Old 12-20-2009, 05:00 PM   #1
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
Default Help put my struts/springs back together :)
I have Front/Rear Version 5 STI struts and springs all apart right now. Adjustable camber plates for the fronts and Group N hats for the rears. Can you guy's string me along step by step of how to ensure I put all this stuff back together properly? Everything is apart but in an organized way. Thanks
Jay
Rallly2000 is offline   Reply With Quote
Old 12-20-2009, 05:08 PM   #2
kumanchu
Member#: 146696
may i suggest going 1 step further in dissasembling the insert from the housings and changing out the grease?
There is a bottom nut on each strut; if you remove that the insert will come out of the housing. remove all of the grease from there (likely to be hard and yellow) and then replace the hard (now useless) grease with fresh synthetic grease. people have reported good results with mobile 1 synthetic red grease, I used valvoline synthetic black grease since the mobile 1 wasn't readily available, and it has worked fine.
it will make the struts work _much_ better.
kumanchu is offline   Reply With Quote
Old 12-20-2009, 05:08 PM   #3
kumanchu
Member#: 146696
oh, and when reassembling to put the bottom nut back on; make sure it is torqued to 14 ft/lbs (not much effort required!) WITHOUT any grease on the threads.
Old 12-20-2009, 05:15 PM   #4
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
You know what kumanchu, I was actually going to do that I've bookmarked the DIY thread for that. Thank you very much for the extra torque info.
Old 12-20-2009, 05:17 PM   #5
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
Although I am worried that when I put it all back together I will get stumped. So if anyone has pics or can lead me with step by step instruction so that I don't need to worry it would be greatly appreciated.
Old 02-08-2010, 08:44 PM   #6
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
14 ft/lbs or 41??
Old 02-08-2010, 11:33 PM   #7
viper74656
Member#: 84758
'04 WRB WRX
When I was assembling my suspension I used this link as a walkthrough:
http://www.iwsti.com/forums/how-inst...-pictures.html
Edit: and this http://www.iwsti.com/forums/how-inst...l-springs.html
viper74656 is offline   Reply With Quote
Old 02-10-2010, 01:37 AM   #8
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
I cannot get the lower nut off 3 of the 4 struts? It is just spinning on the shaft thread? Should I put some heat on it or something?
Old 02-10-2010, 02:37 AM   #9
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
No, take a wire brush attachment on a dremel or drill and remove all the paint off the nut. The paint acts like loctite. Then take an impact and it will zip right off.
Arnie is offline   Reply With Quote
Old 02-10-2010, 10:03 AM   #10
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
NO DO NOT HEAT!!! turn the strut upside down so it is sitting on the top of the dampener that attaches to the tophats. The threads on the bottom have a notch that fits into the bottom of the strut assembly. Turn the dampener by hand until it fits back into the groove. It should no longer spin, now use an impact wrench on it, should come off no trouble at all.
ProdriveDreams is offline   Reply With Quote
Old 02-15-2010, 11:44 PM   #11
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
I am so frustrated!! I had no issues taking the one nut off the first strut but now I can't seem to get the others off for the life of me!! I wire brushed the paint off, used penetrating oil for 7 hrs then tried again upside down while holding the chrome shaft with my impact,. NOTHING........ The nut and thread spin but nothing else. Is this normal? Should I take the 3 to a shop to get removed?
Old 02-17-2010, 11:09 PM   #12
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
okay so today I got 2 more bolts off by compressing the struts while impacting them off. On the 3rd one I some how twisted the thread off the thread from the cartridge and it leak out all of the hydraulic fluid .
Do I A(Replace the strut with a new one and most likely have one stiffer corner?
B) replace the whole STI strut?
C) fix it if its possible?
Old 02-17-2010, 11:15 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
is there someone local to you that can help you??
you seem to need it
Help me finish put my car back together!! :) wrxkid77 NWIC Private Classifieds 2 01-07-2010 09:27 PM
Help me put my Morette headlights back together properly!!! Rallly2000 Electrical & Lighting 1 06-07-2009 02:03 AM
About to put my short block back together... Lachlan Built Motor Discussion 12 03-09-2008 02:40 PM
Help QUICK! Question about putting my Protuned map back onto the car... 2005wrbluesti AccessPort 7 01-13-2007 11:16 PM
help putting my car back to stock? vvRX7 North West Impreza Club Forum -- NWIC 7 01-23-2006 01:24 AM
