Old 12-15-2009, 10:19 PM   #1
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Default 2.0 Evo3 16g Dyno chart
Got my tune done about 4 months ago, so what, i'm lagging! Stock 2.0 with nearly 100k miles still running strong.
Event: dyno pull
Ambient Temp: ~70
Elevation: Unknown
Weather: sunny
Car: 2003 Wrx Impreza
Tuner: Jon
Peak HP at RPM: 294.2 hp @ 6300 RPM
Peak Torque at RPM: 259.9 Ft-lb @5600 RPM
Baseline hp/tq for a stock on same dyno: Unknown: ~190??
Target Boost: 20psi
Target AFR:11
Fuel: 91 Unleaded
Engine/Power Modifications:
Blouch Evo3 16g
DW 650cc Injectors
TGV Delete
Greddy FMIC
Prodrive EBCS
Injen CAI
Walbro FP
APS Dp
COBB catback
Gutted Up pipe
Gimmick turbo inlet
Driveline Modifications:
Stock
Suspension Modifications:
BC racing Coilovers
Dyno Chart:
Conclusion:
All parts were installed by myself so i have a good idea of mechanics.
Questions? Comments? Concerns?
TheSomethingorother is offline   Reply With Quote
Old 12-15-2009, 10:42 PM   #2
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Call him back and make him elaborate. Looks good! Very nice car!
2gnt2wrx is offline   Reply With Quote
Old 12-15-2009, 11:30 PM   #3
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Was about 4/5 months ago, i'd imagine he tunes too many cars to remember mine!
thanks though man!
Old 12-16-2009, 12:02 AM   #4
New_BOOST
Member#: 195062
2005 WRX
Torque seems a little low to me. Are you at 20 psi?
New_BOOST is offline   Reply With Quote
Old 12-16-2009, 12:19 AM   #5
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Yes sir, 20psi.
Torque seemed a bit low to me, but its a 2.0 and i've seen other torque numbers in that range.
Old 12-16-2009, 12:23 AM   #6
Prevent
Member#: 149114
260tq... not bad at all on a 2.0L
Prevent is offline   Reply With Quote
Old 12-16-2009, 12:32 AM   #7
GenoaWRX9
Member#: 212459
2012 sti wrb
rip: 95 and 02
i think you may have just convinced me to buy a evo3 16g thanks!
GenoaWRX9 is offline   Reply With Quote
Old 12-16-2009, 12:36 AM   #8
TheSomethingorother
Member#: 186149
2005 STi WFC #144
No problem! I must say I'm for the most part very happy with the tune and the turbo..
Although not sure what my craving for more power will lead to..
Old 12-16-2009, 12:36 AM   #9
KurtP
Member#: 44836
1999 Fozzy
looks good.
I definitely would have wanted an explanation of the dip starting at ~6400 and an explanation as to what "running funny" means.
KurtP is offline   Reply With Quote
Old 12-16-2009, 12:39 AM   #10
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Originally Posted by KurtP View Post
looks good.
Not sure why it dips after 64k either, but i can feel it in the car.
Any ideas?
Old 12-16-2009, 12:43 AM   #11
KurtP
Member#: 44836
1999 Fozzy
Id be concerned the car is having to pull timing. You will probably get some fall off up top, but it should follow the natural trajectory of the curve, not have a concave dip in power.
I would do some data logs and let people take a look at them....with subarus your most likley culprit for almost any power related problem is bad tuning.
Old 12-16-2009, 12:45 AM   #12
Drivinwest
Member#: 39124
2005 Saab 9-2X Aero
Satin Gray Metallic (CGM)
Looks good. What kind of wheels are those?
Drivinwest is offline   Reply With Quote
Old 12-16-2009, 12:46 AM   #13
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Rota G-forces Replicas of advans.
Old 12-16-2009, 12:52 AM   #14
TheSomethingorother
Member#: 186149
2005 STi WFC #144
I'm going to have to pick up a tactrix cable because i currently have no way to data log, curious now though.
Old 12-16-2009, 12:58 AM   #15
KurtP
Member#: 44836
1999 Fozzy
Ah, I kind of assumed you did an accessport tune....
Should be able to link up with a member in your local forums willing to help you out.
It could very well be nothing, but its always a good idea to do a data log after you get your car tuned especially if you think your curve looks funny or notice something driving the car.
Old 12-16-2009, 01:01 AM   #16
TheSomethingorother
Member#: 186149
2005 STi WFC #144
It was done through open source, but i'm sure i could find someone with a cable around me and i have a laptop.
Not too noticeable but i do feel the drop after 6500.
Old 12-16-2009, 08:16 AM   #17
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
OP, when you have a minute please read this thread and update your 1st post with the required info in the required format. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 12-16-2009, 10:20 AM   #18
SacksLax
Member#: 193949
Numbers are solid. Right about same as mine on a Mustang Dyno. Seems a tad late, but I'm sure it's faster on the road. Mine has a dip in the torque curve as well, but my tuner is a good friend and I trust him completely. Mine doesn't fall off at the top though, and the torque curve is flat as a table, for the most part. Could you bring it somewhere else to get tuned?
SacksLax is offline   Reply With Quote
Old 12-16-2009, 10:23 AM   #19
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
Looks like a nice smooth safe tune to me...
Turbo_Mike is offline   Reply With Quote
Old 12-16-2009, 02:59 PM   #20
TheSomethingorother
Member#: 186149
2005 STi WFC #144
Fixed, thanks for the heads up
Old 12-16-2009, 04:02 PM   #21
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
looks fine to me, the lower boost/torque in the midrange could be mechanical issue or him wanting to save your transmission, jon doesn't normally set the cars up like that.
Up top could be taper or lack of advance up top due to 91 octane.
bren wrx is offline   Reply With Quote
Old 12-16-2009, 04:46 PM   #22
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by bren wrx View Post
looks fine to me, the lower Up top could be taper or lack of advance up top due to 91 octane.
There's a boost line on the dyno chart. It's not taper. Boost actually rises throughout the powerband.
Concillian is offline   Reply With Quote
Old 12-16-2009, 04:49 PM   #23
PA-Outback2000
Member#: 161832
2000 Outback Limited
what rims r those?
PA-Outback2000 is offline   Reply With Quote
Old 12-16-2009, 05:32 PM   #24
New_BOOST
Member#: 195062
2005 WRX
I agree, not bad at all for a 2.0...Im just used to seeing numbers closer to 275 with this turbo on a Mustang dyno. Nevertheless, it must be a blast to drive!
Old 12-16-2009, 06:01 PM   #25
TheSomethingorother
Member#: 186149
2005 STi WFC #144
It is a blast to drive, no doubt about that!
However, a little curious as to why my buddy with vf39 and sti pink injectors gives me a run for my money everytime.
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 03:41 AM
Panel Filter on 2.0 with 16g Brock31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 05-16-2010 04:52 PM
2.0 TDO5 20g dyno results and 1/4 times drewwrxrogers Proven Power Bragging 69 09-18-2008 06:52 PM
2.0 Blouch 16g evo 3 proven page and some videos shift_rex Mid Atlantic Impreza Club -- MAIC 4 03-14-2008 05:15 AM
EVO3-16G-8cm^2 dyno #'s FuJi K Proven Power Bragging 15 01-29-2008 12:13 AM
