Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 12-17-2009, 08:28 PM   #1
GLD247
Member#: 207789
2003 WRX EJ257 Swap
Default Spun bearing on stock motor. build ideas.
so i spun a bearing (most likely, regardless it is borked) the other night and well i now need to decide on what to do next. which is both and .
so i need some feedback/suggestions. anything would be extremely helpful. and yes I'm on the stock 5 speed. car has about 70k miles.
1. Rebuild my motor back to stock specs, but that newer crank with more oil journals, and maybe different bearings/clearances?
2. Hybrid build - that newer stock crank, maybe upgraded rods and pistons?
3. new short block and swap over what i can to it
4. used complete 2.0
5. full STi swap
also thinking about possibly running E85
I'm on a budget of about 2-4k. i already have a shop that can assemble/re build the motor for me for about 400 so im good on that.
GLD247 is offline   Reply With Quote
Old 12-17-2009, 09:18 PM   #2
acheung
Member#: 118389
i think you are going to need more money. What's the condition of the heads?
acheung is offline   Reply With Quote
Old 12-17-2009, 09:21 PM   #3
GLD247
Member#: 207789
2003 WRX EJ257 Swap
the heads are fine i would think. havent pulled the motor apart yet to see anything. waiting to decide on most stuff first.
Old 12-18-2009, 06:18 PM   #4
GLD247
Member#: 207789
2003 WRX EJ257 Swap
anyone? i can get a nice deal on some eagle rods and CP pistons. they any good?
Old 12-18-2009, 07:57 PM   #5
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Did you figure out what caused the spun bearing? Low oil level, cracked pickup, dirty oil, or some other cause?
Fierysun is offline   Reply With Quote
Old 12-18-2009, 10:24 PM   #6
hobbesnapoli
Member#: 221436
02 WRX vf39
Yes, they're good....
We need some more details to give you any sound advice
hobbesnapoli is offline   Reply With Quote
Old 12-19-2009, 04:57 AM   #7
GLD247
Member#: 207789
2003 WRX EJ257 Swap
well i dont really know where to start, what do ya need to know?
and no, i will be able to tell you what happened in a few weeks when i get the motor out and apart. i think it had something to do with hard cornering+high revs in the cold ass winter lol.
Old 12-19-2009, 09:03 AM   #8
bertune
Member#: 107290
5. full STi swap
bertune is offline   Reply With Quote
Old 12-19-2009, 10:26 AM   #9
sense of nature
Member#: 112759
2018 bugSti
SexyRP
If you spun a bearing , there is a good chance your heads/cams are trashed.
It takes surprisingly little bearing material to score the cams & Journals \
I would tear it down , then see exactly what u need .
sense of nature is offline   Reply With Quote
Old 12-19-2009, 11:09 AM   #10
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Even then, they aren't exactly trashed, just need a deck and align hone on the journals, and new/polished cams.
Merp is offline   Reply With Quote
Old 12-19-2009, 12:25 PM   #11
sense of nature
Member#: 112759
2018 bugSti
SexyRP
I guess it all depends on how much driving was done after , Another member( Ronzogonzo) spun a bearing on a 255 & drove only 11 miles babying it , heads, crank & cams destroyed
Old 12-19-2009, 12:28 PM   #12
240sxguy
Member#: 229791
2002 WRX wagon
Yeah, my heads/cams are scarred up after someone spinning a rod bearing or two.
240sxguy is offline   Reply With Quote
Old 12-19-2009, 04:15 PM   #13
GLD247
Member#: 207789
2003 WRX EJ257 Swap
well i guess we need to tear it apart to see. but we drove about 1-5ish miles i would say i think, just to get it home.
Old 12-20-2009, 06:44 AM   #14
nolag05
Member#: 146419
2005 Subaru WRX STi
World Rally Blue
i did the samething... i have an STi already tho...
100mm CP pistons
Eagle rods
New cryo treated crank
supertech valve train
kelford 264 cams
11mm oil pump(i think...)
new oil cooler
nolag05 is offline   Reply With Quote
Old 12-20-2009, 03:58 PM   #15
GLD247
Member#: 207789
2003 WRX EJ257 Swap
^^ on what turbo?
how do those cams preform/sound? i was considering cams. but they arent useful at my power goals, and am in it more for the sound (i know). i like the nice lopey idle and whatnot.
Old 12-20-2009, 10:41 PM   #16
nolag05
Member#: 146419
2005 Subaru WRX STi
World Rally Blue
FP green for now... in a couple months it will be swapped for an HTA 35r setup... what are your power goals? most people look to jus stage 2 and
call it a day... others(like me) get there and realize that this car has way more potential!! i don't think the sound is that much different from whatever one is telling me... car should be finished soon, i will let you know how she sounds...lol i am in it for the sound also... but what changes the note alot is if you switch to an equal length header... makes our cars sound like EVO's...lol
^^ on what turbo?
Old 12-20-2009, 11:49 PM   #17
zblad
Member#: 233047
2004 WRX
Default what do u need for rebuild
when your rebuilding these engines what do you have to or should replace and were can you get the gasket kits???
zblad is offline   Reply With Quote
Old 12-20-2009, 11:58 PM   #18
nolag05
Member#: 146419
2005 Subaru WRX STi
World Rally Blue
local subaru dealership or a speed shop in your area... We have 4 or 5 in our area that sell them. you want websites that sell them?
Old 12-21-2009, 12:19 AM   #19
zblad
Member#: 233047
2004 WRX
Default ya
hey yea i would but like what should u replace like oil pump, bearings, and ect.. just kindo if need a list to know what im getting into lol im not sure whats wrong with my motor still need to pull my friend was doing like 120 and now it knocks like crazy??? any ideas lol thanks
Old 12-21-2009, 12:54 AM   #20
ddaddyo
Member#: 226894
2006 WRX STI
CGM
If you decide to go with #5, I've got a used STI short block with 67,800 mi. that I'm about to put up for sale. Heads were damaged due to cracked oil pickup tube, but car seized up before there was any damage to the lower end. ( See this thread for details: http://forums.nasioc.com/forums/show....php?t=1864345 ) Dealer said I just needed new top end, but I opted for a whole new motor. Mechanic said the heads could be fixed with an over sized cam (meaning the journals are over sized) and a proper honing of the journal bearing surface on the heads. Anyway, thought I'd throw that out there. PM me if interested.
ddaddyo is offline   Reply With Quote
Old 12-21-2009, 01:13 AM   #21
nolag05
Member#: 146419
2005 Subaru WRX STi
World Rally Blue
http://www.autopartswarehouse.com/re...placement.html
is one... sounds like a rod but can't tell without hearing her... will it start?
If its knocking like that i wouldn't start it again...lol. Have it towed to a shop and let them check it out...
Who can help me on a spun bearing on an 05 2.5RS Project13 North West Impreza Club Forum -- NWIC 9 03-01-2010 10:42 PM
Spun bearing on my EJ207 whatishe Built Motor Discussion 15 07-09-2009 09:05 PM
stock motor build ? stolen04 Built Motor Discussion 1 02-14-2007 11:51 AM
What causes a spun bearing on a ej205 ? Sausage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 02-09-2007 05:54 PM
99RS 2.5L stock motor build up questions. chrismindless Normally Aspirated Powertrain 3 04-21-2005 04:27 PM
