Old 12-15-2009, 03:05 PM   #1
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
Default 06 wrx transmission into 02 wrx
My friend is swapping his 06 wrx transmission for an 04 STi 6mt. I blew my transmission this past weekend and he offered to sell me his parts. Transmission, Rear end diff, and axels.
I've seen somewhere that the clutch types are not the same and i will need a slave cylinder.
Is there anything else i would need to make this work?? I really need my Daily Driver.
Thanks.
MindzeyeWRX02 is offline   Reply With Quote
Old 12-15-2009, 06:12 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
You'll need:,
Flywheel, slave cylinder ,clutch line,throw out bearing &,pressure plate( the discs are the same)
Front axles are diff, rear axles are the same
sense of nature is offline   Reply With Quote
Old 12-21-2009, 12:39 PM   #3
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
Talking
Originally Posted by sense of nature View Post
You'll need:,
When my friend swaps in the 6mt, will he have to replace any of these? "[COLOR=#F82C70 ! important][COLOR=#F82C70 ! important]Flywheel[/color][/color]
, slave cylinder ,clutch line,throw out bearing &,pressure plate"
Thanks.
Old 01-20-2010, 10:24 PM   #4
chperformance
Member#: 235865
does a 06 wrx 5spd tranny fits an 02 wrx? let me know thanks
chperformance is offline   Reply With Quote
Old 03-27-2010, 12:35 AM   #5
subielvr5
Member#: 239083
2002 VF39 WRX
yes, an 06' 5spd will fit in an 02'-03'. just like above, you will need a flywheel, slave, and clutch line, and the front axles. i would not do the swap though if you are looking for a stronger transmission. they are both pretty much junk if you have mods. look into MFactory, Ver6 Gears, or an STI swap instead.
here are the transmission differences side by side:
(02' next to an 07')
http://www.facebook.com/jake.hardee?...&id=1017857674 (if the picture doesn't automatically show)
subielvr5 is offline   Reply With Quote
05 STi transmission into 02 WRX wagon - axle questions corey_dyck Transmission (AT/MT) & Driveline 16 07-28-2011 10:55 PM
06 WRX ecu into 02 WRX? K.Linchpin Engine Management & Tuning 5 05-17-2010 07:17 AM
06 WRX Cluster into 02 WRX - Adding Digital Temp and ABS Fix TheShadowWRX Electrical & Lighting 3 10-13-2009 11:59 AM
04 Transmission into 02 WRX Icey101 Transmission (AT/MT) & Driveline 2 05-03-2007 06:30 PM
06 WRX Transmission VS. 02 WRX Transmission? 02BlueSuperRoo Transmission (AT/MT) & Driveline 17 08-06-2006 10:27 PM
