Old 12-14-2009, 02:28 PM   #1
nj06wrx
Member#: 112411
2006 WRX wagon
red
Default 17x8 with 47mm offset on 2006 WRX wagon. Any issues?
I have searched here and found lots of useful info on tire/wheel/offset sizes but I've not been able to confirm whether of not this will fit my 2006 WRX wagon without problems.
I'm looking at putting 225/45-17 Dunlop Sport 01 tires on a 17" x 8" rim with a +47mm offest.
As far as I can tell the tires should fit the rims just fine and the offset looks acceptable. I'm just wondering if there will be any clearance issues going to an 8" wide rim. I'm not set on 8" rims (7" would be fine), but I've found a set of rims I like at a decent price and they happen to be 8" with no 7" or 7.5" option.
I can get something similar in a 17x7.5" size with a +45mm offset, but I like the design of the 8" better.
nj06wrx is offline   Reply With Quote
Old 12-14-2009, 03:48 PM   #2
mosc
Member#: 177401
2015 STi White
With the wagon, you have very little rear fender clearance. If you want even 225 wide, especially on lower springs, you need high offset. +50 to +55 would be very helpful in fitting decent sized tires.
Rim width doesn't effect clearance that much, it's just that width often comes with wider tires and less offset which are factors that more directly relate to fitment. There's nothing wrong with 17x8 or even 17x8.5" rims for your car as long as you have the right offset and tire choice. That said, as you go wider, your high offset choices become more and more limited.
Lots of people report rubbing on 17x8" +48 rims with 225/45/17 on even stock ride height wagons. Even more common on lowering springs. Adding offset will help this. Generally though, a small fender roll at most and these sizes work fine. If you never load it down, stick stock springs, and don't really turn hard, you might not notice any rub at all. IMHO too many if's
If you want some cheap rims to run 225/45/17 pain free, you can get 06-09 WRX wheels, 17x7 +55. Your stockers can also handle 225/50/16 pretty well because they're high offset. 17x7.5 another popular choice is 04 STi BBS wheels which are +53.
What would I do in your shoes? I'd roll and pull my rear fenders and get some 245/40/17 tires on 17x8 +48 wheels.
mosc is offline   Reply With Quote
Old 10-26-2010, 09:08 PM   #3
mtnredhed
Member#: 262138
Default bumping an old thread
<noob alert>
Stock '05 wrx wagon. I'd like to go to 225/45-17's (plus 1). I've been all over the web looking for 17x7 (7.5/8) rims with enough positive offset. 45's are common. 48's not too bad. 50's are just a handful, and the only 55's are the Suby OEM wheels that will run me a grand for the set.
Are the wagons really that narrow in back? How much body mod am I looking at to fit the 225/45's on +48 rims? I've read up a bit on fender rolling, which seems to have some risk as far as paint cracking. Really don't want to go there.
I'm looking at rims in the $150 range.
A. Why yes, I am cheap
B. While my suby is fun, it's not my only cash sink.
C. I'm not tracking the car, although I occasionally like to get frisky on the twisties.
I know this gets discussed a lot
Thanks in advance
jim
mtnredhed is offline   Reply With Quote
Old 10-26-2010, 09:21 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OMGyerallgunnadiehorribledeaths
17x8 is WAY-WAY better than 17x7 and I like a 235/40 better than a 225/45 on the wrx
and just forget any offset issues as long as it is +45 or more....+42 will work, too....but that is up to you...a couple mm isnt gunna kill all yer gerbils and harbils
Old 10-28-2010, 10:56 AM   #5
__raj
Member#: 177241
2005 LGT Wagon 5mt
To confirm +45 is fine for pure stock 04 WRX wagon? I purchased an inexpensive used set of ASA 17x7.5 +45 offset mounted with 1/2 worn 215/45/17 LM-25 Blizzacks.
__raj is offline   Reply With Quote
Old 10-28-2010, 11:08 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh jesus h ****ing christ
Old 10-28-2010, 04:22 PM   #7
pnutbutta
Member#: 192572
2007 Impreza
CGM
here is my parent's wagon on 17x8 +48, and a 215/45/17 General Exclaim UHP. i provided you an angle so you can see the clearance, which is similar to the impreza wagon (my brother owns a bugeye wagon) They also had a continental 215/45/17 on it before, which was slightly stretched so it depends on tire manufacturer.
pnutbutta is offline   Reply With Quote
Old 10-30-2010, 12:51 AM   #8
littlewhitewagon
Member#: 103068
11 STI sedan
235/40r17 and 225/45r17 with 8" and +45 will require fender rolling in back. If you don't want to roll, get 215/45r17 or a higher offset, or a narrower wheel.
littlewhitewagon is offline   Reply With Quote
2006 WRX Wagon--any applied lip or rear diffuser? suBerSam Interior & Exterior Modification 27 05-20-2015 03:35 AM
17x8 45mm offset on '05 wrx wagon? scoobynewbie Tire & Wheel 4 08-10-2007 07:30 PM
+42mm offset on a WRX Wagon, or sedan? suprawrx Tire & Wheel 2 03-21-2006 09:31 PM
17" Bronze Wheels with perfect offset for a WRX Wagon - What's out there? trahsub Tire & Wheel 9 01-04-2006 11:09 AM
Will a 17X8.5 wheel fit on a WRX wagon? JB1 Brakes, Steering & Suspension 3 04-26-2002 10:40 PM
