Old 12-18-2009, 07:29 PM   #1
JeankySti
Member#: 170370
2006 STi
Precision 6262 Powered...
Default 6262sp STi [email protected] with problems up top...420whp pump gas...Dyno vid & slips inside!
Hey guys so this past sunday we went to War of the imports where we took my STi on my new setup. With my car my first run I just let off on top of 4th gear right after the 1/8 mile running an [email protected] after that the best I ran was an [email protected] because when I shifted into 5th the throttle body wasn't opening completely and the car would not pass 5500 rpm this was on straight up pump gas even though I had this problem I kept racing and managed to make it to the final round taking 2nd place in my class. Thanks to JoTechPerformance and CMB-Tuning!!! Better times coming soon....
Event:
dyno pull / quarter mile
Ambient Temp: around 90 degrees
Elevation: N/A
Weather: sunny and humid
Track and Conditions: asphalt,clean and well prepped
Tires: Bridgestone, Potenza Re-01r, 245/45/17
Car: 2006 STi
Tuner: CMB-Tuning (Colombia)
Engine Builder:Jo Tech
Dyno Info: DynoJet
Peak HP at RPM: 420whp Sae corrected
Peak Torque at RPM:366tq SAE corrected
Baseline hp/tq for a stock on same dyno: Around 250-260 whp on Sti
Target Boost: 21 psi
Target AFR: 11.2 - 11.3 at wot
Fuel: 93 pump gas unleaded
Engine/Power Modifications:
AEM ems
Precision 6262sp .63a/r
Precision 46mm Wastegate
Turbo Xs basic rotated kit
Tial 50mm BOV
CP Pistons
Eagle Rods
ARP headstuds
Cosworth bearings
BMPC FMIC
TGV Deletes
Walbro 255 Fuel Pump
Stock Modified Injectors
Greddy Profec-B
HkS Carbon TI 3in Exhaust
3mm Grimmspeed Intake Manifold Gasket
Driveline Modifications:
ACT Hdss clutch kit
Suspension Modifications:
Tein S-tech springs
Other Modifications:
Front seats removed
Back seats removed
Wing removed
No spare tire or tools
Catback exhaust removed
JeankySti is offline   Reply With Quote
Old 12-18-2009, 07:33 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Looks good nice 60 ft's, any dyno graphs to go with the slips?
TDagen is offline   Reply With Quote
Old 12-18-2009, 07:38 PM   #3
wrblue_sti04
Member#: 208103
Jeanky good job!!! Saludos a JO
Roly
wrblue_sti04 is offline   Reply With Quote
Old 12-18-2009, 07:57 PM   #4
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you know there are others besides you who have had problems with there sti not wanting to rev past 5500 with the AEM,search for the posts and maybe you may find an answer why.
john 1badSTI is offline   Reply With Quote
Old 12-18-2009, 09:37 PM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
do you have a dyno graph?
Old 12-18-2009, 10:51 PM   #6
JeankySti
Member#: 170370
2006 STi
Thanks man, as soon as I find the graph ill post it up.
Roly
Gracias Roly en estos dias le estaremos arreglando todo los problemitas para volver a llevarlo a tratar de tocar los 11 bajitos a pump gas.
Esperamos verte pronto por aka!
Thanks for letting me know, I will be working with my tuner this upcoming week to see if we find the problem.
Looking for it will post it up soon.
Old 12-19-2009, 11:24 AM   #7
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
gj jeanky.. when are we gonna go at it?
wrxwhat is offline   Reply With Quote
Old 12-19-2009, 11:30 AM   #8
JeankySti
Member#: 170370
2006 STi
Thanks man.. Ill let you know when we figure out all the bugs and we can go have some fun.
Old 12-19-2009, 11:48 AM   #9
xsblack
Member#: 26530
2004 Sti
JBP
Check out this link:
http://forums.nasioc.com/forums/show...M+EMS+hard+cut
I had to send mine back to AEM, the problem was fixed and the unit has been working flawlessly ever since. Good luck. You have a nice setup, it should be a beast when its all worked out
xsblack is offline   Reply With Quote
Old 12-19-2009, 03:44 PM   #10
JeankySti
Member#: 170370
2006 STi
Here is a pic of the actual dyno graph I never took the print out.
Here is a vid of a dyno pull unedited.
Old 12-19-2009, 03:54 PM   #11
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
The torque hardly falls off at all... Thing must pull hard...
Old 12-19-2009, 06:59 PM   #12
fourmicah
Member#: 128760
2015 STI
I'm interested in seeing what you put out with race gas and when you get the issue worked out. I'm thinking of this turbo, but with .82 AR. Why did you do with .63 AR on such a big turbo? What is the WTQ @ 4500, you can't see it on the pic?
What are your thoughts on this turbo?
fourmicah is offline   Reply With Quote
Old 12-21-2009, 06:11 PM   #13
SubyWill
Member#: 166830
2003 WRX
this car is a beast
SubyWill is offline   Reply With Quote
Old 12-21-2009, 07:06 PM   #14
JeankySti
Member#: 170370
2006 STi
We are anticipating around an 11.1 on pump gas and 500+whp and 10's on race gas. I decided to go with the .63 a/r since it was recommended both by my mechanic JoTech and tuner Colombia. I had seen an .82 a/r on others STi's not perform so well. I'm not sure what the wtq is at 4500.
I personally love this turbo it is making enough power on pump gas and it will make much more on race gas. The spool up is good for being a journal bearing, I daily drive this car without any problems whatsoever I would recommend this turbo!!!
Old 12-22-2009, 11:02 AM   #15
fourmicah
Member#: 128760
2015 STI
I thought these turbos were duel ball bearing or does AMS use a variant of this turbo that is the same size?
Old 12-22-2009, 11:09 AM   #16
juanmedina
Member#: 133146
It comes in both configurations
Old 12-22-2009, 12:21 PM   #17
fourmicah
Member#: 128760
2015 STI
I comes in both configurations
Thank you
Old 12-22-2009, 03:02 PM   #18
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Beast.
godforbid67 is offline   Reply With Quote
Old 12-22-2009, 11:40 PM   #19
IboonI
Member#: 102622
Nice car man... Keep it up
IboonI is offline   Reply With Quote
Old 12-26-2009, 02:40 PM   #20
JeankySti
Member#: 170370
2006 STi
They come journal and ball bearing.
That's correct
Thanks, will do...
Originally Posted by SubyWill View Post
this car is a beast
Originally Posted by godforbid67 View Post
Beast.
Old 12-27-2009, 02:00 PM   #21
CVR STi
Member#: 127428
What cc injectors ? Only a single walbro ?
CVR STi is offline   Reply With Quote
Old 12-28-2009, 11:19 AM   #22
JeankySti
Member#: 170370
2006 STi
They are stock modified injectors I bought them as 816cc never flow tested them though and yes a single walbro.
Soon I plan on throwing on some 1000cc, fuel rails and a fpr.
Old 01-05-2010, 07:39 PM   #23
JoTech Performance
Member#: 190436
2006 STi
I cant wait to fix all the little bugs in this car and take it back to the track. Im sure JeankySti can get this car in the low 11's on pump gas and in the 10's after we do the fuel system!
JoTech Performance is offline   Reply With Quote
