#51 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
Now, that's worth the money ![]() Thanks! S.
#52 |
Member#: 158864
is there an injector/fuel system cleaner we can just run through that will get rid of this stuff?
#53 |
Member#: 126548
TXIC
#54 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
#55 |
Member#: 165104
SCIC
Vehicle:E85 bug-i sti swap Phatron tuned |
That's a good question but your running 0 wgdc on a pump map to clean the injectors. Its a nice map for those purposes. The load cells should do most of the work I assume unless your running a huge waste gate spring. I wish I knew about tuning so all this is an assumption
#56 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
I should go back and edit all these posts....people are taking it as "this is how i tune cars"....it was just a suggestion for a simple pump gas map to put around on not in boost.
Nuke, what do you need to do to the low load timing? it really all depends on how the e85 map is setup.....but you can run craploads of low load timing on pump too....i was running 52* on my STi for 6 years on 91 oct. stock 06-07 WRX's run 55*. If you're going to make a pump map you should just change everything anyway.....its not like it takes hours and hours to change the boost, timing and fuel maps over.....it can be done in several minutes. My comments in this thread were just a simple solution for someone that really doesnt know what they're doing.....and obviously (at least i thought) not the way i do things or recommend people do things. If you do what i suggested in this thread and get into boost, then you're most likely going to knock like a mofo....especially if your switching to 91 oct. |
#57 |
Member#: 276209
Vehicle:I am Rub Function>Form |
I'm worried that this buildup might be the cause of my issue. Ever so often I'll go to downshift into 2nd attempt to rev match and nothing. The rpm's simply wont climb and the engine makes a noticable misfire sound. I've ordered new plugs in fear that they might be the issue but the current ones look clean. I haven't had time to pull the injectors to check for any gunk, but I'm going to switch over to my 93 map this weekend and run a tank or two of 93oct through the system. I'll report back in a week or 2 with my results.
#58 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Great information. Thank you. (I know this is an older post) |
#59 | |
Member#: 327511
Vehicle:13 WRB GR EL-EWG-E85 |
| Thread Tools | |
| Display Modes | |
| e85 injector size, and boost control questions | Turbovan | Factory 2.0L Turbo Powertrain | 3 | 03-25-2009 01:49 PM |
| Air box gunk build up? | VinnieisSouth | Interior & Exterior Modification | 4 | 03-04-2009 10:55 AM |
| IC Hardline gunk build up? | bcristea | Factory 2.5L Turbo Powertrain | 1 | 04-07-2008 11:18 AM |
| to build up my 2.0 or to build a 2.5 | pulser9 | Factory 2.0L Turbo Powertrain | 13 | 05-19-2007 08:13 PM |
| what's the e85 situation like up there | wherethefmi | North West Impreza Club Forum -- NWIC | 5 | 03-31-2007 01:28 PM |
