Old 12-21-2009, 03:29 PM   #1
unclemat
Member#: 114530
2005 LGT 6MT wagon
Default Twinscroll hybrid VF36/GT2871 tuned by EFI Logics
Got my car tuned at EFI Logics. Great shop and Chris is a great guy and very knowledgeable tuner! Highly recommended.
Car: 05 LGT 6MT (08 STI tranny, 4th gear pulls on the graph), built engine.
Mods: VF36 twinscroll ball-bearing turbo w/GT2871 compressor wheel (same wheel as in AVO380) w/15 lbs. AVO wastegate actuator, JDM STI twinscroll EL headers/uppipe, AVO catted downpipe, Perrin Y-mid with extra straight-thru Mangaflow muffler welded in, STI quad-tip cans, AVO CAI, Perrin inlet, 08 STI intake manifold/TMIC, TGV deletes, DW 740cc injectors, AVO fuel pump, Prodrive BCS.
The numbers are not too impressive, although this is not an optimistic dyno (stock STI puts 240 whp on it) - 292 whp peak (note the graph is corrected, it put 310 whp uncorrected, but it was pretty cold day, probably less than 40F in the dyno bay), but the power band is really nice. The car responds incredibly quickly and is a hoot to drive. Chris said something is holding the turbo back, likely restrictive exhaust (I wanted to swap the quad-tips for stright-thru Prodrives, but didn't have time to do it).
Dotted lines are the baseline (road tune by my friend), solid lines are the final tune. The results are now also in their dyno database.
Comparison with 2008 SpecB stock (comparision should be made with SpecB because of the 6MT tranny):
And versus EFI's shop stage II SpecB:
unclemat is offline   Reply With Quote
Old 12-21-2009, 03:48 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Congrats on the power, Im sure it pulls like a mother..
But I have to ask, why not save a million dollars and just go with a vf22? You could get a used one for 400 bux, its ball bearing, and you can make more power out of it with relative spool.
STi Mikey is offline   Reply With Quote
Old 12-21-2009, 03:50 PM   #3
unclemat
Member#: 114530
2005 LGT 6MT wagon
I just felt adventurous and experimenting... yeah, it absolutely wasn't cost effective, but oh, well. I think the setup has more in it. Will try to optimize it and also I'll add alky injection in spring and get it retuned.
Old 12-21-2009, 04:17 PM   #4
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
When you get a chance please read this and update your 1st post to the required format.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 12-21-2009, 05:20 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i dont think cost effective and twin scroll will be used in the same sentence for subies for a long time.....especially stock location twinscroll.
I mean all our fancy stock location turbos (ATP and Blouch) are already pushing $2000. Now add a TS manifold to that (Tomei $600, FR $1500). And you might as well go rotated and get an intake and downpipe with your kit.
I'd venture to guess a rotated SS gt35 would even spool equal to a stock location TS version.
Old 12-21-2009, 05:46 PM   #6
unclemat
Member#: 114530
2005 LGT 6MT wagon
I agree. But my goal was maximum spool, throttle response and decent top end I was hoping for 320 whp Mustang ponies on pump, so I didn't get there.
The TS header/up/turbo cost me about ~$1500 (nice score, since VF36 go for that much alone). Plus $300 to modify the turbo. So it wasn't all that bad compared to a comparable single scroll setup and e.g. Perrin EL header. The quality of OEM EL header is above anything else, even above Full Race IMO, since the material used is almost as thick, but then they add the insulation and heatshields.
Old 12-22-2009, 08:47 AM   #7
EFI Logics
Vendor
Member#: 193180
Thanks for stopping in! The car definitely had a unique setup and it was nice to see such a modded LGT wagon roll in!
- [email protected]
EFI Logics is offline   Reply With Quote
Old 12-22-2009, 10:58 AM   #8
boston_errol
Member#: 179007
2005 Legacy GT Wagon
ABP
I've seen this car in person at a cars and coffee a while back. Gorgeous. Post pics!
boston_errol is offline   Reply With Quote
Old 12-22-2009, 11:11 AM   #9
unclemat
Member#: 114530
2005 LGT 6MT wagon
Thanks. These are slightly out of date pics, but while internal changes have been huge, externally only cans have changed:
DOM 3 XTR Tuned by EFI Logics mywifesSTi Proven Power Bragging 64 07-06-2010 01:24 PM
2008 DGM STI Stage 2 - 300WHP - Tuned by EFI Logics adam07specb Proven Power Bragging 11 02-10-2010 12:23 PM
2008 STi Tuned By EFI Logics RxDoc Proven Power Bragging 2 05-01-2009 09:35 AM
Element GT52 Tuned at EFI Logics Ray_STi Proven Power Bragging 32 12-24-2008 01:46 PM
