Old 12-20-2009, 06:34 PM   #1
modaddict
Member#: 95840
sold to a good bud
awaiting next car
OMGHi2U Connecting rod weight compilation thread
This thread was designed (obviously) to compile a list of connecting rod weights. Now, I don't have them all!!!!!
If you have a build sheet or are a Vendor that is willing to share the weight of your rod please do so!
Pauter:
2.5L pre 2000 DOHC
.905”
2.008”
5.180”
.840”
575g
SUB-230-510-1315F
2.0L
.905”
2.165”
5.135”
.840”
555g
SUB-230-550-1305F
2.2L
.905”
2.165”
5.135”
.840”
555g
SUB-230-550-1305F
2.5L 2000 and newer SOHC
.905”
2.165”
5.180”
.840”
585g
SUB-230-550-1315F
Manley H beam:
14024-4
Subaru EJ 18/20/22
5.137"
2.165"
.840"
.905" (23 mm)
.9063"
535g
Manley "turbo tuff" lol I-beam
14416-4
Subaru WRX EJ20/STi EJ25
5.141"
2.165"
0.840"
.905" (23 mm)
.9063"
613g
Eagle:
CRS5137S3D
5.137"
530g.
Subaru EJ18, EJ20, EJ22
Cosworth:
5.137"
130.5mm
524g
ej20/ej25
Tomeii H-beam
(04-07) Subaru STi EJ25-
130.5mm
K1 Technologies: (h-beam)
SH5137AJJB4 Subaru EJ20 5.137" 2.165" 23mm 3/8" 533g
SH5180AJJB4 Subaru EJ25 5.180" 2.165" 23mm 3/8" 547g
Carrillo:
EJ20, EJ22, EJ25(WRX & STI) 2ltr & STI 2.5
4 PRO-SA SB-2LTR<SA-65137H 3/8 WMC
5.137
131 0.845
21
0.844
21
2.165
55
23mm
517g
BigValley's website lists Carrillo's as the below specs:
http://www.bigvalleyperformance.com/...-2.0L-%26-2.5L
Rod Specifications:
- Bolt Size: 3/8"
- Length: 5.137" (130.50mm)
- Big End Bore: 2.165" (55.000mm)
- Pin Diameter: .9055" (23mm)
- Total Weight (in grams): WMC Bolt = 519, CARR Bolt = 524
- Rotating Weight (in grams): WMC Bolt = 368, CARR Bolt = 374
- Reciprocating Weight (in grams): WMC Bolt = 151, CARR Bolt = 150
OMI rods?
http://www.omi-performance.com/honda...nnecting-rods/
Subaru EJ20
part # description
OMI-CRH-S-EJ-10 We strongly recommend using ACL or OEM bearings for this application.
Length: 5.137" - Weight: ~542gram
Innovative Tuning/ Manley rods
http://www.innovativetuning.com/cata...oducts_id=2976
Specs:
Length: 5.137" (center to center at 68 degrees F)
Weight: 525 gramsAlloy: 4340
Fasteners: 3/8" ARP 2000 cap screws
Oliver:
http://www.oliverconnectingrods.com/...ds/TechSCS.pdf
5.137” Subaru Legacy LT EJ18, 20, 22 0.906 2.164 S5137LT
5.180” Subaru EJ25 LT 0.906 2.164 S5180LT
no weight listed on their website!
Scat:
EJ20 / EJ25 Specification
5.137"
130.5mm
Weight 524g
Element Tuning: (h-beam)
5.137"
520g
Crawford Performance: (h-beam) (also have I-beams)
as shown in post #17 below
510g
Stock STi rod:
as shown in post #13 below
589g
Brian Crower:
Engine ej20/ej25
C-to-C: 5.141"
B.E. Bore: 2.166"
B.E. Width: 0.843"
P.E. Bore: 0.905"
P.E. Width: 0.840"
Fastners: 3/8" ARP2000
H beam = 525g
I beam 535g
I'll keep working on this. This is what I whipped up real quick.
Vendors needed:
Maxwell power
3MI Racing
Axis
Stock rod weight double verification?
Please post your weights. They may be different than listed above. Please post other manufacturers too.
modaddict is offline   Reply With Quote
Old 12-20-2009, 07:35 PM   #2
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice looks like a cool compilation of info lets add to the list!
TDagen is offline   Reply With Quote
Old 12-20-2009, 07:56 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Here are some weights I got from TWE a while back: "STi = 586.6g, EJ25 SOHC = 610.7g, Oliver = 544g (our personal favourite), Pauter = 604.8g." I have a set of the 544g Oliver rods, they're "normal" Phase II SOHC dimensions and I'm not sure they're made anymore. I got the impression from Tom @ TWE that they just had the one set, which I bought from them.
Interesting that the Pauter weight he quoted (for the Phase II SOHC application) is ~20g higher than what you've found.
Pat Olsen
Old 12-20-2009, 07:58 PM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Pat Olsen
Well the internet is always right, 60% of the time.
Old 12-20-2009, 08:14 PM   #5
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Well I have a set of Crawford's rods sitting in front of me. I haven't personally weighted them but the weights listed on them (each one has a weight written on with a sharpie) average to 510 grams. Not the greatest but as you stated the internet is correct 60% of the time. I will see if I can find a good scale and get some actual weights for you. I also don't know who makes the Crawford rods but I'm interested to find out. They list them as "long rods" but they are just the phase 1 ej25 NA rods which are 131.6mm.
John__Gotti is offline   Reply With Quote
Old 12-20-2009, 08:49 PM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Are they H beam or I beam?
Old 12-20-2009, 08:51 PM   #7
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
H beam
Old 12-20-2009, 09:04 PM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
H beam
A picture with the weight would be outstanding!
Old 12-20-2009, 09:07 PM   #9
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
I will see what I can do. Can definitely get you a picture but will see what I can do about getting them weighed tomorrow. Report back then.
Old 12-20-2009, 09:44 PM   #10
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Good website that lists some connecting rod manufacturers:
http://www.strikeengine.com/connecting-rod.html
Old 12-20-2009, 10:35 PM   #11
MartinSTi05
Member#: 145145
2006 wrx STi
I am currently building a 2.12 stroker using eagle rods. I also happen to have a set of eagle rods, stock STi rods, stock 02 WRX rods and a digital scale with a resolution to .1 grams lying around in my shop. If you want I can weigh all three for you on the same scale to give you an idea of the absolute and relative weights. I can also give you the the individual weights for the Eagle rods if you want so we can begin to rate the various brands on their consistency.
MartinSTi05 is offline   Reply With Quote
Old 12-20-2009, 10:37 PM   #12
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
Gruppe-s uses Helix H beam rods in their shortblock. I can not seem to find anymore info on them.
Anyone?
Texy32 is offline   Reply With Quote
Old 12-20-2009, 11:12 PM   #13
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
OEM STi Rods - 589g
Manley H-Beam Rods on the same scale - 518g-520g
Crystal_Imprezav is offline   Reply With Quote
Old 12-20-2009, 11:40 PM   #14
modaddict
Member#: 95840
sold to a good bud
awaiting next car
For sure please weigh them. Any information gathered is extremely helpful. I think most everyone realizes that rods will weight differently from rod to rod, batch to batch and scale to scale.
Old 12-20-2009, 11:48 PM   #15
MartinSTi05
Member#: 145145
2006 wrx STi
However, weighing each rod from many sets from many manufacturers will give people a good idea on who is consistent and who is not.
Old 12-21-2009, 02:06 AM   #16
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
Anyone?
They are acually tomei rods. I bought a gruppe-s built block a little more than three years ago(when they were dirt cheap). I was worried about the helix rods, but then when I spun a bearing, and I disassembled that bad boy, I came to find out they were tomei rods. I thought I got an error in my favor, but then I called them and they said they are infact the same rods tomei sells for $$$$ just relabled as helix, even though the rods themselves have tomei slabbed all over 'em.
In regards to the thread, since you don't have weights for these, I just pulled my motor (going back to stock), I haven't decided if I'm going to sell it whole, part it out, or put it in my 08 sti that I will be buying. If I part it out I will definitely weigh them for ya.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 12-21-2009, 10:22 PM   #17
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
So I weighed one of the Crawford rods that I have and it was 1.12lbs or 508g. The scale I used was not the greatest (was at the hardware store for measuring bulk hardware) so imagine it is rarely calibrated and not the finest resolution. But from this result I must conclude that the weights listed on the rods are correct. The weighs that are written on the rods are; 509.6, 509.8, 510.1, 510.3. So I would venture to say the Crawford "Long Rods" are 510g, their length C-C is 131.6mm since they are just phase 1 NA ej25 replacement rods. If you still want a picture I could probably post one but it looks like any other H beam rod.
Old 12-22-2009, 03:13 AM   #18
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Its nice to have a list, but don't be tricked into thinking that the lightest rod is the best rod.
How do you measure strength and quality...?
Beetspeed is offline   Reply With Quote
Old 12-22-2009, 10:56 AM   #19
Member#: 42075
Thats easy... on the dyno!
And the lightest rod usually fails first when you are making big HP
Team Crawford
Crawford Performance is offline   Reply With Quote
Old 12-22-2009, 11:23 AM   #20
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
^So since you posted Crawford why not give us some more info on your rods. Like weight, length, manufacturer, what hp you rate them too, etc.
Old 12-23-2009, 01:23 PM   #21
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Would you mind weighing these rods?
I'm really interested to have a double verification on a stock STi rod.
Old 12-23-2009, 01:25 PM   #22
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Originally Posted by Crystal_Imprezav View Post
OEM STi Rods - 589g
.905”
2.165”
5.180”
.840”
585g
SUB-230-550-1315F
It's interesting that the "bomb proof" Pauter rod is 4g lighter than the OEM sti rod.
I would love to have independant verification on this.
FWIW, 1lb has 454 grams.
Running a rod that is relatively light (500g I'll use as "light") the Pauter rods would come in at 340g heavier or .75lb's.
I'm most definitely not worried about 3/4 of a pound.
big wig racers are.....
Old 12-23-2009, 01:50 PM   #23
modaddict
Member#: 95840
sold to a good bud
awaiting next car
updated the 1st post with moAr.
Old 12-23-2009, 11:35 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you guys really want to compare my long rod's weight to a standard length rod?...that' seems like a great comparison
Old 12-23-2009, 11:35 PM   #25
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Pat Olsen
I too have a set of Pauters that came in 20 g higher than what is stated on the web site mine came in @ 603.4
sense of nature is offline   Reply With Quote
ej207 turbo compilation thread wrxsnowstyle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-16-2009 07:43 PM
wtb: ej22t connecting rods or 2.2 n/a connecting rods 91turbosedaan Private 'Wanted' Classifieds 1 01-10-2009 12:37 PM
wtb:ej22t connecting rods..or j22 n/a rods 91turbosedaan NWIC Private Classifieds 1 01-10-2009 04:58 AM
Connecting rod WEIGHT PeteDucati Built Motor Discussion 20 04-07-2007 05:06 PM
eurojax's yearly photoshop compilation thread (part deux) (lots of gifs) (57k okay) eurojax Off-Topic 8 03-07-2006 08:45 AM
