Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 12-15-2009, 12:23 AM   #1
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
Default 96 SVX Question
my friends moms coworker (yes i know) has a 96 SVX that has around 105k on it. She is the original owner of it. Her AWD has gone out somehow and she is wondering why. The rear wheels are NOT spinning, but the front ones are. I guess she took it to a dealer or something and they said they think its the transfer case/rear diff or something along that line. She doesn't believe them for some reason, she thinks its something else. Could it possibly be anything else? She asked me to post up and see what i could find out.
Thanks
Jncominco2 is offline   Reply With Quote
Old 12-15-2009, 01:28 AM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Seems to me like the center diff or the rear diff would be the problem. It would be easiest to tell if the car was driven on a lift in the air.
bhhamblin is offline   Reply With Quote
Old 12-15-2009, 01:48 AM   #3
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Driveline fell off? lol It happened to my jeep. I suppose its possible lol.
EsubaruJ is offline   Reply With Quote
Old 12-15-2009, 09:09 AM   #4
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
If i told her to do that, what could be the possibilities? If the front turns but the back doesnt, its the rear diff?
i hope they would notice something like that heh
Old 12-15-2009, 10:27 AM   #5
ninefourteener
Member#: 104414
SUBY 06WRX 07TRIBECA
78BRAT 94SVX-LSi
I posted a response on SLCSubaru as well
Fuse box under the hood. The SVX has a tow option that will electronically disengage the rear diff.
Check that first.
ninefourteener is offline   Reply With Quote
Old 12-15-2009, 10:28 AM   #6
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
it could be the center diff as well. could be completely trashed and its slipping. Wonder if the car was ever towed on 2 wheels?
Old 12-15-2009, 10:32 AM   #7
ninefourteener
Member#: 104414
78BRAT 94SVX-LSi
true^^^
Could be any manner of things. That is the easiest, most logical solution though.
The SVX came with that feature, which is something most folks aren't immediately familir with. If you pull the fuse under the hood, it allows the SVX to be towed, or to use a donut on the rear to limp home.
If the fuse blew.... it would cause the same problem. There "should" be an indicator on the dash though that says she's in FWD or "limp" mode.
Old 12-15-2009, 11:00 AM   #8
Not-EWRX
Member#: 158043
2013 Wrx Hatch
This woman is smarter than most. I swear most of them don't even know there car has four wheels.
ZING!
Not-EWRX is offline   Reply With Quote
Old 12-15-2009, 11:04 AM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Check that first.
I was going to post this. Foresters have the same fuse. It's a super easy thing to check and less than $1.00 to fix if it is the problem.
If that's not it tell her to take it to another dealer. Putting it on a lift would be easier than trying to figure it out on the forums.
medamullet is offline   Reply With Quote
Old 12-15-2009, 11:06 AM   #10
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I believe all subarus have this feature but now it's not mentioned in the manual . I think they revised the manual on later models and only reccomend towing with with all four wheels off the ground and the fuse is used only if you are using the spare tire. They don't want it to be used for long periods of time since it is still hard on the car. Most people won't drive around on a spare tire for that long but people were pulling the fuse then towing the car across the country and subaru wasn't going to fix issues that could be caused by it.
aclver1 is offline   Reply With Quote
Old 12-15-2009, 11:29 AM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I think it depends on the car. I don't believe my car even has that fuse. My buddy has an 09 forester and the manual says put the spare tire on the back, and pull the fuse when driving. Just like what you are saying. It might depend on what kind of rear diff the car has. I am guessing the suabru fleet all have a similar setup, other than the STI with the DCCD with front and rear locking diff.
Old 12-15-2009, 11:41 AM   #12
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Yeah I didn't think about the sti being different. But I will soon enough after the 6 speed swap.
Old 12-15-2009, 12:36 PM   #13
stoner
Member#: 52863
2007 B7 A4
Whats her experience as a Tech. She takes it the dealer and then says it has to be something else? Not saying it can't be something else, but why take it to a dealer then disagree with them?
stoner is offline   Reply With Quote
Old 12-15-2009, 12:41 PM   #14
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
I would try the fuse first, it is easy to check and cheap to replace but it could be a number of problems like mentioned before.
Old 12-15-2009, 01:00 PM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I agree with stoner. If you don't like what htye say there isn't any reason to take it to the dealer. Try another dealer, if you the first guy gave off creepy oompa loompa vibes.
Old 12-15-2009, 02:45 PM   #16
azn2nr
Member#: 35276
the fuse only came on automatic cars. but the thing is, if there is no fuse in the holder then the car is in awd mode. the rear wheels only stop working if the fuse is in there. so if it is the fuse it wont cost anything to fix, just pull the fuse out
azn2nr is offline   Reply With Quote
Old 12-15-2009, 07:17 PM   #17
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
This happened on my 93 Touring Wagon. It's expensive to fix ($800) or so, and the reason many do 5MT swaps on them instead of rebuilding/repairing the 4EAT.
DLC is offline   Reply With Quote
Old 12-16-2009, 12:47 AM   #18
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
thanks for the responses everyone. i told her to check that out and she said shes taking it to another dealer to get looked at
Old 12-16-2009, 10:11 AM   #19
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
That's the best indea ever good luck, and I hope it works out!
Old 12-16-2009, 04:22 PM   #20
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
A&C Automotive in Murray also knows about this kinda stuff. Charlie works on Saabs and Subarus and would be a bit cheaper (and would do a better job) than the stealership(s).
Old 12-18-2009, 09:29 AM   #21
odepaj
Member#: 94835
1995 SVX
2008 spec.B
+1
There is no fuse in the FWD slot, you have to put a fuse in there to disengage the center diff.
The FWD fuse is for DIAGNOSTIC PURPOSES ONLY.
odepaj is offline   Reply With Quote
Old 12-18-2009, 09:56 AM   #22
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Chances are it's one of two things.
1) solenoid C - small solenoid that controls fluid path in the center diff
2) the center diff "basket" - this basket is welded to the transfer gear and works with the clutch packs. We had an SVX that the basket came loose from this gear. My research showed this is pretty common.
From over a year ago to today. 07 WRX & 96 SVX included!!! fzel07wrx Member's Car Gallery 7 08-25-2008 10:50 PM
Place to buy 96 SVX parts Fairlane 'Old School' Subaru Forum 4 04-01-2006 08:00 PM
Fs: 96 Svx forevernewb Private Vehicle 'For Sale' Classifieds 10 09-04-2003 03:04 PM
96 SVX for sale... forevernewb Mid West Subaru Owners Club Forum -- MWSOC 9 07-28-2003 02:20 AM
96 SVX for sale (pending interest) forevernewb Mid West Subaru Owners Club Forum -- MWSOC 3 05-25-2003 08:09 PM
