am pretty sure Subaru's display at the Baltimore Auto Show this year had stressed that the engine was further back into the car.
The Boxer 4 has one, big disadvantage though. The exhaust pulses cannot be properly scavenged out of the cylinders. A 4-to-1 header would be the only solution, but there is no room for one. The exhaust pulses on one side of the motor are not equally spaced time-wise. This could be one reason why you don't see any N/A RS Imprezas doing low 13s. We have a local N/A Neon that does 10s!
BugBomb is offline   Reply With Quote
Old 05-20-2002, 02:20 PM   #11
phucvtec
Member#: 16261
2000 Impreza 2.5RS
Blue Ridge Pearl
Here is my take on it...
The term "boxer" is used to decribe the engine in that the pistons are located directly across from each other, and they move in and out in unisen (which apparently looked like the fists of a boxer to the designer). The major advantage is that boxer is going to be incredibly stabilized as it winds up. In the case of a V or Inline configuration, there the net inertia is not always stabilized by the moving engine parts alone, and corrections need to be made. The result is incredible low engine torque. (please correct me if im wrong, its has ben awhile since i took physics )
the limitations are that the size of the engine is larger than most 4-cyl engines, hence great efforts are made to mount it in the engine compartment. For this reason, along with cost, the only companys that use boxer engines are subaru and porche. Ever wonder why your NA impreza costs only about $2000 less than a Z-28?
Another advantage is the center of mass issue. the engine sits low, which lowers the center of mass close to directly between the front wheels, inhancing handling. Furthermore, the engine design allows the transmition to be located directly behind, which moves the center of mass of the entire vehicle to almost below the stick shift! Ever wonder why subarus handle so much better than most vehicles in their class?
Hope im not toooo wrong on this stuff, and hope it sheds some light
phucvtec is offline   Reply With Quote
Old 05-20-2002, 02:53 PM   #12
bigpaulo
Member#: 17655
2002 Impreza TS
low profile green
Default boxer engine advantage - cylinder oil on startup?
I was once told that Subaru engines can last a long time, because when you shutdown the engine, the oil in the cylinders don't drain down into the oil pan, like they would in other engine designs, where the cylinders are more or less vertical.
Since a coating of oil remains in the cylinders after it's been shut off, it helps reduce wear when you start the engine next.
Was I told a pack of lies, has anyone else heard this, or is there truth to this idea?
Paulo
bigpaulo is offline   Reply With Quote
Old 05-20-2002, 06:12 PM   #13
JMFInkel
Member#: 14916
1999 Impreza 2.5 RS
Rally Blue Pearl
Hi, everybody!
I remember reading a while ago that the manufacturing processes for boxer engines are also less prone to casting errors than those of other engines. Bang, ergo, zoom Subaru engines (and Porsche engines) tend to have somewhat stronger weakest links. Hope that made sense.
Jon
JMFInkel is offline   Reply With Quote
Old 05-21-2002, 02:11 AM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think the biggest reasons are
a) the AWD
b) the lack of RS N/A tuners, most go turbo
If you were to say, use the Cobb tuning N/A block/head/cams on a FWD Impreza with racing tires and gutted to save weight along with engine management systems, I wouldnt be surprized to see low 13's, high 12's
Old 05-21-2002, 02:15 AM   #15
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
a) the AWD
I agree. Our cars can weigh over 500 lbs. more than a Neon slimmed down for drag racing. Add that to the drivetrain loss that AWD has and bingo, you're talking a huge difference in e.t. with the amounts of power we are talking about.
Eric
Old 05-21-2002, 08:13 AM   #16
tonytiger
Member#: 3844
1993 Legacy 1.8
On thing I didn't see mentioned is the ability to make the front of the car very slim, due the flat engine, which helps in air drag dynamics.
I have now knowledge of the exhaust header design, but what about making a dual exhaust from the both headers individually - I mean like 2-1 twice. Is it worth it?
That would be nice setup I think...
tony
tonytiger is offline   Reply With Quote
Old 05-21-2002, 09:19 AM   #17
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Imprezas are not for drag racing. Drag racing is onle a few seconds of "boy, I can go in a straight line!" Get a g-tech if you just HAVE to know your 1/4 time.
Imprezas are for the twisties, and the boxer engine is perfectly suited for this. Great torque and low center of gravity. Also, with some work she'll ake more boost than most IIRC. Having only 2 cylinders per bank makes the block that much stronger.
-IggDawg
IggDawg is offline   Reply With Quote
Old 05-21-2002, 09:39 AM   #18
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
Indeed. Drag racing is for Trans Ams with huge, butt-ugly, overstyled nostrils and 21452176 cubic inches of V98 "engineering". Subarus are for rally-x and hillclimbs, and are well-suited to such.
lb
www.trancelab.com
Old 05-21-2002, 03:21 PM   #19
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
one such occurrance: the Subaru XT/XT6 body had the lowest drag coefficient of any mass-produced passenger car up until one of the recent Porches was released, IIRC.
SoobATV is offline   Reply With Quote
Old 05-21-2002, 04:39 PM   #20
C-daleRidr
Member#: 18074
2008 Speed3
So, there's a bunch of good technical reasons. What do I notice every day? It's the smoothest car I've ever been in at idle. Get in my wife's Honda and it feels like I'm in an earthquake.
It seems that Subaru ignored a lot of the wind resistance pluses of the boxer, though, with the body of the car undoing anything the boxer might have done by its positioning.
And I think a lot of the reason our cars aren't much less than Camaros is the supply/demand factor, and the fact that our transmission is more advanced than anything a muscle car could hope to have.
C-daleRidr is offline   Reply With Quote
Old 05-21-2002, 04:54 PM   #21
nuj44
Member#: 18893
2002 Impreza RS
Also,
because of the set up of the boxer (lower, and "flat") the entire drivetrain can be done in a straight line. Other AWD systems have to go back to the rear wheels and have a complex configuration of gears and shafts that have to run back along the side of the original shaft.... causing weight distribution to be uneven from one side to the other of the car, not just front and back. Our far advanced Subaru's look more like this. Front ->H---- <-Back compared to a straight six Front -> --==-- <-Back, or a V6 Front-> >==-- <-Back
as you can see by my tacky diagram. the straight six and V6 have more weight on the left side.
Okay Kids. Done with my bad lesson of the day.
Peace and Impreza's
NUJ
nuj44 is offline   Reply With Quote
Old 05-22-2002, 04:40 PM   #22
Subie Trials
Member#: 14013
2002 impreza 2.5 TS
White 5spd
with the better balance and lower center of gravity the boxer engine helps you jump your car with a greater deal of control and confidence, if you are into that kind of thing. Bo and Luke watch out for the subies!!
Subie Trials is offline   Reply With Quote
Old 05-22-2002, 11:36 PM   #23
Prez&SUS
Member#: 18575
although the low drag is a plus too, another good thing about the low hood is the visability of the road directly in front of you (especially visable on the new wrx, where the center of the hood is much lower than the edges where the headlights are)
i know this sounds kinda lame but compare it too sitting in a camaro, you feel like your driving a cruise ship
in defense of drag racing and the argument that subies wernt made for it, well, neons wern't exactly made for it either but they seem to do pretty well.
Prez&SUS is offline   Reply With Quote
Old 05-23-2002, 03:36 AM   #24
racerwad
Member#: 2564
Smile
someone mentioned that space requirements was a disadvantage to a boxer motor. i'm wondering how that would be? the only dimension a boxer engine would be large is is width. that only forces the car to be wider; while that does increase frontal area (and drag) it also makes the car wider for a larger, more stable platform. subaru was able to add an extra piston to the H6 and it only increased in length by 33%. sounds pretty space efficent to me.
andy
racerwad is offline   Reply With Quote
Old 05-24-2002, 12:59 AM   #25
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
well, the EJ25 also has a large bore for its stroke. That probably has something to do w/ the engine couldn't be any wider and fit in the car. a longer stroked engine wouldn't fit into the bay.
I also wanted to say that my car seems to run smoother than most of the honda's I've been in. Hondas seem to vibrate which sounds and feels weird to me. Surprisingly, the Si's seem smoother(even at high RPM) than the base models.
mrbell is offline   Reply With Quote
Benefits of "bored-out" engines? Gonzalo General Community 13 09-11-2007 10:02 PM
What are the benefits of a built engine with turbo? wReXeRw Built Motor Discussion 8 10-16-2006 06:14 PM
Do the benefits of being a woman outweigh those of being a man? mr_disco Off-Topic 29 10-15-2003 09:37 PM
Is it possible to get the benefits of a lighter crank pulley without the negatives? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 07-02-2003 01:44 AM
Info on the 16 valve SOHC boxer engine mbdevilhater Normally Aspirated Powertrain 1 07-20-2001 06:12 PM
