Old 12-14-2009, 02:22 PM   #1
BigRed06
Member#: 154561
2006 cougar magnet,
my dad is my wingman
Default DIY coolant overflow tank? The OEM sprung a leak.
Is there something acceptable/affordable I could use as a coolant overflow tank? There is a small hole in my original one, and no matter how many times I plastic weld it/all weather tape it, over time it starts leaking again. I'm a college student and I'd rather not spend $55.21 on a new one from the stealership. Any ideas... preferably previously tested ones... I would greatly appreciate.
BigRed06 is offline   Reply With Quote
Old 12-14-2009, 04:08 PM   #2
mikeythejew
Member#: 141672
If you can find one at a salvage yard where you pull the part, it should be cheap. The late model year salvage yards are usually more expensive, but worth a try.
mikeythejew is offline   Reply With Quote
Old 12-14-2009, 05:33 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
any of the aftermarket ones for fmic's will work. They have a volume of a soda can or so.
If you dont mind to be ghetto for a little while, any thicker walled plastic soda bottle will do with the capped drilled. Then you can take your time JB welding your stock overflow tank properly. Or check your regional forum, someone might have one for sale.
fastnoypi is offline   Reply With Quote
Old 12-14-2009, 07:23 PM   #4
elviking
Member#: 182656
2007 2.5i
1 Black, 1 Blue
Not sure if I have the correct one, but I found it for $35 at https://www.chaplinssubarugenuineparts.com/
elviking is offline   Reply With Quote
Old 12-14-2009, 08:19 PM   #5
BigRed06
Member#: 154561
2006 cougar magnet,
fastnoypi would you mind throwing me a link to the "aftermarket ones". The first thing i did was check my regional classifieds but no luck; and as far as trying to fix it again, it would be round three... something about the way the coolant heats up, it just seems to breach every fix. its time to get a leak proof solution. I'd be willing to try the soda can idea, but do you mean like a 1 or 2 liter bottle, or a 24oz can?
mikey lets just say the salvage yards here consider me a gringo, so unless I can get a darker skinned friend of mine to come along, it might be more expensive than the stealership.
elviking i looked high and low on that sight and couldn't find it, did you have to advance search or maybe its a different part you were looking at...?
Thank you guys for the input!
Old 12-14-2009, 09:58 PM   #6
elviking
Member#: 182656
2007 2.5i
1 Black, 1 Blue
Try this.
https://www.trademotion.com/partloca...layCatalogid=0
Its for a 2007, as I don't know what you have.
Old 12-14-2009, 10:01 PM   #7
elviking
Member#: 182656
2007 2.5i
1 Black, 1 Blue
Actually, it says its for 02-07.
Old 12-14-2009, 10:42 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Bigred.. i've used a a 20 or 24 ounce bottles before and even the 22oz NOS energy drink bottle for extra power just throw them out if you see them getting grungy
aftermarket ones can be found all over ebay, summit racing and jegs. just do a keyword search for "coolant overflow" Just be sure to measure the height of the canister to wherever you want to mount it. You dont even need the crossover tube on the top of the radiator if you want to relocate to the opposite side by the power steering reservoir.
Old 12-15-2009, 07:59 PM   #9
BigRed06
Member#: 154561
2006 cougar magnet,
alright awesome I'll experiment with those options. thank you for your time fastnoypi
Old 12-15-2009, 09:09 PM   #10
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
punch or drill a hole in the lid of a gatorade bottle, insert hose, profit.
Old 12-15-2009, 09:10 PM   #11
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Ghetto modding, however it still looks better than stock.
axelthrasher is offline   Reply With Quote
Old 12-18-2009, 06:11 AM   #12
indytruckboy
Member#: 192599
2004 STI
2007 Outback Wagon
Are you talking the tank on the intake or the one on the radiator?
indytruckboy is offline   Reply With Quote
Old 12-18-2009, 11:56 AM   #13
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Ghetto repaired the gas tank in my old Road Runner. Enlarged the hole, then used (without sealant) a tire plug. Was still holding when I sold it. If it can be ghettoed, I've probably done it! RP
drivin blind is offline   Reply With Quote
02 wrx coolant overflow tank OEM $15 shipped subypal Engine/Power/Exhaust 14 01-31-2010 09:47 PM
Fs Va: Oem Washer Tank, Oem Coolant Overflow Tank Bugeyeballa Engine/Power/Exhaust 2 10-25-2009 08:33 PM
Pic request: GD WRX looking straight down at coolant overflow tank/battery area garface Member's Car Gallery 0 02-01-2005 12:36 PM
wrx wagon front sway+impreza coolant overflow tank for 99rs White 2.5rs Private 'Wanted' Classifieds 4 07-08-2004 06:42 PM
Coolant Overflow Tanks Roo Service & Maintenance 4 05-07-2002 12:06 PM
