Old 12-17-2009, 08:09 PM   #1
vinth
Member#: 232797
2002 Wrx Hybrid
Default Bought a 02 wrx with a 14b want to upgrade to vf39
Would be it be a simple bolt on or am I going to have to do a mess load of stuff since it has the t5-14b.
vinth is offline   Reply With Quote
Old 12-17-2009, 08:19 PM   #2
RayN
Member#: 135789
2005 STi
CGM
if you want to run a vf 39, your going to need at the least bigger injectors and a tune. you cant just slap the 39 on and call it a day
RayN is offline   Reply With Quote
Old 12-17-2009, 08:25 PM   #3
vinth
Member#: 232797
2002 Wrx Hybrid
Ok well that didnt give me an awnser? I have 565cc pink injectors perrin fuel rails among other things so the car is qualified for the vf39 but I want to know if I have to buy anything to make it fit or can I just switch them out.
Old 12-17-2009, 08:28 PM   #4
fazeracing
Member#: 142564
PM DScamp 4
Cleveland Steamers
Please let us know everything done to your car so we dont have to guess, and could you fill out your profile that would be great!
fazeracing is offline   Reply With Quote
Old 12-17-2009, 08:33 PM   #5
vinth
Member#: 232797
2002 Wrx Hybrid
Alright ill just keep this simple will there be any difference in bolt pattern from the 14b to the vf39 bolting it to the pipes
Old 12-17-2009, 08:36 PM   #6
RayN
Member#: 135789
2005 STi
CGM
yea its a direct bolt on. all the flanges are the same. . just get a tune when u swap it.
Old 12-17-2009, 08:40 PM   #7
vinth
Member#: 232797
2002 Wrx Hybrid
So I can take off the td05h-14b mitsu turbo and directly bolt on the vf39 with no problems. I really want to be sure before I do all this and it doesnt fit.
Old 12-17-2009, 08:42 PM   #8
coldturbo
Member#: 168900
2002 Impreza WRX
Vf-39 Grp.N luv
How did you find a WRX with a TD05H-14G?
Was that even made in the Subaru form factor?
I know some JDM Subaru's had a 16g.
TD05H-14G should be a square flange.
Last edited by coldturbo; 12-17-2009 at 08:44 PM. Reason: TD05H-14G hsould be a square flange.
coldturbo is offline   Reply With Quote
Old 12-17-2009, 08:43 PM   #9
DrumNWReX
Member#: 99119
2006 WRX Cobb Stg. 2
OBP Clark Turner tuned!
Funny how he's not very forthcoming with details about his setup but keeps asking the same questions... Dude, how are we supposed to know exactly what is going on in your engine compartment unless you tell us exactly what you have going on?
DrumNWReX is offline   Reply With Quote
Old 12-17-2009, 08:46 PM   #10
vinth
Member#: 232797
2002 Wrx Hybrid
OK mod list time...
Greddy FMIC
HKS Bov
Perrin Fuel Rails
Sti Pink Injectors
td05h-14b turbo
It has a full turbo back system but I do not know what brand.
I havent even ran the car yet I bought it wrecked at an auction and im repairing it and my parts car had a vf39 but the exhaust system on that got destroyed.
If you need anything else ask.
Old 12-17-2009, 08:56 PM   #11
DrumNWReX
Member#: 99119
Ok, it sounds pretty standard. My only concern would be the shape of the inlet and exhaust side of the turbo (I'm thinking twin-scroll vs. single like the rest of us mortals have) as being a different shape. But if it isn't like that, then a vf39 should pretty much be plug and play.
Anyone care to correct me? I am in no way an expert here, but this seems to be a common theme among subies. I can't imagine that the turbo would be THAT different
Old 12-17-2009, 09:08 PM   #12
RayN
Member#: 135789
2005 STi
CGM
got pics of the turbo???
Old 12-17-2009, 09:12 PM   #13
vinth
Member#: 232797
2002 Wrx Hybrid
Old 12-17-2009, 09:22 PM   #14
DrumNWReX
Member#: 99119
Ok, I can't tell...
Old 12-17-2009, 09:43 PM   #15
RayN
Member#: 135789
2005 STi
CGM
it looks like the typical stock location turbo but 14b just dont sound right
Old 12-17-2009, 09:49 PM   #16
vinth
Member#: 232797
2002 Wrx Hybrid
yes I agree I saw a G on the turbo I swore but I also thought I saw a 14 so I dunno I will double check tommorow
Old 12-17-2009, 10:16 PM   #17
drifte
Member#: 209749
06 STI
Aspen white
Well its not a td05 14b Mitsu so you should be a direct bolt on. I swapped a friends stock wrx turbo for a sti turbo, only thing that may be an issue is oil feed line I think.
drifte is offline   Reply With Quote
Old 12-17-2009, 10:20 PM   #18
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
^^^ same here...I had to bend my oil line a little to make it bolt up to a vf39
Cbgrandtheftauto is offline   Reply With Quote
Old 12-17-2009, 11:08 PM   #19
RayN
Member#: 135789
2005 STi
CGM
might be a 16g which would be a better than a 39
Old 12-18-2009, 12:54 AM   #20
driftfc88
Member#: 218308
06 STI
EJ207 swap
It's more than likely a 16g which is better than a vf39. I have one on my car and it's making around 270 to the wheels. Find the numbers on the front and match them to the numbers on this list.
http://www.turbomaster.info/eng/cata...i&pagina=TDO5H
driftfc88 is offline   Reply With Quote
Old 12-18-2009, 12:59 AM   #21
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
vf39 will have crack issues. 16G would be better and have more power. If spool is a issue maybe consider port and polish.
Old 12-18-2009, 01:55 AM   #22
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Looks like you bought someone else's mess/problem from the pictures and the mod list.
Byzantium is offline   Reply With Quote
Old 12-18-2009, 02:03 AM   #23
turb04
Member#: 61386
04 PSM WRX R.I.P.
05 Snow White Camry
Wow for awhile this was like the blind leading the blind!!! LMAO
turb04 is offline   Reply With Quote
Old 12-18-2009, 01:44 PM   #24
Calikid
Member#: 157491
03' JdmSti Hybrid
Emeral Green Pearl
get it ported. i have one on my 02.
Calikid is offline   Reply With Quote
Old 12-18-2009, 06:23 PM   #25
lowrider89
Member#: 143022
2005 modded S4
you probably have a 16g which is better than VF-39...
lowrider89 is offline   Reply With Quote
FS SoCal 02 wrx with lots of upgrades but blown motor hellaqwik Private Vehicle 'For Sale' Classifieds 4 02-17-2010 11:18 PM
Just bought an 04 STi with mods. I want to do two things... How do I do it? hotshot2109 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 11-08-2009 09:03 PM
02 WRX with VF39 sk8er722 Proven Power Bragging 45 03-02-2008 10:49 PM
I want to be the first one to upgrade to the '06 WRX brakes... Kostamojen Brakes, Steering & Suspension 11 07-27-2005 02:29 AM
02 WRX - With Upgrades hdrwrx Private Vehicle 'For Sale' Classifieds 4 02-08-2004 03:10 PM
