Old 12-17-2009, 09:26 PM   #1
Blakeat86
Member#: 201543
02 WRX
JDM6MT
Arrow Is the banjo bolt on the td04 the same size?
I'm changing turbos and the banjo bolt on my new turbo is larger then the one on my TD04. I was wondering what size the one on the block is? That would be the one on the other end of the line that goes from the turbo. I'm just trying to figure it out before I start disconnecting stuff and get stuck.
Blakeat86 is offline   Reply With Quote
Old 12-17-2009, 11:35 PM   #2
em99sport
Member#: 172670
2011 STI 5-door
2013 F150 Ecoboost
When I installed a VF39 on my '04 WRX, I used the stock coolant banjo fittings and had to separate the coolant feed section from the drain section. The two banjo parts were too close together for my 39. I simply bent the line back and forth so it created a clean break at the metal section between the banjo parts. No leaks since then.
em99sport is offline   Reply With Quote
what size and pitch is the banjo bolts on the td04 turbo. supernick77 Factory 2.0L Turbo Powertrain 2 07-22-2009 02:01 PM
Are the Center caps on all of the imprezas the same size??? BrickNick Interior & Exterior Modification 2 10-30-2008 12:36 PM
What size is the torque bolt on the injectors on an 05 STi? 1/500yellowwrx Factory 2.5L Turbo Powertrain 0 11-10-2006 03:40 PM
What size washers do I need for banjo bolts on brake caliper? thrdeye South East Region Forum 27 10-14-2005 01:15 AM
Can I Reuse the Washers on the Banjo bolt Silverandscared Factory 2.0L Turbo Powertrain 9 09-01-2004 09:31 AM
Message Board Statistics All times are GMT -4. The time now is 08:35 AM.
