Welcome to the North American Subaru Impreza Owners Club Friday July 25, 2014
Old 12-13-2009, 03:15 AM   #1
jacobp7201
Member#: 210161
Default 02 Bugeye Retrofit: FX-35 Clear Bi-xenon
After researching many write-ups on here and the HID Planet forums, I was able to complete my HID retrofit this past week. Being that my last retrofit was almost 5 years ago (00 Integra), I wasn't sure how this one was going to turn out. The Integra was pretty straightforward since the majority of the work involved cutting the stock bracket and mounting the projector. With this retrofit, I had to figure out where to cut/how to mount/which shrouds or bezels to use, etc.
This setup consists of the following:
- OEM FX35 Clear Bi-Xenon projectors w/ modded cut-off shield
- OEM Matsu****a Ballasts from an Infiniti Qx4
- Ocular Shrouds
- Morimoto 4300K D2S Bulbs (brand new not yet color shifted)
- 9007 wire harness
I'm really happy with the appearance and overall performance/light output of these projectors. Here's some pictures of the completed retrofit. I'll post some cut-off pics once I find a perfect spot to snap some. Feel free to post or pm any questions regarding the retro. --Thanks for looking!--
jacobp7201 is offline   Reply With Quote
Old 12-13-2009, 04:05 AM   #2
kaeo_15
Top Scoob 021
Member#: 115406
2008 STi
For Sale...
Looks good! I love mine!
kaeo_15 is offline   Reply With Quote
Old 12-13-2009, 04:22 AM   #3
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
where do you get the head lights from and how much??? but the car looks great
bmxhotsauce is offline   Reply With Quote
Old 12-13-2009, 09:01 AM   #4
Spore
Member#: 100117
2009 Impreza 2.5i
Satin White Pearl
I'm guessing its an Ebay MY02-03 headlight
Great work on the retrofitting. HID retrofit on a bugeye looks amazing!
Spore is offline   Reply With Quote
Old 12-13-2009, 11:58 AM   #5
flash02
Member#: 78916
so how did you do it? how are the projectors mounted in the headlight assy.
flash02 is offline   Reply With Quote
Old 12-13-2009, 12:06 PM   #6
ryan2.5
Member#: 167205
2004 N.F.D
04 STi. FP Red + Meth
those look good. nice job. I was considring using the same shrouds cause you dont have to trim any of it. They look really good. Can you post up some output shots?
ryan2.5 is offline   Reply With Quote
Old 12-13-2009, 04:36 PM   #7
jacobp7201
Member#: 210161
Thanks guys! Headlights are aftermarket from ebay as Spore mentioned... Since this is my daily driver, I needed a spare set of lights to retrofit and couldn't find any decent oem ones. I'll snap some cut-off pictures tonight and post them up.
Projectors are mounted on to stock reflector bowls... I basically dremeled off the stock reflectors, mounted the projectors, aimed, then sprayed the bowls black, re-mounted, double-checked the aiming one more time, cleaned, then re-sealed, then aimed again.
I used this thread for reference:
http://forums.nasioc.com/forums/show...highlight=fx35
Old 12-13-2009, 04:59 PM   #8
valkrie hunter
Member#: 208381
'10 Legacy GT
that does look amazing, i've always wanted to attempt retrofitting HID into mine... but no headlights available for the new imprezas
valkrie hunter is offline   Reply With Quote
Old 12-13-2009, 06:59 PM   #9
sick EJ20
Member#: 105596
03 BUGEYE
psm
looks clean, can you post some night time pics, if you have any
sick EJ20 is offline   Reply With Quote
Old 12-14-2009, 12:35 AM   #10
jacobp7201
Member#: 210161
Cut-off pics added. It's the best I could do for now since my camera's battery was dying and there were two trees in the way...
Old 12-14-2009, 11:03 AM   #11
ryan2.5
Member#: 167205
2004 N.F.D
cutoff looks perfect.
Old 12-23-2009, 04:44 PM   #12
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Looks great! Any in-process pictures? Did you mount via the JnC method or through the rear?
What do you do during the day if your lights are off and you've got to flash the high beams?
Superorb is offline   Reply With Quote
Old 04-03-2010, 02:35 PM   #13
jaytheman
Member#: 226841
i have the same set up! with the retrofit but the only thing is im scared to start on it with the oem headlights. This will be my first retrofit any advice?
jaytheman is offline   Reply With Quote
Old 04-03-2010, 04:05 PM   #14
subaru3169
Member#: 55252
* pullup bar *
you could get a spare set from ebay.. the blacked out oem looking ones
subaru3169 is offline   Reply With Quote
Old 04-05-2010, 01:01 AM   #15
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
dont know how i missed this thread.. but looks good!
jdubya301 is offline   Reply With Quote
F/S BROKEN TABS: FX35 Bi-xenon HID retro fitted bugeye head lights. ALL TABS BROKE! ravenlunatic Exterior/Styling 10 02-04-2010 04:41 PM
Very Serious Feeler: Bugeye Bi-Xenon Retrofits Turbo_Twinky NWIC Private Classifieds 13 07-23-2009 12:23 AM
Bi-xenon fogs in bugeye? sorrowfulkiller Electrical & Lighting 12 07-14-2008 07:31 AM
bi-xenon 9007 bugeye HID kit bugeyed bandit TXIC Private Classifieds 10 04-16-2008 05:33 PM
OK FS: Bugeye FX45 Bi-Xenon Projector Retrofit Kit $350 jimbobrand Exterior/Styling 8 08-21-2007 06:28 PM
