Old 11-10-2012, 09:24 AM   #26
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Originally Posted by SG02WRX View Post
I'm having the same issue. Any idea on what the noise was?
It's coming from that same area.
Well, that would be the A/C compressor, so try removing the A/C belt and see if the noise goes away. If it does, you've just found the culprit.
tibug is offline   Reply With Quote
Old 11-10-2012, 09:38 AM   #27
WrXwAgOnWrB
Member#: 269631
05 9-2x
Dark Blue Metallic
I know some belts when new can cause a different pitch or noise because they are new. If it only started after you replaced your belts. Or like stated before a bearing could be going out.
WrXwAgOnWrB is offline   Reply With Quote
Old 11-10-2012, 10:14 AM   #28
tommyson01
Member#: 154579
2005 OBXT
Old man blue
This, but I don't think it's the compressor.
Take the AC belt off and see if the whine goes away. It sounds like it is the bearings in the AC idler pulley are going bad. Common and cheap and easy to replace.
tommyson01 is offline   Reply With Quote
Old 11-10-2012, 01:26 PM   #29
Civ2Sub311
Member#: 178149
2004 Impreza WRX
WRB Stage 2
The answer was right here on the YouTube video page:
Civ2Sub311 is offline   Reply With Quote
Old 12-22-2012, 11:22 PM   #30
caution
Member#: 20397
2002 WRX sedan
Midnight Black
I wanted to report my experience with this. About a week ago a whine started up suddenly and remained, but everything else ran fine otherwise.
It was the AC pulley bearing. My cousin and I took the front belt off first. I started it and the whine continued, but it was still difficult to determine whether or not it was the pulley or something up higher. Since he lives near an auto parts store we took a chance and just went and bought a new pulley bearing and popped it on there. No more whine.
It's an 2002 WRX, so it had been on there a long time.
caution is offline   Reply With Quote
Old 12-23-2012, 11:31 AM   #31
fr0st
Member#: 41618
2008 WRX Hatch
wrb
i'm betting on AC compressor clutch
one thing you try, if it's above 32F outside, is putting the AC on and off to see if it's changing the sound..
it won't work below 30F i think as the compressor has a sensor to stop it from working when it'S cold so it won't get damaged..
also, put a LONG flat head screw driver on the compressor and put your ear on the other end, do it on the altenator as well and other things you can think of.. it will help pinpoint the source instead of just having a hunch on where the problem is.
EDIT: BE CAREFUL WHERE YOU PUT THAT SCREWDRIVER SO YOU WON'T GET HURT..
fr0st is offline   Reply With Quote
Old 12-23-2012, 11:40 AM   #32
Diodon
Member#: 341423
Mine's been making the same noise as well....
Diodon is offline   Reply With Quote
Old 08-30-2014, 08:28 PM   #33
paulpat
Member#: 237145
02 WRX
12 FXT
bumping... car started to make this sound. I'll be replaying this vid when i get home to better speakers but it sounds just like it.
paulpat is offline   Reply With Quote
Old 10-20-2014, 06:36 PM   #34
_zrobbie
Member#: 391465
2005 WRX STi
Mine started doing something similar too, the sound gets louder with the revs on mine. Coming from what looks like the same spot too
_zrobbie is offline   Reply With Quote
Old 06-14-2015, 12:51 AM   #35
Zitro
Member#: 369247
2013 WRX Hatch
Bumping an old thread, I know, but I just noticed this same sound on my WRC. It's a 2023 with only 24k miles, so it would be pretty surprising if it was a belt going already. I'll check this out, but any other suggestions?
Zitro is offline   Reply With Quote
Old 06-14-2015, 12:54 AM   #36
Sikk
Member#: 241662
2006 WRX VF48
time traveler spotted
Sikk is offline   Reply With Quote
Old 06-14-2015, 01:23 AM   #37
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
Pics or it didn't happen. I am curious about that body style, and WRC cars for the street by then too. This could be cool!
575rider is offline   Reply With Quote
Old 06-14-2015, 01:24 AM   #38
575rider
Member#: 112024
03 hybrid 6spd wgn
How else do you put that many miles on such a new car?
Old 06-14-2015, 04:33 AM   #39
Zitro
Member#: 369247
2013 WRX Hatch
Spoiler alert: the 2023 only comes in wagon form.
Haha damn you guys; meant 2013.
Wierd noise, only at certain times WTF shamrock 05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-26-2009 12:46 AM
WRX whine noise when engaging gears at certain speeds Blue2002WRX Transmission (AT/MT) & Driveline 0 04-27-2009 12:46 AM
Tranny is all of a sudden making a very loud whining noise fatcircles Transmission (AT/MT) & Driveline 4 02-06-2008 07:37 PM
24k miles on car and all of a sudden weird grinding noise when braking cold. Eric SS Brakes, Steering & Suspension 5 04-14-2003 07:00 PM
