Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 12-17-2009, 08:24 AM   #1
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
Default Idle problem after Tial Q Bov Install
well i got my tial Q bov welded on last night and i seem to be having a slight idle problem now...
the car pulls 19in/hg at idle (then again that's according to a prosport boost gauge) which according to tial means i should use the 10psi spring.
the problem is that as i roll up to stop lights the car will sometimes stall out. Only sometimes though... other times the rpms go slightly lower than it should then bounce back up and recover to a normal idle.
also it seems more likely to stall out if i heel-toe up to the light rather than just coast in neutral.
the valve appears to be closed at idle (i can see just a little of the o-ring) and it seems to blow-off as it should between shifts... i did notice this morning that after very low amounts of throttle and then a shift it will not quite blow-off but make kind of a "chufchchchc" sound which i guess is compressor surge.
so what do u guys think?
oh i also had a maf flange welded on too since I'm going to a blow-thru setup soon so maybe the block-off plate is leaking? or maybe the maf itself is leaking since i took it off.
Putting a washer in worked perfectly if anyone else has this same problem.
thanks for the help.
fl4tsc is offline   Reply With Quote
Old 12-17-2009, 08:30 AM   #2
CooperS431
Member#: 52007
2004 STI
Really? Another one of these threads? Get rid of the tial and put the stock bpv back on... if it is a vent to atmosphere bov it can cause the maf scaling to be way off in between shifts and at idle and can cause the car to stall. The maf already accounts for the air being recirculated by the bpv, and when you run a vent to air it causes a rich environment.
CooperS431 is offline   Reply With Quote
Old 12-17-2009, 08:33 AM   #3
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
yes thanks i understand the issues bovs can cause which aren't bad if the bov is set up properly. and if you missed the part where i said i'm going to a blow-thru soon, i am, which will completely eliminate any problems a vta bov can cause.
Old 12-17-2009, 08:35 AM   #4
CooperS431
Member#: 52007
2004 STI
Yes you are going to a blow through soon, but the problems you are having now are because of the bov.
Old 12-17-2009, 08:37 AM   #5
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
ya if it was a piece of **** bov then sure your theory would make sense but a well setup bov like the tial (that doesn't leak) has no problem running on a draw thru setup without stalling.
Old 12-17-2009, 08:41 AM   #6
RayN
Member#: 135789
2005 STi
CGM
you might need a harder spring.. and make sure that the seal between the bov and flange is good.. make sure no leaks are present everywhere else. also the lil chuckle you hear can be surge or just the bov bouncing off the spring. even if it was surge, you are not running enough boost when it just chuckles to do any damage. only time to be conserned with surge is when you cant vent at full boost.
RayN is offline   Reply With Quote
Old 12-17-2009, 08:42 AM   #7
ADAS1223
Member#: 159853
2005 Impreza
wrb
Make it tighter! should only open at higher psi's, not just casual shifting
ADAS1223 is offline   Reply With Quote
Old 12-17-2009, 08:47 AM   #8
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
the occasional stalling and rpms that drop way down and bounce back up is completely normal with a vta bov. its going to do it until you go resurculating. nothing to worry about just annoying
under0athh51189 is offline   Reply With Quote
Old 12-17-2009, 08:53 AM   #9
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
that's what i was thinking but i just looked at some old logs and my idle is right around -8.7psi which is -17.7inHg which should be perfect for the 10psi spring since tial says to use the 10psi for idles between -16 and -19inhg.
idk I'm starting to think there's a leak somewhere else or the seal is bad between the bov and flange.
but then again there are no problems i can see under boost.
Old 12-17-2009, 08:55 AM   #10
RayN
Member#: 135789
2005 STi
CGM
^ wrong. a properly set up VTA BOV will not stall
you guys need to read this so that you can properly give out the right information
http://forums.nasioc.com/forums/show....php?t=1602235
Old 12-17-2009, 09:03 AM   #11
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
thank you!! finally someone gets it!
hopefully davenow/defiant will see this soon and give me some tips since he's one of the few that actually understands the car shouldn't stall.
i mean **** i used to run a gfb bov which are some of the worst for leaking and didn't stall and the tial is one of the best so it definitely shouldn't stall.
Old 12-17-2009, 09:09 AM   #12
RayN
Member#: 135789
2005 STi
CGM
as i said in my previous post. you may have to add the 11 lbs spring. and i think -17 may be a lil high, i think you want to be around -20. so you may have a leak regardless and it might not be caused by the bov.
Old 12-17-2009, 09:12 AM   #13
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
ya my idle was iffy before but i just thought it was a tuning issue and maybe a small leak in the tgv to head gasket. i'm taking the intake mani off to get it ported and to replace the gaskets to maybe that will fix it.
also I'm going to lube the o-ring for the maf sensor and maf block off (since they didn't seem to go in so great) when i get home and see if that helps.
Old 12-17-2009, 09:14 AM   #14
stlscoobydoo
Member#: 221261
2004 sti
wrb
you might need to get the bov reshimmed also what size is the bov that you up on there?
stlscoobydoo is offline   Reply With Quote
Old 12-17-2009, 09:15 AM   #15
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
don't know what reshimmed is but the bov is brand new.
what do you mean size? it's the Tial Q...
Old 12-17-2009, 09:25 AM   #16
RayN
Member#: 135789
2005 STi
CGM
the Q is a 50 mm
Old 12-17-2009, 09:27 AM   #17
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
When we played with one we ran into a problem of the vac being so high that it opened at idle. Go with a stiffer spring.
Old 12-17-2009, 09:32 AM   #18
RayN
Member#: 135789
2005 STi
CGM
you might also want to consider making the DIY intake pressure tester.. should be able to find your leak easy that way
Old 12-17-2009, 10:39 AM   #19
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
you have a link to that pressure tester?
Old 12-17-2009, 05:15 PM   #20
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
so right now it seems the best answer is get a stiffer spring...
any other suggestions?
Dave this is where you come in and make us all look like fools...
oh and TiC what BOV do you guys run instead of the Tial? just curious what you've found to work since you guys are pretty damn successful.
Old 12-17-2009, 05:20 PM   #21
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I ran the 50mm Q with a the -21hg spring(11 or 12lb spring IIRC), and it ran fine at idle and did not stall out.
It did surge like a mofo though
Gfunk720 is offline   Reply With Quote
Old 12-17-2009, 05:24 PM   #22
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
what do you mean surge?
aren't the 50mm and the Q 2 different bovs.
the 50mm being the old design and the Q being the new design?
i guess they are both 50mm though. whatever
Old 12-17-2009, 05:26 PM   #23
Gfunk720
Member#: 42549
E92 M3 M\\\
There is the Alpha Q as well. But yes, the new designed 50mm...
Just like you said, the chachachacha sound coming from the turbo region of the car. I only had it on for like 2 miles of driving, but my car definetely didn't like it too much
Old 12-17-2009, 05:31 PM   #24
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
They are both based of the same concept design, the Q just flows more now. If you can see o-ring at idle, then it is leaking due to the vacuum pressure pulling more than the spring can hold. Put a shim in there, or a stiffer spring. Done/
quadtard is online now   Reply With Quote
Old 12-17-2009, 06:10 PM   #25
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
alright well I'm about to order a new spring but I've got one more question..
is there any way to know the 11psi spring will be enough?
idle problem after replace radiator??? sum0325 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2009 02:19 PM
Idle Problems after Spec-c intake manifold install wrxwagon253 North West Impreza Club Forum -- NWIC 16 11-03-2007 04:49 PM
massive idle problem after violent axle brake?? imprezaRS420 Legacy Forum 3 12-27-2006 10:57 PM
Idle problem after blowing SBF5 Annoying Eric Normally Aspirated Powertrain 3 09-07-2005 08:28 AM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
