#1 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
Event: dyno pull
Location: Epic Motorsports Fayetteville, NC Ambient Temp: 55 degrees Elevation: feet above sea level Weather: sunny, chilly Car: 2004 Subaru WRX Tuner: Robbie Latta @ Epic Motorsports Dyno Info: Mustang Peak HP at RPM: 424.5 @ 6271 RPM Peak Torque at RPM: 410.4 @ 4492 RPM Baseline hp/tq for a stock on same dyno: ~225 hp for a STi Target Boost: 22 psi (how about 22 psi before 4000 rpms sound )Target AFR: 11.8 on methanol injection Fuel: 93 octane on 100% methanol injection using a M10 nozzle Engine/Power Modifications: Coolrex Engineering 2.5L EJ257 shortblock, 99.75mm CP pistons, stock STi rods, STi crank, STi cams, Sti headgaskets, 8.8:1 CR, EJ205 Heads with Coolrex Engineering mild porting/polishing (VERY MILD ), Garrett GT35R with Tial vband .63 exhaust housing, Tial 44mm EWG, Hallman Pro manual boost controller, Coolrex Engineering 3" intake with K&N filter, TurboXS rotated uppipe and downpipe modified for vband, TurboXS rotated FMIC piping with blow thru MAF, TurboXS FMIC, TurboXS fuel rails, Coolrex Engineering TGV deletes, IXIZ AOSep, IXIZ intake manifold isolators (work AWESOME), Stock modified BOV, SMC methanol injection kit with M10 nozzle, Walbro 255 pump, modified stock injectors (820cc), Maddad Equal Length Headers with modded for EWG Maddad uppipe.Driveline Modifications: 2007 STi 6 speed, ACT 6 puck sprung clutch/pp Suspension Modifications: RCE Blacks with Tokico DSpec's, GTSpec ALK, Perrin 25mm sways and endlinks Dyno Sheet (horrible pic but it the best I have right now): ![]() Video: Sorry this is on my camera phone and there is a lot of dyno background noise Credits: I have to give credits where they are due. 3 people have contributed to helping me. 1.... WJM Thanks for the tech and support buddy. 2.... is Robbie @ Epic Motorsports. He never gave up on the tune and fought that annoying blow thru MAF for some great results and on several occasions helped me in a pinch when I was unsure about something I have done 3.... would have to be Doug @ Topspeed. He originally helped me spec out the motor while I was building it and convinced me on my turbo setup. Thanks for your input and support buddy. Robbie has the skills over at Epic. Also Steve and Jason constantly listened to me and provided their input on my build. I've seen many cars go in and out of Epic Motorsports in the 3 months I've been building my setup. You simply can not go wrong with them! Give Epic Motorsports a call. Blow through MAF's are horrible to tune but NOT impossible. They are very hard to get a nice straight AFR curve as you can see in my dyno sheet but my curve is +/_ .1 point of AFR and I'm running stupid low timing so I'm safe as can be. Towards redline I was maxing out the MAF and it wanted to run lean so Robbie dumped fuel in as rich is better than lean....it worked. I'm contemplating going back to suck through MAF to see if the car likes it better but so far it's smoother than stock right now. The car freaking pulls like a banshee. Never stops pulling on the street. Full boost around 3800 rpms according to datalogs. This setup far surpasses my old record setting 18g on the EJ205. We are going to put some more miles on this engine before pushing it more as there is a LOT of room for more boost and timing. It was dynoed with only 500 miles on the new engine so right now I'm gonna enjoy it. Stay tuned later for more in the spring time ![]()
#2 |
Member#: 114631
Vehicle:2007 11.5 @ 118 Stock Turbo Record Holder |
Very nice. I was gonna say, 22 psi on meth? Then I read further. If you think your having fun now, wait till you turn her up!!
#3 | |
Member#: 85813
South East
![]() FYI my bone stock EJ205 was boosting 26psi on meth ![]() |
#4 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
dude, what happen
?post some datalogs, or run an Airboy Congrats |
#5 |
Member#: 85813
South East
#6 |
Member#: 133146
#7 |
Member#: 85813
South East
#8 |
Member#: 99102
South East
Vehicle:08 Corvette Z06 problem Traction? |
how many rpms are you spinning it to?
#9 | |
Member#: 133146
. So, is the car still weighting 2800 lbs? If it is, it must feel unreal. Any plans on going to the track? I need a ride ![]() GL |
#10 |
Member#: 85813
South East
#11 |
Member#: 85813
South East
Doubt it. I put many things back into it as now I'm focused on driving it and enjoying it vs killing times at the track.
#12 |
Member#: 16197
South East
Vehicle:2005 OBP LGT 99 WR400 SuMo |
Impressive man, congrats!
#13 |
Member#: 193949
South East
Vehicle:BugI WRX "Rissa Roo" WRB E III XVIG |
Robbie does it again...great numbers, I couldn't be more happy with my tunes from him either!!
#14 |
Member#: 85813
South East
Before people start asking why I chose a .63 exhaust housing.....yes tq falls up top as my timing is safe and low. I built this car for a wider power vs making all out power. I'm boosting a full 22 psi before 4K
That's EXACTLY what I wanted. |
#15 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
I am so glad you are smart to know that you don't have to crank it high in the revs and you also understand you don't need to crank it past where it makes power.Just to let you know if you switch back to a suck thru maf you will max it out even sooner,just to let you know. good luck and enjoy your ride
#16 | |
Member#: 85813
South East
#17 |
Member#: 77470
all the blow thru I have used on customer cars and tuned were 3",the kstech is a bigger suck thru but since it is not pressurized like a blow thru it still might get maxed out too soon.Just to let you know I have seen 600whp on a 3" blowthru no problem.
#18 |
Member#: 159243
Vehicle:sg3 Turbo Tek Tuned Hakt Ecu e85 30r 6spd |
congrats...enjoy.
#19 |
Member#: 99102
South East
#20 |
Member#: 85813
South East
Look at the dyno chart and you will see. Tq drops and hp is starting to fall off. Shift and get back into the meat of the power band.
That's one of the biggest killers at the drag strip.....drivers not knowing how to read their power band and take advantage of it. |
#21 |
Member#: 159243
why rev the motor to the limit when the power band is well before 7500. its pretty simple.
the 2.5l's have more rotating mass than the 2.0's. the ej207 powerband reads differently. also depends on your turbo/injector/bolt on setup. |
#22 |
Member#: 198925
South East
Thanks Delette glad I could tune your car. Cant wait to dog on her a bit more this spring! Woot.
#23 |
Member#: 85813
South East
#24 | |
Member#: 77470
#25 |
Member#: 70459
TXIC
Vehicle:2002 AW Bugeye ej257 6spd, GT3076R, Alky & EWG |
i was expecting something closer to 450whp with a 35r and 100%meth on 93 pump but i guess the smaller exhaust housing has something to do with it and the small amount of timing. i dont know... =(
| Thread Tools | |
| Display Modes | |
| dyno tune 2.35L Ej22t sti heads gt35r 571 whp @ 25 psi | Rod702 | Proven Power Bragging | 28 | 04-30-2010 09:58 AM |
| Maxwell Power Dyno Tune: 2.5L Hybrid + GT35R = 588whp | Maxwell Power | Proven Power Bragging | 47 | 12-31-2009 06:31 PM |
| the great debate built ej207 or built hybrid? | waldo | Built Motor Discussion | 21 | 07-01-2009 12:12 AM |
| FLI Tuned 320wtq/325whp Built Hybrid w/4Krpms power band! | UP2MTNS | Proven Power Bragging | 27 | 09-25-2008 06:36 PM |
| Dyno tuned GT35r 05 STi with EasyEcu by Ecutek | boostinscooby | Proven Power Bragging | 6 | 10-29-2006 09:42 PM |
